Old September 27th, 2020, 11:47 AM   #1
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Pics of 250 cylinders out of the block
Hi Guys, does anyone have any pics of an 08-12 250R cylinder block with the liners removed ? Just looking to see how the liners are sealed in the block.
Thanks
Old September 28th, 2020, 12:57 AM   #2
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Thanks
I've got one opened up!
The Bike | The Truck
Old September 28th, 2020, 01:31 PM   #3
How about this? ZZR600 and Ninja 250 liners. Seal is with O-rings. If you're boring for larger liners, just use press-fit and anaerobic sealant on assembly. I also like liner-flange to be 0,05mm above deck for extra clamping, although not really needed on un-boosted applications.
Old September 28th, 2020, 02:10 PM   #4
More of liners:
and block:
Thanks bruce!
https://www.ninjette.org/forums/show...3&postcount=27
Old September 28th, 2020, 02:30 PM   #5
Mohawk
Mohawk's Avatar
Thanks Danny, the 600/250 pic is one of mine. I found that post from Bruce, but the pic had timed out. So the new gen liner is as I recalled with the O-ring in the cylinder, what I really want to know is what is the OD inside that O-ring groove ?
The block pic is a pre-gen one as no cam chain tensioner boss. The pre-gen did not bother with an upper O-ring, because the head gasket forms that seal. Not sure why they added the upper one to new-gen. Either way I have a spare set of 600 liners that can be fitted & bored to 66 or 67mm for a 335 or 345cc big bore.
Thanks
Old September 28th, 2020, 02:38 PM   #6
OD of groove in new-gen liner? To determine liner thickness there?
I do have pre-gen block I can open up for you. Will have to be after this weekend when I'm back from holiday.
Old September 28th, 2020, 03:11 PM   #7
Mohawk
Mohawk's Avatar
I’m Only interested in the new-gen block at the moment. I have one that I bored to 64mm for a 315cc. These are being fitted to 300 engines !
That upper O-ring groove reduces the liner thickness, so I’ll get them pressed out of another block & replace with 600 liners.
Thanks
Old January 31st, 2023, 02:21 PM   #8
Mohawk
Mohawk's Avatar
So the world went mad & many people got furlough & did their bike projects. Unfortunately I had Covid badly right at the start & then had to work right through. So everything got parked. So finally started on the ZZR 315 engine build & finally got the X300 cylinder bored & replated. Just arrived yesterday.
https://www.dropbox.com/s/omm2ghxd9t...71A0.jpeg?dl=0
https://www.dropbox.com/s/uh6di2vnkp...DE71.jpeg?dl=0
Can't get 08 250 to run on both cylinders ford4x4302 2008 - 2012 Ninja 250R Tech Talk 5 March 11th, 2019 06:50 AM
07' Ninja 250 Farkles (pics pics pics) instinct 1986 - 2007 Ninja 250R Farkles 4 April 15th, 2014 06:26 PM
