March 24th, 2013, 04:37 PM | #1 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
No new bike....yet
It's got a nick on the rear fairing, and it needs tires ASAP (ordered some Battlax BT-023s), and bar-ends. I already ordered adjustable levers, reflective rim strips, and the honda/cbr/600RR decals to put on there.
It has blue LEDs on the front under the nose and the rear; there were some on each side at the bottom of the fairings, but I ripped them off, probably gonna take off the other ones as soon as I have time to take off the fairings. Last futzed with by xSean13; March 28th, 2013 at 08:10 AM. |
March 24th, 2013, 05:08 PM | #2 |
Looks like a great bike.
March 25th, 2013, 06:16 AM | #3 |
hates stupid people
Definitely looks good with the exception of it being lowered. Hope everything works out.
My vlogging channel: Ma1iciousLogic |
March 25th, 2013, 05:14 PM | #4 |
Glad you found something that looks worthwhile. Give her a good look over! Good luck!
March 25th, 2013, 05:38 PM | #5 |
You gunna keep it yellow?
March 25th, 2013, 05:46 PM | #6 | ||
Yeah it looks that way, going to check it out wednesday. Fortunately the blue LEDs toggle on/off. Well, probably not. If I did, I'd add some black (plastidip probably, lol) to break up all that yellow. However! I found a 2006 CBR 600rr with 17k mi that I'm going to also look at...he said he'd take $4200 for it. It's got the carbon yoshi, pc5, etc (he doesn't have the stock parts though....) I know i'd eventually want to change the stock exhaust on the yellow one & obviously need a powercommander or something, so I'm debating on which I should lean towards. If the exhaust, pc5, 3 years newer, and black justify $700 versus the 10 year old bike with 9k miles, which is yellow. http://nashville.craigslist.org/mcy/3690200502.html |
March 25th, 2013, 07:12 PM | #7 |
Join Date: Sep 2011 Motorcycle(s): 2009 Triumph Street Triple, 2009 KLX250SF, 2003 Suzuki SV650S (Sold), 2006 Ninja 250 (Sold) Posts: A lot.
Get the black one!
March 25th, 2013, 07:36 PM | #8 |
Don't be racist jono!
just kidding :P I'm leaning towards the black one, but they're about equal in my opinion as far as pluses/minuses. Therefore, I'm going to go look at them both Wednesday (which coincidentally is also my birthday), talk to the owners and see who seems like a better person and if both bikes are as they say, then go from there. I bet I can get the black one at $4000 when he has a stack of $100s in his hands. |
March 25th, 2013, 08:41 PM | #9 |
Doh!
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250r Posts: 286
Even though 10 years is a long time 7 isn't that far behind. Seeing as its only done 9k miles, unless you plan to stick onto it for a while it wouldn't be worth it.
Still, who knows maybe you might find another bike with an even better deal. Good luck |
March 25th, 2013, 09:03 PM | #10 | |
Honda did make quite a few changes to the CBR 600rr bikes starting in 2005, particularly a lighter, aluminum frame, and adjusted engine with better mid-range. So, there are more difference aside from just age. |
March 25th, 2013, 09:24 PM | #11 |
Upside down forks as well.
March 25th, 2013, 09:51 PM | #12 |
Yeah, forgot about the inverted forks, and something about dual radial front brakes. I honestly have no idea what advantage inverted forks offer, or the difference in the brakes.
Just read up on inverted forks, sounded to be more noticeable for track use. |
March 25th, 2013, 09:53 PM | #13 |
Get the black one!!!
March 25th, 2013, 10:05 PM | #14 | |
Doh!
March 25th, 2013, 10:07 PM | #15 |
Lol, that seems to be the consensus, and I prefer black.
The guy just emailed me more pics...it's got a pretty good sized crack on the front fairing near the windscreen/mirror. And it's got a +3 rear sprocket and probably -1 front...which I'd need to swap out since I won't be doing wheelies or need the extra take off power...and I guess I'd have to get a new chain too. Lol, so now I'm leaning towards the yellow one that's basically stock. |
March 25th, 2013, 10:16 PM | #16 |
Doh!
One man's treasure is another man's junk... erm well that didn't sound quite right lol
Well, get the canary and paint it black, look out for after market parts that can suit you're requirements. Figure out the total cost and ten decide which would be a better buy. oh the possibilities.... |
March 25th, 2013, 10:29 PM | #17 | |
March 26th, 2013, 06:45 AM | #18 |
Yepp pretty much. They keep everything in oil so there's less frothing, but you're likely not going to see any advantage on the street from that because it takes some hard riding to notice that.
March 26th, 2013, 07:39 AM | #19 |
Join Date: Jan 2011 Motorcycle(s): 15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R Posts: 422
The difference in the brakes is the 06 has radial mounted front brakes. Kawasaki was the 1st to add them to the 600 class in 03. Suzuki did it in 04 and Yamaha and Honda in 05. The same goes for inverted forks on all bikes mentioned.
I would pick the 03 CBR and actually like the yellow. I almost bought the exact bike but ended up buying a new silver 03 VFR800 instead.
15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R 636 |
March 27th, 2013, 07:31 PM | #20 |
Here it is...considering naming it "Bumblebee"
It has blue LEDs on the front under the nose and the rear; there were some on each side at the bottom of the fairings, but I ripped them off, probably gonna take off the other ones as soon as I have time to take off the fairings. |
March 27th, 2013, 08:28 PM | #21 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Nice! Congrats on the new bike! Holy crap that front tire though..
March 27th, 2013, 09:07 PM | #22 |
March 27th, 2013, 09:19 PM | #23 |
Congratulations!!! She's definitely a beauty
March 27th, 2013, 09:21 PM | #24 |
Damn! That's a cold-ass honky!
Enjoy the new bike! |
March 27th, 2013, 09:56 PM | #25 |
Doh!
Good choice mate... That is definitely a thing of beauty. That yellow certainly does make some of its lines stand out. Congrats!
bumble bee eh? That calls for some black racing stripes |
March 27th, 2013, 09:57 PM | #26 |
March 27th, 2013, 10:11 PM | #27 |
Doh!
You should get all the silver parts painted matte black as well so that the bike is pure black and yellow machine... I think you could also swap the mirrors with that of a 250 or something that looks sharp and clean, seems like the 250's would fit... just suggestions btw forgot to ask, how do you feel about the engine? It might have lost some power over the years, you should have that checked out unless you've already done so. |
March 27th, 2013, 10:20 PM | #28 |
It's still a beast. With 9,000 miles...it wasn't ridden much, and not very hard.
I'll definitely have to look into some other mirrors, these are UGLY and basically just suck. I ordered some black decals with a silver outline on some of them, and reflective silver and reflective yellow wheel strips, I'll see if I can plastidip over the silver & the Honda decal, because I don't want to have to remove it if I don't have to. |
March 27th, 2013, 10:30 PM | #29 | |
Doh!
Thats pretty cool! Do keep us posted on all the upgrades... plenty of pictures
March 28th, 2013, 07:10 AM | #30 |
Looking good Sean!! Gratz on the new ride!! 9000 miles and mostly stock except the cosmetic stuff.
Be sure to give it a really thorough once-over, then go have some fun once you get new tires. CBR's are really fantastic all-around bikes. Are you going to ditch the nasty blue HID's? |
March 28th, 2013, 08:09 AM | #31 | |
I'm trying to figure out where that right bar-end went...lol Quite the mystery, as it shouldn't have just slipped off. |
April 3rd, 2013, 05:54 PM | #32 |
New tires, new decals, new reflective rim stripes (poorly put on, but I have a lot more), and some plastidip
April 3rd, 2013, 07:02 PM | #33 |
You and the plasti-dip It looks great. Much better than it was.
April 3rd, 2013, 07:08 PM | #34 |
Sharp looking bike
April 3rd, 2013, 09:16 PM | #35 |
Doh!
Looking real sexy right there! and I see you painted the bottom black which looks sick!
April 3rd, 2013, 09:34 PM | #36 |
Thought about blacking out that swingarm? Sweet bike!!!
[motorcycledaily.com] - MD Bike of the Year: KTM 1190 Adventure (Bike Reports) (News) | Ninjette Newsbot | Motorcycling News | 0 | December 28th, 2014 06:50 PM |
[motorcycle-usa.com] - Harley Bike Week Ride-In Bike Show 2014 | Ninjette Newsbot | Motorcycling News | 0 | March 13th, 2014 12:10 PM |
[topix.net] - Honda Chopper Bike: A futuristic bike to complement the personality of | Ninjette Newsbot | Motorcycling News | 0 | November 29th, 2011 02:40 PM |
[superbikeplanet.com] - Finally a Bike That Fits Him? Sic Tests 1000cc Honda GP Bike | Ninjette Newsbot | Motorcycling News | 0 | October 4th, 2011 06:40 AM |
[roadracingworld.com] - Harley-Davidson Bringing 70-Bike Demo Fleet To Daytona Bike W | Ninjette Newsbot | Motorcycling News | 0 | February 9th, 2010 01:00 PM |
