Old May 29th, 2014, 10:17 PM   #1
WAGESLAVEesc
Motorcycle(s): 04 250R
Front brake pads/rotor scraping
I can hear it scrape every time the front wheel goes around. Could this be a something I can fix by adjusting, or is my rotor bent, or could it be possible my brake pads are burnt out? Thanks
edit: looks like I'll have to take a video, I'll reply once I've got one
Last futzed with by WAGESLAVEesc; June 4th, 2014 at 09:33 PM.
WAGESLAVEesc is offline   Reply With Quote
Old May 29th, 2014, 10:24 PM   #2
Scraping isn't good; you need to find out what's causing it. What do the pads look like?
Old May 29th, 2014, 10:24 PM   #3
/moved to pre-gen tech
Old May 29th, 2014, 10:25 PM   #4
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
could be that one of your pistons are not releasing.
TEAM ALFALFA
www.apexassassins.com
Old May 29th, 2014, 10:25 PM   #5
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Does it scrape with or without brakes being applied? Also, how long do you hear the scrape..like does it scrape the whole time it's spinning or at a certain frequency?
The Bike | The Truck
Old May 31st, 2014, 05:44 PM   #6
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
Probably just the pads rubbing on the rotor from the caliper being sticky and needing to be cleaned so the pistons slide back in after you release the brake lever.
Old May 31st, 2014, 06:29 PM   #7
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Yeah, like these guys are saying...
Is it a "scrape"? Or just a "rub"?
A little rub as the wheel spins can be OK, but a scrape is not.
If you or a buddy has a dial indicator and mounting setup, you could check runout on the disk.
Old June 1st, 2014, 03:39 PM   #8
agentbad
agentbad's Avatar
Pics of the brakes pads?
Old June 3rd, 2014, 06:13 PM   #9
Lllewis87
Motorcycle(s): 04 ninja 250
My rear brake was doing the same thing. I replaced the pads and it all went away. I'm guessing that when I pushed the piston back while changing the pad it freed it up. Good luck.
Lllewis87 is offline   Reply With Quote
front brake rotor NikRN06 2008 - 2012 Ninja 250R Tech Talk 16 August 20th, 2012 06:01 AM
WANTED: 08+ front brake rotor Jiggyfly Items Wanted 1 March 26th, 2012 08:02 PM
WTB: 08+ Front Brake Rotor chester3000 Items Wanted 0 February 6th, 2012 10:49 PM
Front Brake rotor fivepin 1986 - 2007 Ninja 250R Tech Talk 6 April 11th, 2010 04:33 PM
Rust on front brake rotor? M-Oorb 2008 - 2012 Ninja 250R Tech Talk 15 June 4th, 2009 11:30 AM
