Old June 13th, 2020, 10:28 AM   #1
Tsmith9233
Motorcycle(s): 03 ninja 250
Carb vacuum line question
I have an 03 machine with a 12 engine. I swapped the stock 03 carbs for stock 12 carbs. The 12 set has a tee and a second hose in the vacuum line that connects to petcock. I thought it might go to the nipple at rear of gas tank, but doesn’t reach. I assume I do not want a wild vacuum leak. Do I extend it to attach to tank or plug it off or???? Thanks in advance.
Tsmith9233 is offline   Reply With Quote
Old June 13th, 2020, 10:55 AM   #2
ducatiman
ducatiman's Avatar
plug it or eliminate the T entirely using continuous hose, petcock to LH carb vac nipple direct.
I surmise the T fitting arrangement was actually meant to run off the carb *vent system* not the *vacuum system* of the carb so its possible it was "piped" wrong by PO of the carbs. Yessir, a giant vacuum leak. I can hear him now...runs like crap..these 250's suck!
Verify the actual vent is clear to....ummm, vent. If hose present, no kinks or crimps! Free and clear 100%
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old June 13th, 2020, 11:20 AM   #3
Tsmith9233
I know I have a Frankenstein machine, probably take a while to get it sorted. Hopefully you all can assist along the way... will swap out that hose pronto.
Old June 13th, 2020, 12:36 PM   #4
Tsmith9233
Eliminated the T and put one piece hose from carb to petcock. Is there supposed to be a hose attached to nipple on tank? If so, from where does it come? What’s the other end attached to? Thanks again
Old June 13th, 2020, 01:00 PM   #5
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Found this in another post
https://faq.ninja250.org/wiki/Hose_r...ine_fuel_tanks
On the 49 state tank there's the one hose outlet (drain).
49 state models have only one hose coming from the rear of the fuel tank. This is a drain hose for fluid that gets in the depression between the filler neck and the top of the tank, from being in the rain or overfilling the tank. Air vents into these tanks
On the Cali tank there's 3 (L-R), with the middle apparently the drain.
The right tube allows air into the fuel tank through the gas cap as the gas level drops. This tube must remain open.
The middle tube is the drain and should keep the stock routing under the bike in the hose cluster (right-hand side of the frame, as discussed above).
The left tube circulates fumes to the emissions system and should be capped off.
Old June 13th, 2020, 03:10 PM   #6
Here's some pictures to double-check vacuum-hose routing. Many times, you may inherit incorrect routing from previous owners.
Not shown is vent-hose from centre of fuel-rail that should go backwards between carb-inlets at airbox and down to ground by rear-shock. Drain-hose from tank shoud also end up down there.
Last futzed with by DannoXYZ; June 13th, 2020 at 06:48 PM.
Old June 14th, 2020, 07:01 AM   #7
ducatiman
ducatiman's Avatar
In pic that open T between RH carb vac barb and decel valve must be eliminated if present in any non-Ca bike. Continuous hose preferred. In ANY application, it should never be left open.
I believe that T is piped to the Ca model canister.
Thankfully, only encountered 1 Ca model EX500 here many years ago, service access complicated by all the extra junk.
Hmmmm....REMOVE?
Custom Carb Service
Vacuum line RockMonsterTJ 2008 - 2012 Ninja 250R Tech Talk 1 March 26th, 2020 03:49 PM
06 Ninja - Carb vacuum leak... Dramier 1986 - 2007 Ninja 250R Tech Talk 13 August 24th, 2015 08:28 PM
Loose vacuum line. Major backfire. lockdun1 2008 - 2012 Ninja 250R Tech Talk 4 October 13th, 2014 01:33 PM
Gas and Vacuum line maintenance? ProdigyRacingLA 2008 - 2012 Ninja 250R Tech Talk 4 March 11th, 2014 10:16 PM
Fuel in Vacuum line headshrink 2008 - 2012 Ninja 250R Tech Talk 4 April 23rd, 2011 03:29 PM
