Old January 16th, 2023, 10:24 AM   #8521
MikeCL
Motorcycle(s): ‘04 EX250
Originally Posted by Bob KellyIII View Post
that's odd.... the choke lever direction on your bike is reversed compared with mine.... I push Up to turn on the choke.....down to turn it off
.... maybe because mine is a newer model... a 2012 maybe the older model
is reversed...i don't know.... these guys would know though
maybe that is part of the problem LOL
Bob....
Hmm maybe easy to bump into on the older models so they decided to change it?
MikeCL is offline   Reply With Quote
Old January 16th, 2023, 12:08 PM   #8522
MikeCL
I think I’m going to be doing the two bottle method for carb sync lol the rubber stopper is a tad too big will have to shave it down a bit, I have plenty of oil so that will have to do however it’s a bit thicker being that it’s out in the storage.
Probably won’t get to it until Wednesday however.
Old January 16th, 2023, 05:25 PM   #8523
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
I made my carb Sync tool from PVC pipe and just made 2 small containers for the oil in line to each carb just to catch the oil (just in case) those connect to a long loop to each other with the Auto transmition oil in it.... all hooked to a board about 5' long.... I hang that from the ceiling attach a line from the containers at the top to each carb's intake port and read the results on the oil level line down on the board.... it's extremally sensitive ... I used it on my XS650 yamaha and it worked great... haven't tried it on the Triumph or Ninja yet though.....
it's a simple, effective method to adjust and balance the carbs that will not allow the oil to be sucked into the engine. (as it will catch it in either container)
I think I posted a few pictures of it here but not sure... I know I did on the XS650.org forum.......that was about 5 years ago.
it really smoothes out an engine to have those carbs synced!
Bob........
Old January 17th, 2023, 08:35 AM   #8524
MikeCL
Bob........
I was going to do that and I think I’m going to go back to that method
Old January 17th, 2023, 10:47 AM   #8525
MikeCL
So how many have the Shinko SR741 how’s the feel? I assume what’s I’ve been hearing it’s a good all around tire?
I was playing the old videos before I did the valve adjustments and changed the plugs man the bike sounds so much better now as far as the cadence of the motor I expect even better when the carbs are synced and carbs cleaned.
Last futzed with by MikeCL; January 17th, 2023 at 04:46 PM.
Old January 18th, 2023, 01:17 PM   #8526
MikeCL
Running into a slight issue.. finally got the clutch cable on but I can’t seem to get the clutch to disengage even when pulling it has zero effect.
Lol never mind what I just said lol maybe I should just lower the rear wheel.
I do need to adjust the throttle on the carb a bit more I gain like 100 rpm’s if you move the handlebars to the right but I have a little too much slack I will check a bit more
File Type: jpg 65FBB9CB-C070-402D-BD25-04FC6E6F1B1C.jpg (103.8 KB, 4 views)
Last futzed with by MikeCL; January 18th, 2023 at 02:56 PM.
Old January 18th, 2023, 09:29 PM   #8527
Bob KellyIII
LOL.... the throttle cable is real easy to bind up when turning the handle bars
it has to be routed just right.... Keep at it you'll get it !
yah you'll have to pull the tank off to get at the cable under it ... I had to put mine outside of the steel loop holder to get it to stop pulling when I turned the handlebars all the way to the stop... the cable is so short it makes it hard to do
....but you can do it ! messing with the carbs won't help when the cable is being pulled get that right first then mess with the carbs.
LOL... having the rear wheel on the ground will really help in adjusting the clutch HAHAHAHAHA
Bob.....
Old January 19th, 2023, 04:44 PM   #8528
MikeCL
Yeah I only just unhooked the cables from the carb I didn’t take them fully out so with the extra freedom in the cables it might of always been around I just never noticed it.
And as for the clutch haha yeah.. my left footrest bracket finally snapped off which cracked durning my low side crash so I ordered a replacement I did ride around and got to check the clutch engagement which it was fine.
I’ll check the hoop I can’t remember if it in or not.. however I wanted to
Ask when the handlebars are turning fully to the right and hits the stop
Does anyone else’s front brake line get wedged between the bars and the frame? It’s not a lot but more of it doesn’t seem right.
Old January 19th, 2023, 09:32 PM   #8529
Bob KellyIII
that doesn't sound right either... brake line should never be able to be pinched !
I'll go look on mine in a bit and see how it is routed I'm fairly certain it goes in front of the fork not behind it.
Bob.......
Old January 20th, 2023, 09:12 AM   #8530
MikeCL
Bob.......
I was a bit focused on getting the clutch cable on I forgot to take a picture
Ordered some Rust 911 to remove the remaining rust in the tank I got like a month ago
Anyone know what size screws will fit the drilled out rivets on the muffler? I thought the self tapping screws I had would fit but they are a tad too small.
Last futzed with by MikeCL; January 20th, 2023 at 01:23 PM.
Old January 22nd, 2023, 12:34 PM   #8531
MikeCL
Carbs are synced
Old January 22nd, 2023, 01:18 PM   #8532
Bob KellyIII
were they very far off Mike ?
I remember my Brother in laws 305 scrambler was always out'a sync ! you could not keep them IN sync for love nor money so when you did Sync them it always made a big difference ! 5 minutes on that bike and your butt, hands and feet were all numb from the vibration and you had blury vision too !
it's 180 degree crank was the reason ... but it really hauled butt !
you could not compare his bike with mine.... even they both were 305cc's
my bike was a laid back cruiser and his was a rocket ! HAHAHAH
I gott'a get back to putting my Ninja back together but it's still too cold to work on it out there....so....it can wait ! HA !
Bob.....
Old January 22nd, 2023, 03:38 PM   #8533
MikeCL
Bob.....
Right away cyl 1 was filling the bottle right away almost to the point where the second bottle was almost empty.. I moved a little slow and the carbs ran out of fuel lol
The second go around was better.. it’s true it takes very little to adjust them I finally got it to a level where the level kept the same. I was happy with that
https://youtu.be/rJKfDQZ2fVY
The brake line part was easy I see the the little cut out for the hose the zip tie caused it to move
I test fitted the front fairing and the mirror mounts are going to be the hardest to get to move to the correct points on the fairing.
The rear tire only had 6 psi also the swing arm will have to be greased it does creak
File Type: jpg 3D91C70B-4E95-41CC-96F2-7127247D7B80.jpg (124.0 KB, 1 views)
File Type: jpg 682AF18B-AD62-40D9-9FF5-53D7EF2DE276.jpg (130.4 KB, 0 views)
File Type: jpg 626603CF-58B1-4866-A135-0DAD8CD984B5.jpg (104.9 KB, 1 views)
Old January 22nd, 2023, 07:46 PM   #8534
Bob KellyIII
lol sounds like your bike needs about 1/2 a can of WD-40 !
I would soak everything...including the seat and handle grips ...any rubber
any metal.... and then wipe it dry ...
I even use WD-40 to clean the windshield ! and seat.... the light oil is just what the seat needs to keep it soft and pliable.
side walls of the tires too... helps prevent cracking...
it really is FIX-IT in a can ! HAHAHAHA
....I wouldn't recommend that if I didn't do it.... and I do it 3 or 4 times a year !
Bob.....
Old January 23rd, 2023, 07:19 AM   #8535
Bob KellyIII
I just watched your video doing the Sync on the Ninja....
very interesting ! never seen a syncing tool like that.... OBVIOUSLY it works
but it is very slow reacting.... the one I made used the tube connecting the
bottles as the gauge and it was very long like 8' long or so...
but the principal is the same.... What ever works right !?!?!?
those bottles are actually perfect for it... LOL
I knew those frapachino bottles were good for something !!!! HA !
Keep after it ! but do it right your life depends on it !
Bob......
Old January 23rd, 2023, 12:39 PM   #8536
ducatiman
ducatiman's Avatar
FWIW- i perceive both cylinders fluctuating somewhat within the combustion process, as if the circuits were not totally clean or fuel flow was partially impeded. And suggest turning the idle speed down a bit.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old January 23rd, 2023, 07:51 PM   #8537
MikeCL
The choke was on just a bit I had the idle down low enough where it wont stall I ended up taking the bike down the street to help warm it up before I checked the carb sync it was fine without the choke but coming to a stop sign pretty much caused the bike to die.
Not sure how much riding would need to ride with zero choke on
Old January 23rd, 2023, 07:56 PM   #8538
MikeCL
Oh yeah if anyone has those flush mount turn signals anyone know what size nut goes on for the mounting studs?
Old January 23rd, 2023, 08:19 PM   #8539
Bob KellyIII
I think what Gordon is refuring to is the vibration in the water it did seem kind'a high to me as well but I don't know WHAT it should look like as I haven't done my Sync sense he re did my carbs for me....
if you know what it is supposed to look like you can tell by the fluctuations
that something is off.... so I would listen to Gordon .....
that probably means your pilot curcuits are getting all varnished up and that is why you need to run the choke alot.....
in most cases you should only need the choke to start it and then turn it off in a second or two ... not leave it on for a long time.... having to leave it on a long time tells you something is messed up !....Dirty carbs!
if it's not running like it first came off the show-room floor then something is amiss and needs to be fixed
I should know as Mine has yet to run like that.... it's always had a problem starting when it was cold and when I finally did the pilot circuit specifically
on the third try I did finally get it to run acceptably... but I could tell it still was not perfect. those carburetors are the hardest to clean I have ever encountered ! there is a picture that I went by to give me an idea of where to clean... if I can find it I will add it here...
it's a strange pilot circuit and difficult to clean!
Bob........
Old January 24th, 2023, 08:23 AM   #8540
ducatiman
ducatiman's Avatar
nitpicking here....the hose sizes chosen seemed to be to large, thus *any* leakage of air negating the entire synch process.
In any event, it seemed quite rough running.
Custom Carb Service
Old January 24th, 2023, 04:08 PM   #8541
MikeCL
That’s the hose size listed on ninja250.org
Anyways does my shifter look bent to you? I replaced the bracket today
File Type: jpg 5EA61D35-588A-4169-8D27-E774408C9A63.jpg (94.2 KB, 3 views)
File Type: jpg 107B2E48-C732-4B41-9F04-ADF79B8485B2.jpg (151.8 KB, 2 views)
Old January 27th, 2023, 02:26 AM   #8542
MikeCL
Worked pretty good
File Type: jpg B4E69AE9-50B1-4186-A18B-8B27B12A86D6.jpg (106.4 KB, 3 views)
File Type: jpg E858BB12-84EC-460E-8B15-0ED6D27D5C5C.jpg (39.4 KB, 6 views)
Old January 27th, 2023, 10:22 AM   #8543
Bob KellyIII
What's that Mike ? getting the rust out of the gas tank ???
how did you do that ?
Bob..........
Old January 27th, 2023, 10:27 AM   #8544
MikeCL
Bob..........
Gas tank I got from eBay about 2 months ago I used rust911 32 oz makes 4 gallons it was only $43 for 32 oz It was bay far the best route for me. I’m going to switch tanks today.
Old January 28th, 2023, 11:28 AM   #8545
MrB64
Motorcycle(s): R1,GT380,RGV 250,Ninja 250, Honda SS125
Replaced the blown tacho bulb, whole fairing had to come off to do that.
Lubed the speedo cable as recommended.
Found a suitable wavy washer in my collection to take out the worst of the free play on the clutch lever.
Replaced the air filter.
And finally cleaned it. Washed the engine down and the back of the fairings while they were off.
Took it for a run to dry it off, of course.
MrB64 is offline   Reply With Quote
Old January 30th, 2023, 04:34 PM   #8546
Bob KellyIII
Well yesterday I put the right front frame piece back on the ninja and then put the thermostat housing on it and hooked the back end to the tube on the head.
made sure the spark plugs were tight and put the sparkplug cap on the left plug and then started looking for the right coil.... couldn't see it so I was getting really cold by then and decided to give it up and go back inside and get warm !
the cold is hanging on like grim death this year.... it got all the way up to 50 deg. but then dropped back down to below freezing again for a week....
I'm hoping it will warm up next week !
Bob.....
Old January 30th, 2023, 05:02 PM   #8547
MikeCL
Taking a break now with the bike got two weeks to study for my CDL test lol talk about stressful
Old January 31st, 2023, 01:35 AM   #8548
Bob KellyIII
LOL by the time I finally got down to the DMV office to get my permit when I was a Kid I had that entire book memorized ....but the book is 3 times as big now !!!!! there are so many new laws in there now that I couldn't believe it !
and they DO TEST YOU ON THEM ALL so you have to know them
taking the drivers test was a breeze back then they just had me drive up and back in the parking lot and go through the gears... then do a TIGHT figure 8
and that was that..... I had practiced that figure 8 till I could do it at full lock in both directions.... and I passed easy he mentioned that most guys fail at that
and I told him I had been practicing for over a year ! I wanted my permit bad!
when I finally got my License there was no driven test as I had already done that for the permit but the written test was much harder indeed...
STUDY THAT BOOK real good ! its not as easy as you think it is !
some of the questions are ambiguous..... and you'll only know the right answer if you've studied that handbook inside and out !
.....and answer it like the handbook says... not in your words, in the books words.....
good luck !
Bob......
Old February 11th, 2023, 05:50 PM   #8549
MikeCL
I’m back! And I PASSED! Now a Class A holder!
Now time to return back to the bike lol I brought a replacement brake MC and perch the replacement has a broken switch but the switch should transfer over just fine.
The last thing I did before I stopped was installed the fuel tank but it looks like the screw on the left side is stuck and I’m not sure if I would be able to get it out.
File Type: jpg DF379ADD-01A4-484E-852D-82F34590A5F7.jpg (68.9 KB, 4 views)
File Type: jpg 145D94AD-32B3-484B-AE08-0301E77A86A5.jpg (74.1 KB, 3 views)
Old February 11th, 2023, 06:10 PM   #8550
Bob KellyIII
Congrats Mike !!!!! now don't Kill yourself.... Ride like they don't see you !
Bob.......
Old February 11th, 2023, 07:03 PM   #8551
MikeCL
Bob.......
Thanks! The biggest thing is to just take your time! Next up is working on getting the MC endorsement and getting the msf course booked!
Old February 11th, 2023, 08:02 PM   #8552
Bob KellyIII
When I took the endorsement test it was real easy they just had me drive up and back in their parking lot and then do a figure 8 in both directions ( the tighter the better) I stood on the pegs when I did mine I don't know if he took off for that or not but I did..... he was mainly looking to see if I had control or not I think. and sense I went to full lock on the figure 8 each way he knew I had control... that might be hard to do on a bigger bike as I was on a Honda 90 ! HAHAHAHAHAHA
so is a Motorcycle safty course Mandatory now ? there was talk here in California of them making that a requirement but I dunno if they did or not !
Old February 11th, 2023, 08:21 PM   #8553
MikeCL
If I looked at it right in CT it required to take the course at any of the approved locations as for the figure 8’s I could probably do that with enough space.
Next up is the tires, sprockets and chain.
Old February 11th, 2023, 08:56 PM   #8554
Bob KellyIII
thats just it.... they do not give you much space at all I had to go to complete lock just to stay in the traffic cones they set there it was very tight....
I'm quite tickled tonight I got the Ninja running again.... ! Finally !
....dunno if it's right yet but time will tell that story !
Bob.......
Old February 11th, 2023, 10:04 PM   #8555
NinjaPony
New rider
NinjaPony's Avatar
Motorcycle(s): 2021 Ninja 400 (abs), 2004 NinjaEx (2007 motor)
Washed her.
NinjaPony is offline   Reply With Quote
Old February 12th, 2023, 12:16 AM   #8556
Bob KellyIII
I did all kinds of stuff ! and I got her Running again !
and after I adjusted the airscrews a bit she is running alot better...
I think tomorrow I will adjust the idle airscrews to get the highest RPM and add a 1/4 turn and then start getting her ready for her first run in over 6 months !
man it's been a long winter here ! HAHAHAH...
I found out that the DMV STILL doesn't have Geico's insurance information on the Triumph....AGAIN..... they have it on all the newer bikes but not on the old 1977 Triumph .... I wonder why ? they are supposed to notify the DMV so they have it.... but they keep messing up on the triumph.... I guess I am going to have to call them because you can't find out anything on line.
.....OOOh well, that's how it goes ...first your money then your clothes !
And My Buddy in Bhutan , Tsheten. finally got his Hand guards for his new bike.... that should give him some challenges to get them on there right !
HAHAHAHA !
if everything goes right and the weather warms up I'll be riding before the months out ! WOOO HOOO !
Bob........
Old February 12th, 2023, 01:43 AM   #8557
MrB64
Bought a 2nd hand Scottoiler off ebay for it.
Had one on my R1 since I bought it in 2017, never replaced the chain and only adjusted it a couple of times in 15000 miles.
Old February 14th, 2023, 09:57 AM   #8558
MikeCL
I still need to do a little fairing fixing up.. maybe if the weather keeps being a little warmer.. it was hard to work with the fairing in low 30's and getting it to melt and stay.
Old February 14th, 2023, 10:15 AM   #8559
MikeCL
Hey I was wondering for those that ride in colder weather had bad does carb icing happen on these bikes?
Old February 26th, 2023, 02:10 PM   #8560
MrB64
Washed the bike again today, did the routine checks; oil, water, brake fluid, tyre pressures.
Found the rear down at 11psi, culprit was this,
Ordered a repair kit as I couldn't find my own and ordered a new tyre. Annoying because the tyre is in good condition.
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
