November 6th, 2010, 05:42 PM | #1 |
Join Date: Nov 2010 Motorcycle(s): 2009 Ninja 250R Posts: 194
Small issue with ignition
So, today i noticed my key was being a pain to get in and out. I took a closer look and looks as though the left metal piece is bent a little. Not sure how it became like this but anyone know a fix or if i should take it back to the dealer. seeing as i just bought the bike 3 days ago...
I hate when little things like this happen.... just ruins my day. Picture |
November 6th, 2010, 05:54 PM | #2 |
noob motovlogger
Join Date: Dec 2009 Motorcycle(s): Black 2009 250r Posts: 328
That bent bit is normal. I believe it's there to help guide the key in. Generally you need to wiggle the handlebars a bit when you insert and remove the key though much like jiggling the steering wheel on a car.
My Motovlog "Damn, either shimming the needles fixes 90% of any problems with the 250Rs, or kkim owns stock in a washer manufacturer." -DmbShn41 |
November 6th, 2010, 06:22 PM | #3 |
Join Date: May 2010 Motorcycle(s): 09' Ninja 250 Posts: 17
to my knowledge, that indent is there in almost all ignitions. I always assumed it's purpose is so that the tip of the key can get under the tiny metal door and slide it back... allowing the key into the keyway. I don't think anything is wrong with your bike. Try taking a few minutes to fiddle with your key and the ignition and you'll probably find a better angle / technique to get the key in and out process a bit more smooth!
EDIT: Same as above for the most part, I didn't refresh the page before I replied : / |
November 6th, 2010, 06:34 PM | #4 |
Thanks guys.
November 6th, 2010, 06:44 PM | #5 |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
kevlarorc has it right. I find that the key doesn't go in that easy if the bike is turned to its steering lock so I just move the handle bars a bit and it slides right in. Same thing for taking it out
09 ninja 2fiddy SE Driving slow things fast |
Sequential LED Tail Light small issue | ez12a | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 5th, 2015 05:46 PM |
[motorcyclenews.com - news] - Small bikes for a small budget | Ninjette Newsbot | Motorcycling News | 0 | August 30th, 2013 09:40 AM |
[motorcyclenews.com - news] - Small bikes for a small budget | Ninjette Newsbot | Motorcycling News | 0 | August 30th, 2013 02:40 AM |
wanting to move up to a 600cc sport bike, but i have a small issue... | Jordan91 | General Motorcycling Discussion | 37 | December 29th, 2012 07:39 PM |
[nytimes.com] - For Motorbike Dealer, There Are No Small Parts, Only Small Plans | Ninjette Newsbot | Motorcycling News | 0 | November 12th, 2008 11:58 PM |
