Old April 16th, 2013, 03:00 AM   #1
psych0hans
psych0hans's Avatar
DIY for installing race fairing?
Hi guys, is there any DIY guide for installing race fairing on the Ninjette? I'm trying to install my airtech race tail, but it just doesn't seem to want to go on there. Is there any special way of doing this? I don't want to use too much force as I'm afraid of breaking it.
Old April 16th, 2013, 05:29 AM   #2
I will make one if needed but it's really simple. The tail fairing loves to hang up on the undertail plastics. So slide it on till it stops and then look under, you should see where it's hanging up.
Get a dremel, makes the install and custom fitting a snap. You're most likely gunna need it for trimming around the kickstand mounting tab if you still have it.
Old April 16th, 2013, 05:40 AM   #3
psych0hans
psych0hans's Avatar
Thanks for your reply Chris, I finally did manage to get it on after a lot of pushing and shoving. Now I'll have to take it off again to drill the holes. How many holes did you make in your tail section? I only have a tail section, so I won't be installing anything else.
Old April 16th, 2013, 05:53 AM   #4
I have hotbodies, which is slightly different than yours. From the picture, it looks like yours will only need the 2 lower holes near the rear shock (one each side).
Old April 16th, 2013, 05:56 AM   #5
Here on both sides.
Old April 16th, 2013, 07:40 AM   #6
sierrahotel
CVMA #92
Motorcycle(s): harleys
I also run a ziptie through one of those two grommeted forward holes into the chassis. There's a non-theaded bolt hole on the chassis that lines up. You can get a little more creative and bolt it if you are willing to do a little fab work with tabs.
Not really required, but since I don't have a kickstand every bit of tail fairing rigidity helps as I balance the bike with 1 hand on the tail doing the rearstand dance.
sierrahotel is offline   Reply With Quote
DIY - Installing a ZX-6R Master Cylinder VeX 2008 - 2012 Ninja 250R Tech Talk 33 August 27th, 2018 11:30 AM
DIY: Installing Spy 5000m Alarm jeanca223 2008 - 2012 Ninja 250R Tech Talk 8 May 17th, 2017 03:33 PM
Searching for a DIY thread on installing header kael0206 2008 - 2012 Ninja 250R Tech Talk 1 June 15th, 2011 02:07 PM
DIY- Installing Footpeg Extenders kkim 2008 - 2012 Ninja 250R Tech Talk 78 November 20th, 2010 09:58 PM
DIY: Installing Halos tlhamon 2008 - 2012 Ninja 250R Tech Talk 26 October 27th, 2010 08:40 PM
