Old June 7th, 2021, 09:27 AM   #1
Sandr
09 250R possible vacuum Leak?
I lived in NY so 8 months of the year the bike was in the garage covered up. only has 9k miles on it, driven very lightly.
My 09 Ninja 250r Idles great when the choke is on. When i press the accelerator 10-15% the rpms drop until the bike stalls. At first i thought it was a dirty carb so i dissassembled it several times cleaned and put them back in. Same issue.
There is no fuel leak, but i suspect there is a vaccume leak, maybe an O ring between the carbs. not sure. Has anyone had this problem? Is there a Vaccume hose diagram anywhere? just so i now what to troubleshoot.
Sandr is offline   Reply With Quote
Old June 7th, 2021, 10:28 AM   #2
It's almost certainly a carburetor passage or passages that you didn't get clean. These carbs are famous for that... they look clean, but somewhere where you can't see it, they're not clean.
I've always done my own carb work, but when my 250 started acting up I sent the carbs to Ducatiman here on the board, and he brought them up to like-new spec.
Last futzed with by Triple Jim; June 8th, 2021 at 02:51 PM.
Old July 14th, 2021, 05:02 PM   #3
Sandr
Problem solved! all the symptoms Said, "clean the carbs" after a TON of cleaning and no progress. I finally checked one o the hoses. The hose was loose. maybe a little worn out. after replacing the bike runs like new!
Old July 14th, 2021, 05:31 PM   #4
ducatiman
ducatiman's Avatar
specific location of leaking hose?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old July 15th, 2021, 08:15 AM   #5
bigBug
Especially the fuel passages.
bigBug is offline   Reply With Quote
Old July 19th, 2021, 01:11 PM   #6
Sandr
FIX:The circled hose was ever so slightly stretched out and would not fit snug, even with better hose clamps on it. I swapped out the hose with a 1mm smaller one to guarantee it fits and put on new hose clamps for insurance and it fixed my problem.
The bike is a little jumpy at low speeds, but on Highway speed it runs perfectly. i suspect a minor tuning is in order
Photo: https://imgur.com/a/2H4iZ9E
Guess I Had a Vacuum Leak in the Petcock VaFish 1986 - 2007 Ninja 250R Tech Talk 18 November 16th, 2015 01:55 PM
06 Ninja - Carb vacuum leak... Dramier 1986 - 2007 Ninja 250R Tech Talk 13 August 24th, 2015 08:28 PM
Vacuum leak maybe? iflylow 1986 - 2007 Ninja 250R Tech Talk 4 February 24th, 2014 01:47 PM
Vacuum hose cross caused leak Quick1 1986 - 2007 Ninja 250R Tech Talk 9 December 23rd, 2013 03:19 PM
2007 won't idle. Vacuum leak or something else? cookiebug79 1986 - 2007 Ninja 250R Tech Talk 23 September 30th, 2013 09:28 AM
