August 19th, 2009, 08:53 PM | #1 |
Join Date: Jul 2009 Motorcycle(s): F650GS Dakar, FJR1300, Ninja 250R Posts: 47
Fastener Torque Specs
Hey All!
Hoping to get a group effort involved towards updating a skeleton page just created on the Wiki. I know, I know... borrible formatting but it's a start! If you know torque specification on various nuts and bolts on the Ninjette, or simply want to go in a clean it up, update the wiki page! http://www.ninjette.org/wiki/Fastene...Specifications Those without shop manuals will greatly benefit! Cheers! |
August 20th, 2009, 03:25 PM | #2 |
Hi Mr. Finder - take a look at it again and see if that's what you were wanting... if not, I can make changes
August 20th, 2009, 08:19 PM | #3 |
August 21st, 2009, 09:26 PM | #4 |
Wow, fantastic list there Kim!
August 23rd, 2009, 07:34 PM | #5 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
im confused, you have FT.LBS listed on some things (bold top listings)
but right under it says IN.LBS ... so which is it? or what is IN.LBS = FT.LBS? I need a IN.LBS torque wrench too now? Torque N*M | kgf*M | ft*lb ____________________ |>>>>>>>>>| 87in*lb |
August 23rd, 2009, 07:42 PM | #6 |
Join Date: Dec 2008 Motorcycle(s): ninja 250r Posts: 371
you do not need to buy a new tq wrench as 1 ftlbs =12 inlbs so if your tq is120 inlbs thats 10 ftlbs
08 250R: sportisi VR full exhaust, Dynojet, custom seat, kleen air rmvd, rim tape, grips, fender chop,zg db windscreen,k&n air filter,15t front sprocket,sportisi-usa clipons,solo seat cowl |
August 23rd, 2009, 08:14 PM | #7 |
If you're looking at the ft.lbs column and it says in.lbs next to it, it's in in.lbs. If it doesn't say anything and is just a number, then it's in ft.lbs.
August 28th, 2009, 07:58 PM | #8 |
torque for the Shift Lever Link Bolt?
Engine Sprocket Cover Bolts are 87 in.lb (7.25 ft.lb) but what about thee Above part? wait i think its 104 in.lb (8.6 ft.lb)? also Shift Pedal Mounting Bolt (18 ft.lb) thats the hex bolt that ppl bitch about coming lose or off and using blue locktite on? Im asking cuz soon (weather is nice enuff) im gonna take off teh front sprocket cover, to be able to Clean all the grim/junk off! and inspect the front sprocket for wear! |
torque | skip | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 22nd, 2014 02:55 PM |
Engine torque specs | Phillip2002 | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 14th, 2013 04:40 AM |
clutch lever pivot bolt/nut torque specs | Confuzshuz | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 25th, 2012 05:11 AM |
Torque Wrench | JLinde1339 | 1986 - 2007 Ninja 250R Tech Talk | 16 | September 18th, 2011 05:40 PM |
suspension torque specs | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 18th, 2011 12:03 PM |
