Old May 13th, 2014, 08:11 AM   #1
verboten1
verboten1's Avatar
MOTM - June '15
Michelin Pilot Street, any experience with good pressures?
I know the pressures I run on my KLR, but I have no clue what kind of pressures people run on sticky tires.
without even thinking I would probably go 26/28
but what should I run? 275 pound rider, slightly lightened bike (it needs fairings lol)
Thanks for any input you may have!
Ride more, worry less.
Old May 13th, 2014, 12:13 PM   #2
I'd start significantly higher for the street. (32F/36R) But adjust to taste. It can go several PSI higher or lower from that without getting into the unsafe areas, so it comes down to optimizing steering feel and wear patterns.
Old May 13th, 2014, 12:22 PM   #3
what he said
Old May 13th, 2014, 12:44 PM   #4
verboten1
verboten1's Avatar
MOTM - June '15
Thanks guys, I knew you would have the answer!
Now if only it would quit raining!
Old May 13th, 2014, 01:09 PM   #5
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
believe me, these tires grip amazingly in the rain.
Old May 13th, 2014, 01:16 PM   #6
kennetht
kennetht's Avatar
is there a certain pressure (besides the recommend pressure) to have the tires constantly at to increase their longevity?
kennetht is offline   Reply With Quote
Old May 13th, 2014, 01:51 PM   #7
verboten1
verboten1's Avatar
MOTM - June '15
Haha, yeah, but I need to get everything ready to get down to TN tomorrow!
Old May 13th, 2014, 02:46 PM   #8
Generally, the higher pressure you run, the better the longetivity. But - if you go way too high, it can actually start making it a bit worse and causing a flat spot a bit quicker, as the tire won't deform at all and will just wear that exact center down no matter what's going on at the time.
Old May 13th, 2014, 02:55 PM   #9
verboten1
verboten1's Avatar
MOTM - June '15
Well, I rode it about 150 feet, it felt way different, the front is lowered a touch, so it was already quick. But wow, this will be fun!
Old May 14th, 2014, 08:32 AM   #10
kennetht
kennetht's Avatar
i guess I should check my pressures then. I havent checked them since I got the tires installed. I am sure they are no longer at the higher pressures.
Old May 14th, 2014, 10:04 PM   #11
tubarney
I've run as low as 8 psi in the rear.
25-35 psi for commuting
15-25 psi for the twisties.
The lower pressure you go:
The less miles you will get.
Your turn in will get worse (tire will become 'flat')
Your contact patch will be the largest, hence most grip more wear.
Less air, more contact patch - tire heats up quicker
Suspension may need re-adjusting
Old May 15th, 2014, 03:52 AM   #12
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
******WARNING TO AUSTRALIANS******
Went to buy some street pilots this week in Ozzie Land.
Guess what
They don't meet Australian Standards.
So there is a few container loads of Michelin tyres ready for scrap.
ninja250r81 is offline   Reply With Quote
Old May 15th, 2014, 08:42 AM   #13
Que? What does that mean, are they mislabeled in some way?
Old May 16th, 2014, 05:39 PM   #14
ninja250r81
Some sidewall failure's, construction failure.
Not one tyre lasted through the testing period.
But, Michellin are said to be working on the problem's
Old June 2nd, 2014, 12:29 PM   #15
roc0487
Motorcycle(s): 08 250
What's up guys?
New to the forum, ran a search and came upon this thread... any definitive answers on recommended psi for these tires? I just got off the phone with Michelin and I'm waiting for their return call. Last weekend, I was checking pressures and my gauge failed... put a bit of air back into the front and on the ride the front felt shakey, haven't rode since.
Someone mentioned (can't refer to the member) that it was 32/36 I believe?
Any help appreciated.
roc0487 is offline   Reply With Quote
Old June 2nd, 2014, 01:00 PM   #16
kennetht
kennetht's Avatar
Originally Posted by roc0487 View Post
What's up guys?
ive been running mine at 32F/36R and find it to be perfect.
Old June 2nd, 2014, 01:59 PM   #17
roc0487
Just checked them, 32F/36R... man were they off. No wonder the ride was sketchy. Thanks Ken
Old June 2nd, 2014, 02:03 PM   #18
Welcome Mike!
Old June 2nd, 2014, 02:11 PM   #19
verboten1
verboten1's Avatar
MOTM - June '15
32/36 was awesome for me!
Old June 2nd, 2014, 02:14 PM   #20
roc0487
Thanks C! I'm glad to be here. I was curious after reading a few other posts... I am only about 130lbs, should I decrease by a few psi?
When I checked the pressures with my new gauge (slime) about 3 times a piece to make sure the gauge is consistent... I got 22F 24R, the last ride was very shady... now I know why. Now we're 32F 36R!
Old June 2nd, 2014, 02:21 PM   #21
Your tire pressures will be a personal thing. Now that you know the ballpark numbers, play with them a bit until you find what you like. @130lbs you should be able to find a happy place between tire pressure and rear preload adjustment. Are you gunna be 10lbs lower than everyone else? Most likely not.
Old June 2nd, 2014, 02:27 PM   #22
roc0487
I appreciate the input, I'll see what happens in the morning on my way to work. I assume the wobble or wander in the front comes from low psi, if they are too hard... the ride will be hard also? Afterwards I'll take a couple psi from each if need be, I would rather be on the upside judging from the scare the other day.
Thanks again guys
Pilot Street Radial from Michelin - Review afelotreyu 2008 - 2012 Ninja 250R Tech Talk 22 September 5th, 2016 05:18 PM
Michelin Pilot Street Radial rear tire review rojoracing53 General Motorcycling Discussion 182 August 2nd, 2016 12:19 PM
Michelin pilot street radials - bought em Bob2010 2008 - 2012 Ninja 250R Tech Talk 73 February 3rd, 2015 07:59 AM
New Michelin Pilot Street for the Ninja 250/300 Boom King General Motorcycling Discussion 87 May 28th, 2014 03:30 AM
New Tires: Rosso II or Michelin Pilot Street kdogg2077 2008 - 2012 Ninja 250R Tech Talk 43 February 25th, 2014 05:53 PM
