Old January 21st, 2013, 08:38 PM   #1
shelei09
Motorcycle(s): 2010 Kawasaki Ninja 250r
Question Sprockets, sprockets, ahhh sprockets?!?!
I have been looking into upgrading the sprockets on my bike (2010 Ninja 250r) I have found from most posts that 15t for front is most recommended and 42/43 for the rear...
My question is with a rear tire size (continental 150/70/ZR 17) is a 42 or 43 tooth better for the rear?!
On the same note as sprockets, I have a solid Alpine white bike and want to find hot pink under glow lights but am wondering if it is possible to paint my steel sprockets hot pink to match?
shelei09 is offline   Reply With Quote
Old January 21st, 2013, 09:00 PM   #2
For a bigger tire though I would do a 43t. But honestly 42 or 43 will not matter that much in the end.
And yea, you can have them powder coated any color you want. Just mask off the teeth so those are not painted and your good to go.
Old January 21st, 2013, 09:12 PM   #3
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
I'm running the same rear tire and I have a 15-42 right now. Ill probably go to a 41 for my next sprocket in 10k miles.
Old January 22nd, 2013, 06:49 AM   #4
Why 41? I also run 15/42 but feel 41 would be a bit much for me.
Old January 22nd, 2013, 06:51 AM   #5
Still to much shifting for ya?
Old January 22nd, 2013, 06:57 AM   #6
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Because it still has plenty of power on the flats and for those long sections of hwy it'd be nice to get the rmps a little lower when I'm doing 80mph. Plus
It'd also be cool to get my speedo to read exactly 1% of my rmps in sixth gear. I think to get the 1% thing I'd need a 40 but ill try a 41 first.
I do plenty of canyon riding and have never felt my gearing was to tall, hell I did the first two races at chuckwalla last year with the 42 still on it and just used 4th gear
Old January 22nd, 2013, 07:05 AM   #7
Ah, I see. The many hills of KY make me feel the way I do. I have never slapped on a 40 or 41. But I do run Putnam Park with 15/42. I feel it's the best gearing for that track for me. 4th gear WOT the only shift points are for the bus stop and straights.
Old January 22nd, 2013, 07:34 AM   #8
shelei09
Thanks for the responses!
Ok thanks for all the input and quick response... My next question would be about the chain.. My bike does not have the center stand and I feel my chain is rather lose.
When I get my new sprockets put on what should my chain be? I saw some places were saying with a bigger tire it should be about 2"?
Suggestions?
Old January 22nd, 2013, 07:59 AM   #9
0.8" - 1.2" are the specs for chain slack but I like a little tiny bit more on mine. Size of the tire means nothing in relation to chain slack. It's all about the suspension travel (less with a taller profile tire) and chain wear (tight spots, loose spots).
See here
Old January 22nd, 2013, 08:49 AM   #10
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
What csmith12 said
Tires and sprockets don't change how much chain slack you should have. But if you do change sprocket sizes you can expect to make a much bigger adjustment to your rear axle to get the chain back within spec. You should also be good with the stock chain length even with a 14-42 so you don't have to shorten your chain.
Old January 23rd, 2013, 09:47 PM   #11
Had to take out a couple links for 15:38. I would say that it was too far for most people and was too far for me when I drove cross-country, but it was fine around town. I switched back to 15:41 after the trip.
sprockets jcsalazar 2008 - 2012 Ninja 250R Tech Talk 10 July 29th, 2013 03:57 PM
New sprockets min nin 1986 - 2007 Ninja 250R Tech Talk 21 May 28th, 2013 07:48 AM
Where to get sprockets? Graugaard 2008 - 2012 Ninja 250R Tech Talk 8 February 21st, 2013 07:38 PM
how do my sprockets look reaperw 2008 - 2012 Ninja 250R Tech Talk 4 December 29th, 2011 10:20 AM
Sprockets again voodoomaster 1986 - 2007 Ninja 250R Farkles 13 April 8th, 2010 11:08 AM
