Old August 25th, 2013, 04:10 PM   #1
ninja_thresh_hold
ninjette.org *********
ninja_thresh_hold's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250r (忍者 250r; sold!) 2001 zx6r
zx6r issues
hey guys, i have an 01 zx6r with a yoshimura rs3 full exhaust, dynojet kit, and k&n air filter. completely stock other than that. when i got the bike, it misfired at 6k+ rpm, and the starter turned over slow every now and then, so i replaced the battery.(no change) and then i also replaced the spark plugs, and that made it run perfectly for 2 days, and then it started missing again, and now it has gotten worse to the point that it will misfire and wont accelerate no matter how far i pull the throttle. i thought it could be the ram air ducts becasue it didnt have clamps on it where it goes to the air box, so i put some on, and pulled the coils, and tested them for resistance and got 2 ohms on all 4. put it all back together, and it didnt fix anything. is it possible that with no clamps on the ram air duct it caused it to run rich and fouled the plugs again, or could it be that the cdi is going bad? im tired of breaking down, and last night i had to leave the bike in a bad part of town:/ any ideas?
ninja_thresh_hold is offline   Reply With Quote
Old August 25th, 2013, 06:42 PM   #2
ninja_thresh_hold
bump
Old August 25th, 2013, 06:43 PM   #3
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
take a pic of the plugs for us
Old August 25th, 2013, 07:06 PM   #4
are the new plugs fouled?
Old August 25th, 2013, 07:26 PM   #5
Don't think it is the CDI yet, did you check both primary and secondary of the coil?
Old August 26th, 2013, 09:45 AM   #6
ninja_thresh_hold
Sorry, what do you mean by that?
Old August 26th, 2013, 10:53 AM   #7
Well, there are 2 wires going into the coil and one going out (to plug). I assume you tested the 2 inputs, what about the output (plug side)? You should get somewhere around 14k-20k ohms.
Old August 26th, 2013, 10:56 AM   #8
ninja_thresh_hold
Yes I tested the 2 inputs. How would I test the output to the plugs?
Old August 26th, 2013, 11:02 AM   #9
Old August 26th, 2013, 09:57 PM   #10
ninja_thresh_hold
cylinder 1: primary (wire side)-1.6 ohm | secondary(plug side):8.70 ohm
cylinder 2: primary (wire side)-1.6 ohm | secondary(plug side):9.98 ohm
cylinder 3: primary (wire side)-1.6 ohm | secondary(plug side):9.85 ohm
cylinder 1: primary (wire side)-1.6 ohm | secondary(plug side):9.86 ohm
Old August 27th, 2013, 01:19 PM   #11
ninja_thresh_hold
I don't know at the moment, I have it all torn down but I haven't pulled the plugs yet.
Old August 27th, 2013, 07:46 PM   #12
ninja_thresh_hold
just for future reference in case anyone needs the specs of the coils on a 2000-2002 zx6r/2005-2008 zzr600
Stick Coil:Primary Winding Resistance 1.2 ∼ 1.6 Ω
Secondary Winding Resistance 8.5 ∼ 11.5 kΩ
Old August 27th, 2013, 09:29 PM   #13
KawiKid860
KawiKid860's Avatar
You should pull the plugs before doing anything seriously really, that will give you a pretty good idea of state of tune. What about your carbs? You have 4 complex high performance carburetors there's a lot of ways they could get clogged up or something.
Old August 30th, 2013, 05:56 AM   #14
Asspire
Asspire's Avatar
Several issues The_big_dill 1986 - 2007 Ninja 250R Tech Talk 21 June 12th, 2013 10:16 AM
Some issues The_big_dill 1986 - 2007 Ninja 250R Tech Talk 12 May 21st, 2013 04:59 AM
Still Having Issues! Achilles 2008 - 2012 Ninja 250R Tech Talk 11 March 3rd, 2013 10:26 AM
valve issues chevykrazy 1986 - 2007 Ninja 250R Tech Talk 6 July 7th, 2010 06:45 AM
I was having issues... Apex General Motorcycling Discussion 24 February 6th, 2010 05:21 PM
