June 6th, 2014, 08:09 AM | #1 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
250 vs 300 on track
Has any one gone head to head on a 250 against a 300? I seemed to have no problem overtaking a 300 down the straight at Blackhawk Farms a couple of weeks ago. My bike 28.6 hp his piped and tuned (his claim). Thinking I was getting better drive onto the straight I would back off then catch up and pass.
June 6th, 2014, 08:12 AM | #2 |
it's all about getting good drive into the corner. they are indeed faster than a 250. maybe the one you were playing with had issues
June 6th, 2014, 08:19 AM | #3 |
There is a slight advantage to the 300 on corner exit but nothing that rider skill cannot overcome. I also feel the draft bubble the 300 creates is larger. On a large straight, a 300 should pull on the 250 but other factors still are in play. Rider weight, tuck bla bla bla...
June 6th, 2014, 08:23 AM | #4 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Possible he wasn't wot?
June 6th, 2014, 08:26 AM | #5 |
a fully pepped up 250 is faster than stock 300 though.
June 6th, 2014, 12:37 PM | #6 | |
dirty boy
MOTM - Apr '14
you done any weight reduction to the 250? or yourself? I forget what it is something close to 20lbs is comparable to 2hp swing when looking at power:weight ratio hmmm...i need to quit modding my bike and go on a diet
June 6th, 2014, 12:58 PM | #7 |
Join Date: May 2014 Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F Posts: 588
That's what I did. I dropped from 170 to 155 lb in the last 7 months. Might stay at 155, but I think I can get to 150. It gets harder as I get older, though.
June 6th, 2014, 02:21 PM | #8 |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
Check out some of the Super Bike Brasil Videos. They run the 300 and the 250 together. The leaders are always 300s.
CVMA #55 |
June 6th, 2014, 07:36 PM | #9 |
I own a 2013 Interim model 250 that was sold here in Asia for the first few months of 2013
It is for all intents & purpose the 300 less the parts that increase the stroke 7.8mm or 5/16th inch & the slipper clutch along with the 250 having 28mm throttle bodies vs the 300's 32mm bodies I was expecting when the 300's came to see a huge diff but in reality they are quite close But this again is the 2013 FI 250 |
June 6th, 2014, 07:51 PM | #10 |
Maybe you're just a better rider than the 250 rider you chased down. Ever consider that?
June 6th, 2014, 11:19 PM | #11 |
The A Team
Join Date: Aug 2012 Motorcycle(s): Z50, CB125, RZ500, MC22, R3. Posts: 394
Its not about the bike. (until riders get to lap record pace)
June 7th, 2014, 08:58 AM | #12 |
Im an old guy, weight is hard to loose. I sit right at 180-185 and 6 feet tall so I'm not out of shape. if I drop any more I feel like crap. I keep removing weight on the bike every chance I get.
June 7th, 2014, 10:09 AM | #13 |
He was on the 300. And yes I am The thing is I would let him get the run down the straight, just to make sure it wasnt because I got a better drive off the corner, then accelerate and pass him.
June 24th, 2014, 12:16 PM | #14 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
First of all, taking my 300 on the track last February only deepened my love for that nimble little bike! It felt so much smoother in corners than my 250 ever did, even on BT-45 street tires. I didn't have to shift as frequently and didn't have a single bogging incident that used to occasionally plague me on the 250 (especially in unfamiliar corners). The 300 falls into corners just as easily as the 250 but has enough power in the lower-RPM range (around 5k) to pull through with no incident. I used to feel if I wasn't around 8k on the 250, there just wasn't the power I craved to pull me through the corner.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
June 24th, 2014, 01:01 PM | #15 |
Join Date: Jan 2014 Motorcycle(s): SC28 Fireblade Posts: 463
Stock for stock the 300 will pull away on the 250 off the line.However, a pumped up 250 is a different story. I remember running against a 300 of the line a while back, the guy on the 300 was a bit heavier than me. I was about 155 and the other guy must have been 170+, we were about dead even until about the end of the second gear. I was getting ahead little by little nothing fancy. But at the end of the day, I will always pick the 300 over the 250.Why? because it may not be by much, but the 300 is better in every way. I can't wait till Kawi comes out with the new 500R, now that is something to think about.
94 900RR 04 BMW Z4 2.5 M Package 01 R170 AMG Sport Package Last futzed with by BoBO; June 24th, 2014 at 03:05 PM. |
June 24th, 2014, 05:57 PM | #16 | |
Board Member
Perfect 250, 300 track? | JohnnyBravo | Ninjettes At Speed | 92 | August 22nd, 2016 05:57 PM |
250 vs 300 on track | ally99 | Ninjettes At Speed | 2 | February 11th, 2014 12:36 PM |
