April 3rd, 2015, 05:08 PM | #1 |
I go fast
Join Date: Apr 2015 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 2
Idleing too high and slow acceleration problem
So I have a 2008 ninja 250 (duh) but my bike has almost 50,000 miles on it. It has a K&N air intake, a two brothers carbon slip on. The bike seems to be idling weird. I set the idle after warm-up to about 1250rpms. But when riding it idles up above 3,000-4,000. Only sometimes though. Sometimes it doesn't. I have the air filter in and the slip on installed but I don't believe it's tuned with them on. So is that the issue. And will this problem of it not being tuned make me get bad gas mileage? I drove 1,380 miles straight from california to texas. And my average gas mileage was 45mpg. Which is pretty bad for a 250 if you ask me. That's cruizing at around 80-85mph. With being all freeway riding I was expecting at least 65mpg.
April 3rd, 2015, 05:20 PM | #2 |
Welcome Zack!
Actually... in nearly stock form, that don't sound too far off mgp wise. 45mph @80mph is near the top end of the bike's abilities, that is NOT where the mpg shines. Your gunna have to slow down a bit or do some mods to see higher mpg @ higher mph. As far as your high idle and such. My guess is.. The bike is slightly lean in stock form and that was made worse by the filter and slip on. It aint much, but it can be enough. Pull a plug and see what it looks like. Has it been sitting for the off season? Since I would suspect your gunna be in the carbs doing some jetting/shimming anyway, might as well give em a good cleaning while you're there.
April 3rd, 2015, 05:26 PM | #3 | |
I go fast
So I'm riding back to California tomorrow. What is the best speed for the best gas mileage? 65mph? And also, I replaced the spark plugs right before I left and it seemed like one looked a bit lean but nothing crazy. But I should tune it anyhow? |
Giving up the slow bike for a slow car | CycleCam303 | Off-Topic | 17 | February 18th, 2014 02:13 AM |
Slow acceleration sleep after 40mph | jackliu239 | 1986 - 2007 Ninja 250R Tech Talk | 47 | August 29th, 2013 07:48 PM |
Slow throttle response and slow return to idle help | Crriiissss | 1986 - 2007 Ninja 250R Tech Talk | 22 | August 7th, 2013 12:26 AM |
Casey Stoner High-Side Crash MotoGP 2012 Indianapolis (Slow motion) | Motofool | Videos | 2 | September 2nd, 2012 07:01 AM |
Weird problem occured today at high speed. | Joe83420 | 2008 - 2012 Ninja 250R Tech Talk | 4 | July 3rd, 2010 09:11 AM |
