Old August 5th, 2013, 02:53 PM   #1
Rollingmenace
Motorcycle(s): 96 Ninja 250EX , 87 CBR 1000, 86 TRX 260R, 86 KXT 250, 84 ATC 200X, 82 ATC 250R (w/CR480)
Highway speed in relation to rpm..
Just had a few questions relating to rpm's at highway speed..
Just put a new used motor in the ninja and took it for it's first long trip more than just around town... Almost 300 miles round trip...
Cruising on highway speedo said 75 mph I'm guessing it was more like 65 mph actual 75 speedo equals out to about 8700-9000 rpm and 80 is just under 9500.. Do those numbers sound about right.. Is it recommended to cruise at or above 9000rpm or should I look into possibly a front sprocket change to get the numbers down... I'm just concerned with the long term affects of running at 9000 rpm or over for a prolonged period of time
Rollingmenace is offline   Reply With Quote
Old August 5th, 2013, 03:13 PM   #2
Sounds about right and nothing wrong with riding for hours at high RPMs. The lil bike loves da rrrrrrr's. Just keep the oil changed and full and ride on. A 15t front and 44/42 rear should make it much more mild.
Old August 5th, 2013, 03:21 PM   #3
tc.young
Motorcycle(s): '89 klr 650, '00 250r
yup sounds right, i have the stock rear and +1 cs, i think 75mph indicated is about 8500 rpm. gps said it's 71 though.
if your unsure check here
http://faq.ninja250.org/speed/
tc.young is offline   Reply With Quote
Old August 5th, 2013, 04:10 PM   #4
Sipper'
Motorcycle(s): 250 Ninja
With the Pirelli MT75's and 15/39 gearing, my 04 indicates 7500 rpm at 75 mph.
Sipper' is offline   Reply With Quote
Best RPM range at speed... robski11500 Riding Skills 9 December 11th, 2015 11:44 AM
What is the AVG speed you do on the Highway reroka General Motorcycling Discussion 45 June 11th, 2014 05:41 AM
Speed/RPM NicoleH28 Riding Skills 62 July 30th, 2013 07:40 AM
RPM-Speed ratio; Update. blink General Motorcycling Discussion 19 January 29th, 2013 05:48 PM
RPM's on highway-a little high? fiberoptx 1986 - 2007 Ninja 250R Tech Talk 1 September 11th, 2009 08:50 PM
