February 25th, 2017, 01:46 PM | #1 |
james250ninjette.newbie
Join Date: Mar 2010 Motorcycle(s): 1986 ninja 250 Posts: 276
2008-12 ninja 250 carbs.
Does anyone know if I can use the 08-12 ninja model carbs in the pre gen models 86-07.
February 25th, 2017, 03:14 PM | #2 |
i think later model 30's will bolt up but '86-87 actually used 32mm carbs
Here's a thread with some comparative pics and possible pertinent info...though in this case the 30's were swapped for 32's in a pregen ....you're contemplating the opposite. https://www.ninjette.org/forums/show...t=32mm+carbset I believe they will bolt up, just dunno how they would run. EDITED TO ADD....'86 and 87 only used 32mm (with metal slides) , 88-07 used 30mm, 08-12 used different 30mm
gordon@customcarbservices.com Custom Carb Service www.customcarbservices.com Last futzed with by ducatiman; February 26th, 2017 at 09:46 AM. |
REFURBED CARBS 250 Ninja | Ghostt | Motorcycle-related | 9 | March 9th, 2015 04:48 PM |
FS: 1988-07 Ninja 250 Carbs | TonyKZ1 | Motorcycle-related | 17 | November 23rd, 2014 01:30 PM |
DIY- Carb Work on 2008 Ninja 250 carbs | kkim | 2008 - 2012 Ninja 250R Tech Talk | 40 | September 8th, 2011 07:51 AM |
