May 7th, 2014, 11:51 AM | #1 |
Join Date: Dec 2013 Motorcycle(s): '04 Ninja 250R Posts: 367
foot scraping..
being as i am a new rider. 6 months+. i have gotten less scared to lean in the corners. maybe its where im placing my foot but when i lean on my right side( which i lean more on my right then i do on my left) i tend to scrap my foot along the ground. the toe of my foot i should say.
Does any one have any advice t prevent this? |
May 7th, 2014, 11:54 AM | #2 |
Join Date: Apr 2011 Motorcycle(s): 2015 636 ABS - 69 Honda 305 Posts: A lot.
Better body positioning
May 7th, 2014, 11:58 AM | #3 |
Join Date: Oct 2013 Motorcycle(s): 2013 White Ninja 300, 2010 Red Ninja 250r (Sold) Posts: 335
I touched my foot to the ground for the first time ever at the track a couple days ago, then did it a few more times. The track was mostly lefts, so I only touched down on the left side.
The consensus is lean your body more, and lean the bike less. The first thing to touch should be knee, not toe, but that comes with experience and proper body position. Once you're scraping toe that means you're using most of the lean angle the bike can give you, so it's time to reduce the bike's lean angle at the same speed by improving your body position. See my thread here for additional discussion: My First Track Day |
May 7th, 2014, 12:12 PM | #4 | |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Hey Unregistered never go faster than your brakes can be applied... |
May 7th, 2014, 12:16 PM | #5 |
Join Date: Apr 2014 Motorcycle(s): five honda's one harley one ninja most have sold all where fun.(one honda was a moped) Posts: 344
I noticed a lot of feet coming off and placing a foot down before corners last time I watched a race (jerez or whatever it was) why do they do that? I didn't think that was smart but I am not a track master or even beginner. it was like they where doing at the start of the apex then bringing foot up and over to the elbow or knee but I saw it a lot of times.......
May 7th, 2014, 12:26 PM | #6 |
This could be it also. Could angling the foot off the peg where the toes are kind of sticking out be an issue too? I was trying to focus on keeping my foot back, and tucked up against the side of the bike as most I could, when I knew I was going to be leaning a lot.
In a right corner where you had to brake before corner entry, do you remember to move your foot back after using the rear brake, and not cover the brake through the apex? Going left, if you had to downshift before the corner did you remember to move your foot back after you finished shifting? I think my first scrape could have been because my foot was too far forward and/or off to the side of the peg, and that's why I scraped the spot under my toe slider instead of scraping the slider. Later in the day is when I removed some of the metal from my toe slider, and I'm pretty sure my foot was back because I had been telling myself repeatedly not to leave it forward by the shifter. |
May 7th, 2014, 12:58 PM | #7 | |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
May 7th, 2014, 01:03 PM | #8 |
thanks man. so its the motocross background.
May 7th, 2014, 01:30 PM | #9 | |
its hard to do though from a normal seating position. depending on your height, you have to slide your butt off the seat to the inside so that the side of your leg is against the tank and you can lock your foot into the peg. in this position you should be able to touch your chin to the inside bar without using either of your hands or your inside foot for support. of course, its hard on your back and leg so do some workouts one thing this kind of just naturally accomplishes though is that your body "wants" to fall into a correct BP and if you keep your arms relaxed, they kind of just go where they're supposed to.
May 7th, 2014, 01:42 PM | #10 |
Join Date: Feb 2014 Motorcycle(s): 2012 R6, 1981 CX500, 2003 Ninja250 and counting Posts: 13
you should be placing the balls of your feet on the pegs. twist of the wrist ii explains this very well.
May 7th, 2014, 02:39 PM | #11 |
cadd cadd cadd
MOTM - May '15
How much lean angle do you generally have left after scraping the OEM footpegs?
I have never come close to scraping anything. At least I don't think I've came close. I do have 3/4 - 1" of chicken strips. I want to experience scraping something so that when it does happen unexpectedly I wont panic and do something stupid. |
May 7th, 2014, 03:08 PM | #12 | |
Tire wear close.jpg Here's the video of my first time scraping my toe, at 25 seconds in.
Link to original page on YouTube. |
May 7th, 2014, 03:09 PM | #13 |
May 7th, 2014, 03:10 PM | #14 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Balls of your feet (just under your toes) on the pegs at all times. Good lines and solid body position will make you drag knee before toe. Don't freak. There's a reason boots have toe sliders. It happens. Just learn from it. Read Twist of the Wrist and Total Control. HIGHLY recommend before you ride technical corners again.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
Peg Scraping? | mrudich | Riding Skills | 39 | June 12th, 2014 08:19 AM |
Grinding or scraping sound ???? | Z300 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 14th, 2013 03:05 PM |
Brake scraping while turning? | kingkang204 | 2008 - 2012 Ninja 250R Tech Talk | 1 | April 13th, 2011 10:32 PM |
Scraping Pegs... Dangerous!? | ahskeetz | Riding Skills | 14 | April 21st, 2009 07:07 AM |
