June 12th, 2014, 10:45 AM | #1 |
Join Date: Jul 2013 Motorcycle(s): 2012 ninja 250r Posts: 49
clip ons
I want to get some aftermarket clip ons but I don't know what size the forks are I have a 2012 250
June 12th, 2014, 11:14 AM | #2 |
37mm yo!
June 12th, 2014, 11:20 AM | #3 |
Which ones would you recommend
June 12th, 2014, 11:22 AM | #4 |
100% woodcraft or vortex
June 12th, 2014, 11:25 AM | #5 |
No clearance issues with the regular witchcraft or do I have to get one with risers
June 12th, 2014, 11:28 AM | #6 | |
Seriously though, there are clearance issues. You need the risers or drop the front and mount above the triple.
June 12th, 2014, 11:37 AM | #7 |
Will the one inch risers be enough
June 12th, 2014, 11:46 AM | #8 |
If you don't want to ever worry about the clearance of the stock bodywork and tank, get the 2.5 risers.
If you want to go lower a bit of customization here and there will be required.
June 12th, 2014, 12:06 PM | #9 |
Ok and this is probably a stupid question but when people say triple tree it's pretty much the plate that sits right below my handle bars
June 12th, 2014, 12:11 PM | #10 |
No such thing as a stupid question.
But yes, that is the top of the triple. It has two parts, an upper and lower. The stock bars bolt to the top triple.
June 12th, 2014, 12:13 PM | #11 |
Great ok so the 2.5 rise bars will be below the triple and not have Any clearance issues. Is that what you have on your 250
June 12th, 2014, 12:20 PM | #12 |
Ummm... not quite.
I have the 2.5 risers yes and the woodcraft clamps do go under the triple but once the risers are installed and the bar put in the riser, the bar itself will be above the triple (and other bodywork & tank). Mine looks like this; If you search around on here, there are other pics from others.
June 12th, 2014, 12:27 PM | #13 |
Ok cool now I know exactly what to buy thanks for the help
June 12th, 2014, 01:30 PM | #14 |
Join Date: Sep 2013 Motorcycle(s): '12 ninja 250r Posts: 26
http://www.revzilla.com/motorcycle/d...riser-clip-ons
i have these. 37mm is you size. no real clearence issues if installed properly. |
June 18th, 2014, 09:35 AM | #15 |
Join Date: Apr 2014 Motorcycle(s): 2011 ninja 250, 2001 klr 250, Honda 400ex Posts: 18
i got the driven clip ons, anyone know a way to install bar ends, do the end caps come off?
sometimes im a squid.... |
June 19th, 2014, 12:35 AM | #16 |
I have been thinking of getting Woodcrafts myself
I had a brand called Mazriano that went on top problem was it required dropping the fork tubes .75 inch which affected teh steering geometry too much. So off they came. Sometimes I wonder/consider the type like Tyga makes which use the stock mounting holes but do not need to drop forks...Also final position looks about same as woodcraft if run with no spacer under. Beet also makes one similar ( the all black pic below ) What do you guys think? |
June 19th, 2014, 05:43 AM | #17 |
Where can you get those beet clip ons
June 19th, 2014, 08:02 AM | #18 |
http://www.beet.co.jp/english/kawasa...50r/index.html
Looks pricey though as 24k Yen = $235 USD But the Tyga is $165 http://tyga-performance.com/site/pro...oducts_id=3296 |
June 19th, 2014, 02:17 PM | #19 |
Join Date: May 2014 Motorcycle(s): Ninja 250R & CBR250R Posts: 105
Im guessing those Beet bars pictured are not the ones for the Ninja 250. I dont see how they would work without the hole for the fork. The top of the fork tube doesnt sit flush with the upper triple clamp, does it? I thought it stuck up a little higher than the clamp.
June 19th, 2014, 07:54 PM | #20 | |
I thought the same thing as you just mentioned |
Woodcraft clip-ons V.S. Kitaco clip-ons | tjb0012 | 2008 - 2012 Ninja 250R Tech Talk | 41 | June 20th, 2011 05:35 PM |
