Old June 20th, 2016, 11:28 PM   #1
z0sum
Engine Ice Top Off?
So about 3 years ago, I flushed my coolant completely and put in some Engine Ice. I checked it again last week, turns out the reservoir is empty. Do I have to drain the system again or can I just buy some more Engine Ice and top it off by adding it to the reservoir?
z0sum is offline   Reply With Quote
Old June 21st, 2016, 12:40 AM   #2
Ghostt
Ghostt's Avatar
It's totally up to you, keep in mind coolant needs to be flush and change every couple of years.
Your call.
violente et ignorantia
ZX-2R BLOG
Old June 21st, 2016, 04:30 AM   #3
tubarney
you might want to figure out how the coolant in the reservoir disappeared.
Old June 21st, 2016, 03:50 PM   #4
z0sum
I figured over 3 years of not checking it might of done it? I've heard Engine Ice is especially quick to evaporate... so, could that be it? Or do you guys think it could be a bigger problem?
Old June 21st, 2016, 04:05 PM   #5
3yrs and you need a top off... seems normal to me. Fill it up and go from there. If it's the "ready to use" type, then fill it up and an keep an eye on it.
Old June 21st, 2016, 04:13 PM   #6
Ghostt
Ghostt's Avatar
After not checking it for 3 years, I would say, you need to check it more often obviously.
No worries after that.
ZX-2R BLOG
[motorcycle.com] - Engine Ice Keep It Cool Sweepstakes Ninjette Newsbot Motorcycling News 0 April 27th, 2016 09:30 AM
Full flush to switch to engine ice? Bigballsofpaint Ninjettes At Speed 14 April 18th, 2016 08:23 PM
[roadracingworld.com] - Sponsorship Opportunity With Engine Ice Ninjette Newsbot Motorcycling News 0 August 27th, 2015 09:30 AM
[cyclenews.com] - Engine Ice Introduces the Champion's Chip Ninjette Newsbot Motorcycling News 0 July 15th, 2015 06:40 AM
[roadracingworld.com] - Engine Ice To Be Distributed In Canada By Motovan Ninjette Newsbot Motorcycling News 0 June 30th, 2015 11:10 AM
