January 14th, 2018, 09:12 PM | #1 |
Join Date: Aug 2017 Motorcycle(s): 2005 Ninja 250 Posts: 78
What size pilot jets are you guys running?
Currently have size 38, it is a pain to start in the summer, and I don't ride in the winter, has anyone solved this issue with larger pilot jets?
January 14th, 2018, 09:41 PM | #2 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
Bill
Insanity: doing the same thing over and over again expecting different results each time. |
January 14th, 2018, 09:44 PM | #3 |
Possibly, my carbs were spotless on the inside so I think I'm gonna try jets first. It doesn't really have a problem starting, just staying running without full choke till its warm
January 14th, 2018, 10:09 PM | #4 |
Are your valve clearances in spec?
January 14th, 2018, 10:09 PM | #5 | |
Bill
January 14th, 2018, 10:42 PM | #6 |
"a legend in my own mind"
Join Date: May 2017 Motorcycle(s): 2015 moto guzzi norge,2020 aprilia dorsoduro, 2014 yamaha fjr, 85 yamaha fj 1100 Posts: A lot.
MOTM - Feb '18
40's, but i have pods.
"trying not to get old" |
January 14th, 2018, 11:29 PM | #7 |
The bike has absolutely zero issues starting in brand-new OEM condition with the exact jets you have. Your difficulty starting would have to do with some non-factory configuration or condition. Most likely uncleared fuel circuits. If the bike's not running perfectly like new, then the carbs aren't perfectly cleaned, simple.
January 14th, 2018, 11:39 PM | #8 | |
January 15th, 2018, 08:03 AM | #9 |
have you set the pilot screws, each cylinder, for highest idle, best response
set with engine fully warmed (after a ride) ??
Custom Carb Service |
January 15th, 2018, 08:42 AM | #10 |
One of our Ninjas was running pods and a leaky stock exhaust with stock 38s.
Never had any starting issues, even in cold (<40F) temps. If the idle mixture is set correctly there shouldn't be any starting problems unless there are other issues (sync, valves, restrictions, enrichener issues, etc). |
January 15th, 2018, 12:55 PM | #11 |
January 15th, 2018, 02:03 PM | #12 |
What is vacuum-level in lines that should have vacuum?
January 15th, 2018, 02:35 PM | #13 |
Pilot jets | KaTyStew | 2008 - 2012 Ninja 250R Tech Talk | 5 | October 15th, 2016 04:09 PM |
FS: Genuine Keihin 42 Pilot Jets | GlassAnkles | Motorcycle-related | 0 | March 27th, 2013 10:19 AM |
Changing pilot jets on a stock 250 | shadowman | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 15th, 2012 08:49 AM |
WTB #40 Pilot Jets | tjkamper | Items Wanted | 1 | August 29th, 2010 05:32 PM |
stock size jets??? | scorpio_vette | 1986 - 2007 Ninja 250R Tech Talk | 13 | July 20th, 2009 11:15 PM |
