July 5th, 2016, 04:20 PM | #1 |
Join Date: Nov 2015 Motorcycle(s): 2009 Ninja 250 Posts: 386
Looking for opinion Intiminators
So I have been looking around at wether to do some RaceTech emulators or Ricor Intiminators. Anyone here have any feedback? I saw a few posts on here but they are a few years old. I already have new springs and preload adjusters in the front.
July 6th, 2016, 05:24 AM | #2 |
They both seem to work. There's more tuning experience with the emulators posted online.
July 6th, 2016, 09:56 AM | #3 |
EX500 full of EX250 parts
That's the impression I got too. Emulators still use a fixed-orifice damping system, with the spring-operated valve. The only tuning you can do is the rate and preload of the spring. Intiminators use a shim stack, so it's customizable by the thickness and number of shims (nearly infinitely). When you look at the details, Intiminators are actually much more of a "cartridge emulator" than emulators are.
I've only read of one person being unhappy with the Intiminators. It was a two person team sharing a bike, and he said there was a large difference in their weights. A number of track riders did say they used 7.5wt oil rather than the recommended 5wt to get slower rebound. I think a lot of people aren't able to, or don't want to, take the time to figure out the best setup with the Intiminators. With emulators, they can get a good baseline from someone else, and turn the screw a bit to tweak it until they're happy. There isn't as much data about the Intiminators yet, so I think you're more on your own for figuring it out. The fact that Ricor bills them as a drop-in fix to all your suspension problems (and that they do work pretty well out of the box) doesn't help that. If I were trying to tune my Intiminators to be perfect, here's what I'd do.
At this point though, I just dropped them in with no tuning, and I'm quite happy with how well they work on my street bike. I plan to drill out the damper rods when I have the forks apart for servicing, and I may play around with tweaking/modding them, but so far I've felt no need to. I think of emulators and Intiminators as being quite similar to carbs and EFI. A lot of people have a lot of experience making carbs work well, but there's simply a physical limit to what you can tweak on them. EFI allows you a lot more adjustability, but it's more complex and not nearly as many people are familiar with it.
July 6th, 2016, 10:52 AM | #4 | |
Join Date: Oct 2015 Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike Posts: 556
MOTM - Nov '15
So, yes, you can get good results with emulators as well as Intiminators. Are Intiminators better than emulators? It's possible if you tune them right. Are cartridges better than Intiminators? It's possible if you tune them right. Having said that, well-tuned emulators will be a lot better than poorly tuned Intiminators or cartridges. I started to go down the road of cartridges with my racebike and I decided to wait till I saw the results with emulators. I have good enough results with the emulators that I don't see the need for something better for now. Part of this is the 250 Ninja itself. It is a flexible chassis that is not very sensitive to setup and allows greater lattitude for an effective setup. |
July 6th, 2016, 11:13 AM | #5 | |
so spears racing sells "customized" intiminators just for the 250. They say its a basically a race version. I am pretty heavy, 220lb so I have .90 springs and running 20wt oil. Just curious what settings or tweaks do you do on the emulators ? |
July 6th, 2016, 11:28 AM | #6 |
Emulators + 10w oil here but crashed 3 times via a tucked front at near lap record pace each time. Otherwise, I have a great track day setup but please note that my best skill is entry while hard on the brakes. I am 175lbs+ gear and run the same springs as you.
July 6th, 2016, 11:29 AM | #7 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
I run the intiminators in my KLR. they really changed the way the whole bike operates
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
July 6th, 2016, 11:30 AM | #8 |
Emulators are much more affordable only $115, I wonder if I should keep with 20wt oil or try 15wt if I go emulators.
July 6th, 2016, 11:32 AM | #9 |
Vintage Screwball
MOTM - Mar '16
With emulators, the oil weight controls your rebound dampening. IMO, if it's working OK now, stick with what you have and make a change if needed after the emulators are installed.
Goin' fast on slow bikes! |
July 6th, 2016, 11:33 AM | #10 |
I would start with 15w and go from there, but 20w is ok too. Since you already have the caps, it's easy to change with a large syringe w/ tube.
July 6th, 2016, 11:40 AM | #11 | |
I assume I can keep the same oil height? Just cut my preload spacers to accommodate for thickness of the GVE ? also curious what oil level you guys are running, I am at 140mm on my tool. looks like RT recommends 130mm when using GVE. |
July 6th, 2016, 12:32 PM | #12 |
http://faq.ninja250.org/wiki/Install...rs_and_springs Should help with the hole drillin'.
I would have to get my little black book to get you the oil measure, but I don't have it with me right now.
July 6th, 2016, 12:37 PM | #13 | |
July 6th, 2016, 01:02 PM | #14 | |
MOTM - Nov '15
Peter Verdone has a ton of good information and the chart he put together is what I used to custom mix my oil. Here's a link to the oil info: http://www.peterverdone.com/wiki/ind...spension_Fluid If you look at the oil viscosity chart, it will clearly show you why you don't want to switch back and forth between oil brands. He even put together a handy mixing chart. http://www.peterverdone.com/wiki/ima..._Mix_Chart.pdf Although I have gotten good results this way, I will say a couple of things: So far, I haven't had to push the front to the point that I am getting chatter although I have had it slide once or twice. It seems that Chris (csmith12) may be taxing the front a bit more than me. I would say that my style is a little less aggressive on the brakes with an emphasis on carrying as much corner speed as possible with more "classic" lines, so keep in mind that different riding styles may requre different setups. Also, I can't say enough about the excellent service and advice that Gregg Spears has to offer. He helped me tremendously when I was building a big bore SV650 motor. I don't think he'll steer you wrong. No pun intended One last piece of advice when tuning your suspension: Only change ONE THING AT A TIME. Whether it's ride height, oil viscosity, oil height, preload, etc. That way you know for sure how the change affected your bike. If you make more than one change at a time it's much harder to know what to do if you don't get the result that you want. |
July 6th, 2016, 02:31 PM | #15 | |
July 6th, 2016, 03:42 PM | #16 |
emailed RT gave them weight info on me and bike they recommended going with
Blue spring, 3 turns, 140mm oil level and 15wt oil |
July 7th, 2016, 06:42 AM | #17 | |
MOTM - Nov '15
Here's a Motion Pro tool that makes getting the oil level right a lot easier: http://www.motorcycle-superstore.com...oil-level-tool |
July 7th, 2016, 09:32 AM | #18 | |
July 7th, 2016, 11:16 AM | #19 | ||
The good news is that the Intiminators seem to come set up pretty well. A lot of people seem to do exactly what the instructions say and just drop them in with new oil. An SV650 guy said he had a hard time telling them apart from his $1100 cartridge forks. Quote:
Looks like PSS/Amazon has them for a little cheaper than everyone else. When I got mine, they were going for over $130. I sold mine (BNIB, to fund the Intiminator purchase) for $130 shipped and they were gone in a few days. To me, the extra $50 was worth it for what I consider better technology. Compared to $115, it's more than 50% extra (a decent chunk of cash), but I think it's still a relatively small amount in the grand scheme of owning and modding a bike. It's an order of magnitude smaller than the price difference going to cartridge inserts.
July 7th, 2016, 11:18 AM | #20 | |
July 7th, 2016, 11:20 AM | #21 |
^^^ I used a spray head for an old bottle of simple green. I measured the straw to a place that was reliable and repeatable, then used the head to squirt all excess oil out to that point.
July 7th, 2016, 11:47 AM | #22 |
MOTM - Nov '15
July 7th, 2016, 12:29 PM | #23 |
CCS Amateur #501
Join Date: Jun 2015 Motorcycle(s): '09 250 SE 'Booger' Posts: 406
I found out theres another option (for the 300 at least) with the Mupo Hydraulic Kit. It seems to be a shim stack, a la intiminator, but without the inertia valve. Googling didnt seem to turn up anyone having tried one on a ninjette.
July 7th, 2016, 12:58 PM | #24 |
That was my syringe and the tube was some old tubing I had laying around the garage. The wife has not happy with me taking kitchen items to the garage.
July 7th, 2016, 01:15 PM | #25 | |
My understanding is that the Intiminator inertia valve is aimed at compensating for big bumps, so trading that for the Mupo's better rebound setup is probably a good deal on a track bike. It may or may not work out better overall on a street bike.
July 7th, 2016, 02:43 PM | #26 |
July 7th, 2016, 03:23 PM | #27 |
July 7th, 2016, 03:27 PM | #28 | |
7 Install the fork fluid. First remove the fork spring and use the oil viscosity recommended in racetech.com. Bleed the fork by pumping them. Install the Emulator and then set the oil level with the forks completely bottomed and the springs out. |
July 9th, 2016, 04:50 PM | #29 |
When you guys are installing the springs on the emulators, so you just get them to where they aren't loose? and then count the turns from there? for example, RT told me 3 turns on the blue springs. So I swapped the blue spring , and then i tightened the nut down just so it was snug and then counted 3 full turns.
July 9th, 2016, 08:00 PM | #30 | |
Join Date: Apr 2014 Motorcycle(s): 1978 Z1R, 1999 EX250 Posts: A lot.
MOTY - 2018, MOTM - Oct '16
From their site; In a sense, RICOR has managed to put two different shocks with completely different characteristics into one package. The primary circuit is tuned to control chassis motion and the secondary circuit is tuned to control wheel motion. RICOR's Inertia Active Suspension is able to recognize the difference between these two types of input and select the appropriate response instantaneously and automatically. As a result, RICOR shocks are able to provide the optimum response to chassis motion AND wheel motion without any of the compromises typically associated with traditional shock absorbers. I'm guessing that they are trying to slow front end dive on the brakes. Having ridden 250s with each you'd be hard pressed to tell the difference between them when installed per instructions. The Intiminators install easier but would be more difficult to remove for tuning as they push in hard and parts don't seem to be readily available. The Emulators are more work to install because of the drilling required in the damping rod, but are easy to remove for tuning (comes with 2 different springs and you can vary the preload of them), only takes a magnet or a parts retriever claw, as they slide in and out easily. I and #1 son like the bike with the tuned Emulators better but it may be the tires as much as the forks. (one has S-20 Evo's and the one that we like better has RS-10's)
Last futzed with by Z1R rider; July 17th, 2016 at 07:17 AM. |
July 9th, 2016, 08:27 PM | #31 | |
July 9th, 2016, 10:29 PM | #32 | |||
I assume that big bumps are much less of an issue on a track, so the shim-stack rebound control of the Mupo might be more useful. On the street where you don't need super-precise rebound control as much, the Ricor valve might be really nice for rough roads. Quote:
I would've liked to install the emulators for comparison, but I didn't want to deal with the extra work and taking the hit when selling them (vs. BNIB), so I just went directly to the Intiminators instead.
July 10th, 2016, 03:30 PM | #33 |
Not even snug, just making contact then the adjustment turns. I'm running 3 turns on the yellow spring using Bel-Ray 20w oil.
July 10th, 2016, 03:49 PM | #34 | |
I think most like the Intiminators because they are much easier to install.
July 10th, 2016, 05:12 PM | #35 | |
July 10th, 2016, 06:12 PM | #36 |
Was tight. Added some stiction. Had to file the rings juuuuust a tad.
July 10th, 2016, 08:26 PM | #37 |
I am so confused about when to add more turns or when to use a yellow spring. what feeling are you guys getting when making this determination?
July 11th, 2016, 05:44 AM | #38 | |
ps: I find the yellow spring is plenty harsh on the street, liked the blues better off track
July 11th, 2016, 07:37 AM | #39 | ||
July 11th, 2016, 08:46 AM | #40 | |
Need part numbers for 250r spring/intiminators! | corksil | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 21st, 2014 09:00 AM |
Looking for opinion | msebastian | 2008 - 2012 Ninja 250R Farkles | 105 | April 16th, 2013 02:59 PM |
Opinion? | JeffM | General Motorcycling Discussion | 10 | April 23rd, 2012 04:39 AM |
What's your opinion? | Stavrosqq | Motorcycle Gear | 3 | August 7th, 2010 10:37 PM |
FS: Intiminators for 86-09 Ninja 250 | esi7esi7 | Motorcycle-related | 5 | July 15th, 2010 10:17 AM |
