Old January 16th, 2014, 08:33 AM   #1
shadewalker
Motorcycle(s): Ninja 300
List of mods so far
Ok so the following thread will include a list of mods i wish to do and the ones ive alredy done to my bike.
List of pending mods :
Completed mods :
12 MM Nissin master cylinder for the front.
Steel braided Brake lines for the front and the back.
Foldable re-sizable adjustable levers
Ninja 636 Clutch Perch
red anodised nuts for the fuel cover on the tank.
michelin pilot street tyres
cf swingarm spools
Akra slip on from the old 636
15 Teeth JT front sprocket
gixxer 600 shock Almost done
Woodcraft clipons.
Tapered steering stem roller bearings.
SSR Preload Adjusters
Bazzaz Zfi TC(Installed)
Tokico 4 pot caliper for the front.
a few pics of the braking upgrade
Last futzed with by shadewalker; March 12th, 2014 at 07:08 PM. Reason: Updates
shadewalker is offline   Reply With Quote
Old January 16th, 2014, 10:41 AM   #2
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Looking and sounding good so far
Old January 16th, 2014, 10:44 AM   #3
shadewalker
thank you .. im still hunting for a good caliper. if i dont find one ill go for the ducati 748 one with the ssr bracket.
Old January 16th, 2014, 10:47 AM   #4
JohnnyBravo
That rim tape come on your bike, and what color scheme is that? looks like the solid green we didn't get in the states.
Old January 16th, 2014, 10:49 AM   #5
shadewalker
yeah so the rim tape i bough separately. and the color scheme is the basic 300. we in india didnt get the special edition or the abs version of the bike.
Old January 16th, 2014, 10:50 AM   #6
shadewalker
a better view.
the exhaust has been shortened so bear with the extremely long exhaust.
Old January 16th, 2014, 09:48 PM   #7
old3
Was there a donor bike for the Nissan 12mm master cylinder? Seen it in 13mm?
old3 is offline   Reply With Quote
Old January 16th, 2014, 09:57 PM   #8
shadewalker
not exactly a donor bike since it was from a friend's 636. there is a guy who gets all these parts from crashed bikes from dealerships over here. so he has tons of forks master cyls calipers lying around. literally tons. even brembos. so tomm im hoping to get my hands on a nice caliper for this master cyl coz its way too hard right now.
Old January 16th, 2014, 10:12 PM   #9
old3
If you search my threads I added a Tokico 4 piston to my 300 off a GSXR with a pretty simple aluminum bracket. It is a really good match with the 13mm stock master. I'll look at the 636, by donor I just meant what bike it was stock on. Thank you!
Good direction to look into. Your sure it is a 12mm piston? That bike pushes at least 8 if not 12 pistons in the calipers? I'd have thought it was bigger than that. I'd think even with my 4 piston cal it would lack any feel at the lever.
Old January 16th, 2014, 10:14 PM   #10
shadewalker
yup i remember looking at your thread. but the bracket is a little difficult.
it pushes 8 pistons for sure. and if you could help me with the bracket i would definitely go for the 4 pot tokico. what year gixxer was it take off of?
Old January 16th, 2014, 10:17 PM   #11
old3
Hey, ummm. I'll have to go check my thread.
I see a 14 cast on the bottom of a zx636 master cylinder so I'm thinking it is a 14mm piston. Does yours say 12?
Old January 16th, 2014, 10:19 PM   #12
shadewalker
yeesh ur right :O i never thought id misread. it is indeed a 14mm mas cyl. u think it will be too much for even the 4 pot?
Old January 16th, 2014, 10:20 PM   #13
old3
Here is the thread, it was a 2002 GSXR but I've got a front end off a CBR 929/954 and they use the same one too. 2000-2004 at least I believe. If I did it again I'd find a CBR 330mm rotor to refit on a custom carrier for my wheel and go from there with the caliper bracket. I'm looking into that now.
http://www.ninjette.org/forums/showthread.php?t=123397
Old January 16th, 2014, 10:23 PM   #14
shadewalker
no pics?
Old January 16th, 2014, 10:23 PM   #15
old3
I'd try it, in fact I might just do it anyway. I'd bet I'd lose some feel but Rojo
(sp) was using a bigger master on his IIRC.I'm pretty happy with the lever feel as it is, but more power wouldn't hurt either! That's one reason I'm looking at the bigger rotor. I'm spoiled by sumoto brakes.
Old January 16th, 2014, 10:24 PM   #16
old3
no pics?
Bugger. I'll take new ones tomorrow! Sorry about that!
Old January 16th, 2014, 10:25 PM   #17
shadewalker
something like this? and what should i do about the bracket?
http://www.ebay.com/itm/2002-02-SUZU...baa9a2&vxp=mtr
Old January 16th, 2014, 10:26 PM   #18
shadewalker
lol its ok.. for today i'll be happy completing my gixxer shock install. the only doubt im having is where and how much do i need to cut the undertail and will my airbox get exposed if i cut it?
Old January 16th, 2014, 10:27 PM   #19
shadewalker
sounds like a good idea. the 2 things i'll need to change are pads and caliper. its not like the bike isnt braking but its just too damn hard.
Old January 16th, 2014, 10:31 PM   #20
shadewalker
http://www.ebay.com/itm/2002-02-Suzu...83342e&vxp=mtr
found this also. if this works then im golden. ill save a lot of money . oither wise my only other option is a ducati 748 brembo and a ssr bracket. that's 200 dollars :S
Old January 16th, 2014, 10:31 PM   #21
old3
Yep, that looks like it. I got a nearly new one super cheap. I've been told they don't like road salt but I'm in my second winter of using it and it has been coated with salt for weeks at a time, no problems.
The air box, you just need to cut the flap hanging off behind the shock. you don't need to cut into the box at all. IIRC I used a long sawzall blade for wood and went in thru the side, very slowly. It was clipped off in a few strokes of the saw blade. Again, very slow!
I think it pointed down-ish, towards the rear of the bike, like a splash shield for the shock? I don't have an air box or I'd go look at it for you bud. Sorry I'm just going from recollection. It should be obvious, right where the new shock reservoir will be.
Shoot a pic and I'll try to help if you need it.
Jim
Old January 16th, 2014, 10:34 PM   #22
old3
How about a 6 piston caliper off a Japanese bike. Didn't the Hyabusa use 6 piston calipers? Go big as you already have a (probably too) big master.
http://www.ebay.com/itm/2004-SUZUKI-...708e0f&vxp=mtr
Old January 16th, 2014, 10:34 PM   #23
shadewalker
hmmm there is indeed a flap type thingy and i think i'll take my dremel to it. would be cleaner since i lack any experience with a saw :P
Old January 16th, 2014, 10:35 PM   #24
shadewalker
hmmmm would it even fit on the 280mm rotor?
Old January 16th, 2014, 10:38 PM   #25
shadewalker
i would need ac ompletely different bracket for this
http://www.ebay.com/itm/99-07-Suzuki...a7d325&vxp=mtr
Old January 16th, 2014, 10:38 PM   #26
old3
Mine bit on the painted center a lil. No harm, it is all the same material. I'd explore it at least. Find out the size of the Busa rotors and the GSXR, which I'm 99% sure were 320mm. Can you get one at the local source to test fit? Maybe get a few measurements from a Hyabusa forum?
Old January 16th, 2014, 10:39 PM   #27
old3
You'll need a new bracket regardless. Mine is billet aluminum. You have a milling guy? Machinist? It can be done in steel too if you have a welder/fab guy or the skills yourself.
Old January 16th, 2014, 10:41 PM   #28
shadewalker
just looked it up. definitely 320 mm
Old January 16th, 2014, 10:42 PM   #29
shadewalker
i have both in fact. even a guy who is exceptionally good with a lathe. but i need some specifications. otherwise ill be shooting blind.
Old January 17th, 2014, 06:54 AM   #30
shadewalker
Gixxer Shock Install Complete
First of all i wanna thank old3, cuong-nutz and Rexbo. their info made this a hell of a lot easier for me.
it feels tremendous but i will have to play around with the damping and compression to get a final feel.
i had to cut a little area in the undertail to make the reservoir fit keeping the airbox untouched.
Old January 17th, 2014, 07:06 AM   #31
Yep, I did too. It was shown in Rexbo's thread, so I knew I had to do that ahead of time.
Post up your settings when you git it all dialed in and stuff. I need to post up mine too.
Old January 17th, 2014, 07:13 AM   #32
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
I was interested in swapping the master cylinder on my bike too. Good to see someone else doing it. Looks good.
Old January 17th, 2014, 07:14 AM   #33
shadewalker
feels horrible though as of now. till i upgrade to the tokico 4 pot caliper. after that im sure its gonna feel awesome
Old January 17th, 2014, 07:16 AM   #34
TnNinjaGirl
Ms. Personality
Noted. I'll keep checking back to see how it feels after that.
Old January 17th, 2014, 07:19 AM   #35
shadewalker
shouldnt take too long. maybe a week to 10 days and i should have that too. i just hope old3 can get me the drawings for the bracket
Old January 17th, 2014, 07:30 AM   #36
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
a better view.
god that solid green I couldn't get looks clean and sexy as hell, very beautiful bike
which mod do you feel has had the biggest impact on your riding, I feel that it will be the gsxr shock but other mods to do myself down the line are always good.
Old January 17th, 2014, 07:35 AM   #37
shadewalker
thanks. my bike has actually been opticoated. so its pretty easy to keep it clean inspite of all the dirt here.
the most difference i felt after making a mod was with the front sprocket. it just goes on and on in 1st now. feels so much better i cant tell you. you need to experience it yourself.
i think my fav mod is has been the steel brake lines. makes a huge difference.
second would be the exhaust. man this thing sounds wicket. ill put up a video soon with the sound and the diy bracket i had to make to make it fit.
i havent had a chance to go to the track yet since i just completed the shock and im still playing around with the sag setting. also i need to educate myself as how these gas shocks work.
but the 2 mods im most excited about are the clipons and bazzaz ZFI-TC. that should be fun
Old January 17th, 2014, 07:36 AM   #38
shadewalker
a pic displaying the finish of the bike after a month of opticoat.
Old January 17th, 2014, 07:37 AM   #39
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I can imagine clipons being my favorite mod should I end up installing some. In the meantime a 600cc shock install seems like one of, if not the, most likely mods that I'll be doing in the future, and yes I'm right there with you on the front sprocket change it made a magical difference.
Old January 17th, 2014, 07:38 AM   #40
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
wow...my bike looks the opposite right now with it's daily dose of salt, I wash it every week when I clean/lube the chain but it just gets dirty again right away
Mods heyzeus 1986 - 2007 Ninja 250R Tech Talk 5 June 17th, 2014 08:18 PM
List Your Mods!!! kkim General Motorcycling Discussion 210 March 12th, 2014 11:49 AM
Yes or no on these mods? Kerberos General Motorcycling Discussion 19 December 13th, 2011 10:33 AM
List of Mods TheJimmyEnglish 2008 - 2012 Ninja 250R Farkles 63 October 16th, 2011 08:55 AM
My mods and what i got for my $$ eddiekay General Motorcycling Discussion 2 August 9th, 2011 09:27 AM
