Old December 10th, 2018, 07:07 AM   #81
You'd be surprised at how well an 11 year old carbed 250 car run when properly tuned.
I wouldn't stop at acceptable. Do a carb sync and fine adjustment of the idle mixture and go from acceptable to optimum.
Old December 10th, 2018, 11:22 AM   #82
My 2005 Ninja 250 is the newest vehicle I own, and they all run very well.
Old December 10th, 2018, 01:34 PM   #83
What a bunch of geezers! I like going out at 6am with temps in 30s and pushing start-button on my bike and have it Vrrrooom to life in less than 1 crank. Then being able to hop on and ride off without single hiccup in less than 15-seconds after that (how long it takes to put helmet & gloves on). I'm converting my 250 to EFI this winter so it will be civilised!
Carefully check rubber boots between engine & carb. They can have small cracks (or loose clamps) that will suck in extra air and cause temperamental idle.
Also do compression-test, you may have worn-out rings and/or valves that can cause difference between cylinders; resulting in lumpy idle.
Run a bottle of PEA-based cleaner through 2-tanks of gas (1/2 each). Such as Techron Concentrate or Red Line SI-1. Then repeat compression-test and see if there's improvement.
Old December 10th, 2018, 01:42 PM   #84
Hey - I resemble that comment!
I didn't know you had "winter" in SF. Anything is possible out there I guess...
Old December 10th, 2018, 04:21 PM   #85
Heh, heh... it's occasionally normal here...
Old December 12th, 2018, 01:49 PM   #86
dodgerdad
dodgerdad's Avatar
Video
So I had a chance to fire it up cold this morning and just as I dreaded (but expected) it ran horrible. I shot a quick video which shows the initial start up.
I had the choke open and still had to gently give it a tiny bit of throttle so it wouldn't stall, but not too much or it would bog out. Towards the end of the video you can see I close the choke and it doesn't help, in fact it stalls.
After the video, I kept helping it along with the choke open and once it reached almost normal operating temperature it idled and ran just fine.
Other than the idle speed adjustment, I haven't touched the carbs since their servicing.
Barring someone pointing out a smoking gun, I'll do a carb sync next week. If that doesn't fully resolve the issue I plan to slap on the fairings and list it over the Christmas break.
Here's a link to the video so you can see her in all her shi**y splendor:
https://www.youtube.com/watch?v=aOCl6hj-5M0
Old December 12th, 2018, 02:06 PM   #87
I could be wrong, but it looks like you didn't have the lever fully in the start position anywhere in the video (lever all the way toward you). Then you put it back to the warm-run position while it was still cold.
Also, there's an easy to adjust knob for idle speed adjustment down by the carb on the left side, so you can adjust that to raise the idle speed any time you need to.
These little engines normally warm up in the 1,500 to 3,000 rpm range, not chugging along at 1,000.
Old December 12th, 2018, 02:21 PM   #88
dodgerdad
dodgerdad's Avatar
The lever was all the way forward, I'll double check the linkage to make sure everything is sitting right.
As for the idle speed knob, I set it when the bike was up to temperature a couple days ago. One shouldn't have to advance the idle with this knob every time it's started cold.
And yes, in the video I did close the choke when it was still cold, understandably it cut out.
Old December 12th, 2018, 02:27 PM   #89
All the way forward is the warm-run position, no enrichment. When you start it cold, it will need to be toward you.
The idle speed knob is there for a reason. Depending on conditions, you may need to adjust it. I occasionally make an adjustment to mine, especially if it's cold out.
You're saying you "closed the choke", which implies you enriched the mixture, but I think you meant the opposite, as in "closed the enricher plungers".
Old December 12th, 2018, 02:35 PM   #90
dodgerdad
dodgerdad's Avatar
Right, towards me when starting it cold, away once it's at temp.
Old December 12th, 2018, 02:46 PM   #91
Use enough choke to keep the revs about 2000 to 2500 for a minute or so, then back it down as much as possible while still keeping the RPMs over the normal idle speed of 1300.
It's no surprise it won't idle cold without any "choke". Use the choke to keep it running when it's cold.
You are getting close. Sync the carbs and adjust the idle mixture and you should be good unless there are other issues - but I don't see any right now.
Old December 12th, 2018, 02:59 PM   #92
dodgerdad
dodgerdad's Avatar
Just confirmed, linkage/cable is properly installed and actuated by lever.
Last futzed with by dodgerdad; December 12th, 2018 at 02:59 PM. Reason: typo
Old December 12th, 2018, 03:00 PM   #93
dodgerdad
dodgerdad's Avatar
Well that's the problem (now), it won't idle above 1000 when cold...
Old December 12th, 2018, 03:02 PM   #94
I'm still not sure you're getting the lever all the way toward you when starting. In the video it was not all the way, but as I said, maybe you had it there earlier. The last part will really raise the idle.
edit: I just checked the video again. At the very beginning, the starter lever was not all the way toward you, which explains why is was running so slowly.
Old December 12th, 2018, 04:43 PM   #95
dodgerdad
dodgerdad's Avatar
Skeptically, I went out there and made sure the choke lever was all the way towards me, and it started. It won't idle past 1300 (when cold) unless I play with the accelerator, which is weird because after a few seconds you usually have to push the lever back a bit so it's not revving too HIGH while it warms up.
At any rate, you were right about the lever, thanks. I think I'll have time Friday or Saturday to do the sync.
Old December 12th, 2018, 07:42 PM   #96
What's ambient temperature there when you started bike for video?
When it's below 45F here, mine won't even start with choke full-on. It'll spin for 5-revs, then stop. I have repeatedly start it over and over again. After 6th time, it'll stay on, put-put-putting around 200-rpms for about 2-minutes.
After that it picks up and stays at about 1000-rpms for about a minute. Then it goes up to 2000-2500rpms after another minute. So about 4-minutes of choke before I can release choke 1/2-way and ride off.
Old December 12th, 2018, 10:25 PM   #97
dodgerdad
dodgerdad's Avatar
It was 59 degrees when I did the video.
Old December 15th, 2018, 04:14 PM   #98
at around the 35 second mark, you should begin *sequentially* backing off the choke, while applying throttle.
Prior to that in the video...I'm hearing an engine favoring 1 cylinder over the other.
By the one minute mark you should have been OFF the choke and ON some throttle, till it wants to idle on its own with no throttle input at all.
i'm thinking you need to up the idle adjustment a bit.
Where does it idle at when warmed?
You earlier stated you performed a valve adjustment, what were your findings?
And solutions? You are SURE you performed checks at the precise cam positions?
Old December 17th, 2018, 07:23 AM   #99
dodgerdad
dodgerdad's Avatar
The bike doesn't start (with the choke) at a high RPM like it did in the past and like my previous carbureted bikes have done. Typically the RPM's jump up and you have to start backing down the choke so it doesn't rev too high but my bike barely runs. It'll bog if I give it any less than the slightest bit of throttle when cold.
I haven't sync'd it yet but did adjust the air mixture which really smoothed out the deceleration quite nicely as it was hanging before. When it's warmed up it runs great, it will idle at 1700 (or 1300 about 25% of the time), one or the other, without much fluctuation.
I adjusted the valves as per the wiki instructions which are pretty clear. What I found is that all the valve clearances where a bit too tight. I didn't take note as to what the prior gaps were.
Old December 17th, 2018, 08:04 AM   #100
You may have a vacuum leak somewhere.
Old December 17th, 2018, 08:37 AM   #101
Feel the head pipes when you first start it and see if they warm up equally, or if one warms up faster than the other, or if one stays cold.
Old December 17th, 2018, 11:57 AM   #102
dodgerdad
dodgerdad's Avatar
OK, I can even borrow a digital laser thermometer. If they warm up unevenly, what will that indicate??
Old December 17th, 2018, 01:49 PM   #103
It will tell you that both cylinders are firing, and that the carbs are at least pretty closely synced.
In the video, it seems like maybe one cylinder is weak or not firing at all. Feeling the pipes when you first start it will tell you right away if one cylinder is not doing its job.
Old December 17th, 2018, 08:20 PM   #104
dodgerdad
dodgerdad's Avatar
Seems simple enough, I'll try it. Does it make sense that a cylinder would miss but only when cold and then always run fine when warm and riding around? I put 40 miles on it yesterday and it ran fine.
Old December 18th, 2018, 07:10 AM   #105
Does it make sense? To quote Kwai Chang Caine, "When you cease to strive to understand, then you will know without understanding."
[motogp.com] - Home race frustration for Redding Ninjette Newsbot Motorcycling News 0 September 5th, 2016 01:44 AM
[visordown.com] - Frustration for Haslam after teammate does the double Ninjette Newsbot Motorcycling News 0 May 11th, 2014 11:10 AM
Exerting Frustration Through Memes Jiggles Off-Topic 12 September 5th, 2012 02:41 PM
