Old December 25th, 2012, 07:21 PM   #1
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Mounting Contour Camera
Hey guys, happy holidays
I got an item from my wish list -- a new Contour camera -- from the family and have been researching the various mounts. From what I can tell, if I want to mount it for general use on my helmet the go-to-mount is the profile mount ( e.g. this one). Reading reviews however says this mount is only held on with doublesided tape which is... kind of a bummer. I'd hate to lose my camera cause something like that came off when I was heading down the freeway. I've looked around and found this which is a metal mount instead of plastic and you're supposed to screw it onto your helmet with drilled holes. That sounds super stable but the idea of compromising my lid that way is scary too.
Anyone have any advice/experience/ideas? I could revert to mounting it on the bars or something, but that seems like it'd be a less interesting vantage point.
Old December 25th, 2012, 07:25 PM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
You obviously don't have much experience with 3M permanent tape. It's plenty strong
AFM #676
Supersports are for n00bs
Old December 25th, 2012, 07:27 PM   #3
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Is that what comes on it or something I could replace it with? The Amazon reviews of the Contour mount have multiple people saying it came undone in pretty low-stress use.
Old December 25th, 2012, 07:30 PM   #4
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Really now? Well you can always order some separately. It's what gopros are mounted with and they survive high speed moto crashes. The camera doesn't always survive, but the mount does
AFM #676
Old December 25th, 2012, 09:12 PM   #5
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Definitely an idea. What about Industrial Velcro? If it's of similar strength I'd think it'd have advantages (could remove the mount if I had reason to, would let me play a bit more with the angle of the camera too since this mount doesn't rotate any.
Old December 25th, 2012, 09:36 PM   #6
I think those riders don't treat their equipment with any respect. I use my contour just about ever ride. I have had it for 2yrs now and still using the original sticky tape mount that was included in the packaging. I have ridden in the wet, cold and really hot and it has held without worry and still shows no signs of failing anytime soon.
Now....
Pick a good mount point and then really think about it again before committing to it. Then, clean the mount area with rubbing alcohol first, stick it to your mount point and press firmly.... not like a sissy either. FIRMLY! Give it some time (have a beer) and press it again. If it's on your bike, it will peel the paint off before coming off. It's only as strong as where you choose to mount it. Mount it on loose material like peeling paint and you know what is going to happen.
And now for the protection part... no matter your camera, go pro, contour or something else. When in doubt, safety wire it. If the mount fails, the safety wire will hold it.
Pro Tip* - The contour comes with a short string with clips on then ends to act as this safety wire. While that is kinda meh.... put it back in the box and use real wire. The wind will cause the plastic clip to bang around the housing/mount and that sound will make it into your video.
Pro Tip 2* - Put a piece of tape over the mic to cut down on wind noise.
Good luck with your contour and I hope you like yours as much as I like mine. It's really the only really easy camera I have seen that can be operated while the bike is in motion.
Old December 25th, 2012, 09:41 PM   #7
Oh! Double check your mount before each ride also.
Old December 25th, 2012, 09:55 PM   #8
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Thanks for the advice csmith. The 'make sure it's right' is why I thought the Velcro might be a good choice -- if I lay out the helmet-side velcro right I can have some play in the angle. (Basically do a pie shape).
Second point: How can I safety wire a helmet mount, or would that be for bike mounting only?
Old December 26th, 2012, 12:25 AM   #9
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I can vouch for the Contour's sticky tape being durable. It's what held my camera in place through my wreck with me sliding and bouncing along the track/dirt. I've got the little rotating mount on my helmet simply due to me wanting to be able to adjust it up or down depending on what I expect to be filming.
I'm also curious what you'd safety wire it to, as wiring it to the mount didn't make much sense.
<-- Linky
Old December 26th, 2012, 12:34 AM   #10
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Hey Wolf, did you put the rotating mount on the top of the helmet or the side? If it fits on the side I might try that out; but I think it'd look silly on the top of my lid :P
Old December 26th, 2012, 05:23 AM   #11
Joshorilla
Bass Master General
Joshorilla's Avatar
I used the profile mount on my lid initially but it was pointing too low, so I just used a swivel mount, I cleaned the are on my lid with a monitor cleaning wipe which only contained isopropol alcohol and small traces of other VOC's, stuck it on with a GOOD amount of pressure, kept pushing on it at points in the day, rode home with it and it was golden.
No signs of coming off or anything, I would say it's more than strongmenough for the application, and given I had to pry the first mount off nearly destrying myself before the tape it's good shiit.
To answer your post above, I use the swivel mount on the side without a problem, I wanted to put it up top, but my modular helmet wouldn't allow for it to go up top without fouling the mechanism.
Old December 26th, 2012, 06:10 AM   #12
DeviantTurtle
DeviantTurtle's Avatar
Motorcycle(s): Honda CRF150, Polaris outlaw 450MXR, Polaris 330 Trail boss, Yamaha 125ttr, Baja DR50, Taotao 110R
Just have faith, I use a suction cup and the helmet stick on mount. 132mph (Road Atlanta track) tested and no issue so far.
Note; Camera hanging off the side fairing!!!
DeviantTurtle is offline   Reply With Quote
Old December 26th, 2012, 08:31 AM   #13
NevadaWolf
NevadaWolf's Avatar
I put mine on the left side of my helmet. I agree with you that up on top looks stupid Plus being on the side it is easier to turn on off
<-- Linky
Old December 26th, 2012, 09:10 AM   #14
I use a swivel mount on the right side of my helmet. The helmet is the only place I don't use safety wire because I am not messing up the helmet in any way to make a hole.
Old December 26th, 2012, 09:33 AM   #15
Joshorilla
Bass Master General
Joshorilla's Avatar
I guess the rule of thumb is to mount it onto the opposite side of the helmet to which you drive on so it is more centred.
Old December 26th, 2012, 10:39 AM   #16
I choose right because I am right handed but yea, more right turns on the track vs left turns.
Old December 26th, 2012, 10:47 AM   #17
NevadaWolf
NevadaWolf's Avatar
I must be watching way too much BBC lately... My brain thought No, it's mounted on the same side I drive on.
<-- Linky
Old December 26th, 2012, 11:12 AM   #18
Joshorilla
Bass Master General
Joshorilla's Avatar
Ha! You'll just get more scenery, that's not necessarily a bad thing
Old December 26th, 2012, 11:18 AM   #19
NevadaWolf
NevadaWolf's Avatar
If I tried driving on the left side of the road, I am sure I would get far more than just more scenery. ROFL Curse I would find out how nimble the bike really is.
Back on topic, I mounted it on the left so I could operate it while riding. It's far enough forward it only sees the front curve of my visor and is able to see whatever I turn my head to look at. I like how loud the beep is because I can hear it when it starts/stops/dies over the motor and wind noise.
I tend to have the mic turned almost off and have a piece of tape over the opening. But still need to cut out the sound when I am fiddling with it on the computer.
<-- Linky
Old December 27th, 2012, 03:12 PM   #20
ChrisCusi
ChrisCusi's Avatar
Motorcycle(s): 2013 Ninja 300 (Black)
Just curious.. what contour cameras do you guys have? I've been really looking at the Roam2 lately.
ChrisCusi is offline   Reply With Quote
Old December 27th, 2012, 03:24 PM   #21
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Contour+2 for me; I'll post a review after I've used it some.
Old December 27th, 2012, 03:31 PM   #22
ChrisCusi
ChrisCusi's Avatar
Can't decide if I want to shell out the extra cash for the +2.... It's a tough decision. I greatly look forward to your review!
And just to clarify.... by the which side argument, we're talking about mounting it on the left side of the helmet because in the US we drive on the right, correct? Not talking about lane position or lane selection right?
Old December 28th, 2012, 08:07 AM   #23
Yep, mounted on the left side because we ride in the right lane.
Old January 3rd, 2013, 11:45 AM   #24
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
I've had my contour mounted on my helmet for almost 6 months and no problem. I cleaned the area and used the rotating surface mount and adhesive tape it came with. At one point I used the lanyard that came with the camera and put it through one of the screws for the visor (XR1R). But now I've raised the angle, so it can't reach it. I should have planned ahead. Also, it's mounted on the right because chatterbox is on the left.
broilmebk is offline   Reply With Quote
Contour camera question ai4px Videos 4 April 24th, 2013 10:31 AM
Testing my Contour HD camera setup pilotgeorge747 Videos 15 February 8th, 2012 11:22 AM
[webbikeworld.com] - Contour GPS HD Video Camera Review Ninjette Newsbot Motorcycling News 0 June 18th, 2011 07:20 PM
[motorcycle.com] - Contour introduces GPS hands-free 1080p camera Ninjette Newsbot Motorcycling News 0 September 30th, 2010 05:30 PM
[webbikeworld.com] - VholdR Contour HD Video Camera Review Ninjette Newsbot Motorcycling News 0 February 5th, 2010 01:30 AM
