Old April 16th, 2014, 11:36 AM   #1
jgcable
Motorcycle(s): 2003 Ninja 250r
Brake pads
I have a 2003 with 4100 miles on it. Its in flawless showroom condition. It was a barn find. It has been sitting in a heated garage covered for the last 6 years. It hadn't been touched since 2008. I just completed a full maintainence on it. Oil and filter, oil screen cleaning, new NGK plugs, lubed the chain, cleaned out the gas tank, new Kawasaki petcock, valve adjustment, carb removal with complete cleaning, removed air/mixture screw plugs and set up the carbs perfectly, washed the air filter, new battery. Its Lime Green and it literally looks brand new. It runs absolutely 100% perfectly. Starts on the first push of the button after 2 whacks of the throttle. Doesn't even need choke to start and I can take off immediately. Anyway... the next 3 items on the agenda are replacing the front fork oil with something a little heavier, tires and brake pads which leads me to this question. The brake pads on the bike look brand new. They have little to no wear on them at all and the bike stops on a dime. It actually has too much brake. Anyway.... is it necessary to swap out brake pads on a bike that has been sitting for the last 6 years? Do they get brittle or do they break down or get contaminated at all from sitting. I have no problem changing them... especially since I have to do the new tires anyway but factory OEM brakes are usually pretty good and I don't want to take off really good brakes and replace them with aftermarket ok ones.
jgcable is offline   Reply With Quote
Old April 16th, 2014, 11:42 AM   #2
Since the bike was stored in a climate controlled environment, I would just inspect the pads and rotors. As long as nothing is out of the ordinary, you should be good to go. However, I would question the quality of the brake fluid.
Old April 16th, 2014, 04:54 PM   #3
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
What Chris says (above). Replace the brake fluid!
Old April 17th, 2014, 05:42 PM   #4
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
Agree with the above. And clean the rotors with a scotch-brite pad. Good find, good for you.
j98sprint
P.S. How about a pix?
j98sprint is offline   Reply With Quote
Old April 21st, 2014, 05:25 AM   #5
jgcable
j98sprint
[IMG][/IMG]
Cant find brake bolt connecting brake pads. Trubin General Motorcycling Discussion 6 June 3rd, 2014 05:35 PM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
brake pads inverted56 2008 - 2012 Ninja 250R Tech Talk 6 March 5th, 2012 05:29 PM
Brake Pads caps 2008 - 2012 Ninja 250R Tech Talk 17 October 15th, 2011 10:55 AM
$5 brake pads! CZroe Motorcycle-related 9 October 11th, 2011 12:23 PM
