Old August 5th, 2015, 08:55 AM   #1
VaFish
VaFish's Avatar
MOTM - Jan '16
Motorcycle Lifts
Has anyone ever used a motorcycle lift like this one from Harbor Freight:
http://www.harborfreight.com/1500-lb...ck-to-top-link
Do they make maintenance easier?
Old August 5th, 2015, 09:11 AM   #2
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
That one is designed for bikes with a double-cradle frame, like Harleys.
The Ninjette doesn't have anything on the bottom... you'd be lifting the bike by its oil pan.
For sport bikes, this is the one:
http://www.harborfreight.com/1000-lb...8892-8495.html
No actual experience with lifts, but I can tell you that having the bike elevated does make life easier. When track prepping my bike, I like to get it on the trailer first.
I've often wondered if the big lift would fit under my car, so I could just put one in the middle of the garage for use when needed. Probably not, though.
Old August 5th, 2015, 10:14 AM   #3
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I love my table lift!
I've since added the grey chock the holds the front wheel better than the red plate it came with. Makes oil changes, chain maintenance, and wheel replacement super easy, plus a lot simpler to just raise it up and tinker with things.
Mine fits under my truck with chock lined up under my bumper, but I have a 4Runner with slightly larger than stock tires.
Keep an eye on sales and coupons, I *think* this can be picked up for around $200 periodically.
<-- Linky
4 out of 4 members found this post helpful.
Old August 5th, 2015, 10:23 AM   #4
YES!!! Lift on sale + super coupon = $200 lift table
DO ET! You will not be sorry.
Old August 5th, 2015, 10:34 AM   #5
adouglas
adouglas's Avatar
Any idea what the actual height is when collapsed, not counting the front wheel holder thingamagig?
I've got a Honda Fit.
Yeah, I know.... dream on....
Or... I could just put it along one side of the garage and just drive the car up onto it....
(Wife: "Andy? Why is your car tilted to one side like that?")
Old August 5th, 2015, 10:51 AM   #6
NevadaWolf
NevadaWolf's Avatar
Well, that might be a solution. I want to see pics if you do it!
Off the top of my head, sorry no I don't know the height. But I can measure it tonight when I get home if you want.
<-- Linky
Old August 5th, 2015, 11:38 AM   #7
VaFish
VaFish's Avatar
MOTM - Jan '16
How does the table lift help with wheel changes?
Do you have to put the bike on the centerstand on the lift? (that's one of the reasons I was looking at a lift, PO removed the centerstand from one of my bikes)
Old August 5th, 2015, 11:50 AM   #8
Hey Tom, you have a pregen, as you may already know the new gens do not have a stock center stand. Anyway... when changing tires and such, a set of stands make life much easier. They make a few different types but 2 should do the trick;
A front triple tree stand - they make some that go under the fork legs also (pictured)
A swingarm stand - you will need the paddle type to lift the stock swingarm on a pregen (rear spool type pictured)
Ebay and craigslist will be an asset here to find a good deal. If you want the best... buy pitbull.
To do more involved work on a bike, getting it up off the ground and at to at least waist level makes the work more enjoyable and not as hard and the legs and back.
Old August 5th, 2015, 11:57 AM   #9
adouglas
adouglas's Avatar
That's what paddock stands are for. This does not replace them. You still need to get the wheels off the ground.
What a table lift does is keep you from breaking your back and tearing up your knees.
Old August 5th, 2015, 12:29 PM   #10
NevadaWolf
NevadaWolf's Avatar
^ what they said.
Bringing the axle up to you vs getting on the flooring makes working on the bike much easier and less painful on you. I still use a pitbull on the rear to deal with the chain and rear tire. My front tire gets more creative as I don't have a front stand.
<-- Linky
Old August 6th, 2015, 12:15 AM   #11
johnydecali
johnydecali's Avatar
Motorcycle(s): '12 Ninja 250r
Wished that I had an actual garage that I could use at my apartment, if I did I'd invest in the 1000lb lift table... As for now I'm lucky to have a brother that's a mechanic with all the tools/toys
I'm not imperfect. However my imperfections are what creates my value and makes me unique - johnydecali
johnydecali is offline   Reply With Quote
Old August 7th, 2015, 09:05 AM   #12
NevadaWolf
NevadaWolf's Avatar
That tall.
<-- Linky
Old August 7th, 2015, 09:23 AM   #13
Rifleman
Old and slow
Rifleman's Avatar
Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250
Lift from the tree pitbull is about as rock solid as you can get.
http://img.photobucket.com/albums/v620/Ricejocky/achievement.easy.bake.Rifleman_zpscllv4ryl.png
Rifleman is offline   Reply With Quote
Old October 5th, 2015, 08:32 PM   #14
windingroads
Motorcycle(s): 1989 GL1500 Goldwing
Used to have a lift. Big, heavy, always tripping over it. Realized I always used it "fully raised" or "fully lowered", so I sold it, built a fixed-height table, and use a ramp with it. When not in use, it's easy to lean against the wall. To each their own, I guess.
windingroads is offline   Reply With Quote
Old October 5th, 2015, 08:33 PM   #15
windingroads
I DO have a front-stand, the type that fits into the holes on the bottom of the forks, that I don't particularly need. Anyone near Waukesha WI wants it for $20, come on by.
Old October 5th, 2015, 08:55 PM   #16
FilipinoAviator
FilipinoAviator's Avatar
Motorcycle(s): 1999 CBR1100XX, 1989 Ninja 250, 1993 KDX200
Or, you know, use a 2-post car lift and some 550 cord
FilipinoAviator is offline   Reply With Quote
Old October 6th, 2015, 06:48 AM   #17
DCMoney
DCMoney's Avatar
Bought a pneumatic lift a few years ago, neighbor has the harbor freight lift and I didn't like the foot pump actuation to lift the table up.
Its an invaluable tool to have if you have the room for it.
I've even taken it to the track with me.
MCRA.com
Ingenious Lifts Motofool Videos 2 July 15th, 2014 07:01 AM
[motorcyclenews.com - sport] - Francis lifts Pinhard Trophy Ninjette Newsbot Motorcycling News 0 January 6th, 2014 08:40 AM
[superbikeplanet.com] - Repsol Lifts Veil on Marquez Test Ninjette Newsbot Motorcycling News 0 March 12th, 2012 08:50 AM
[webbikeworld.com] - Handy Motorcycle Lifts Ninjette Newsbot Motorcycling News 0 February 19th, 2012 03:30 PM
Shoe lifts as a solution for high seats adouglas General Motorcycling Discussion 23 June 24th, 2010 08:12 AM
