Old October 9th, 2011, 02:30 PM   #1
THE BIG SITT
THE BIG SITT's Avatar
Fuel Gauge not working
So I'm finally finishing up all of the work on my bike. One of the last hiccups is the fuel gage's unwillingness to cooperate. And yes, I do have that little wire clip thing attached. My main concern comes from this: On my fuel tank, I currently have a total of THREE tubes attached. Two are going to the petcock, and one is a vacuum tube going to the left side of the tank. Now it looks like there is a place one the fuel sensor thing on the bottom of the tank for another tube, but all of my tubes are going somewhere. So am I missing a tube? Am I retarded?
THE BIG SITT is offline   Reply With Quote
Old October 9th, 2011, 02:53 PM   #2
ScorpionNinja
ScorpionNinja's Avatar
that 3rd one on left side of tank, is your gas overflow tube, it runs down next to the rear shock, points down to the ground (aka 250Rs Penis).
I took out my carbs to clean them, while putting bike back together, I have a hose from between the carbs... that I could remb goes to where. I connected it to the "FUEL SENSOR" (black) under the tank, right side, but my bike dont even start now. I dont even remb if anything goes to it.
My 2009 ISNT the california model, is yours?
Old October 9th, 2011, 07:37 PM   #3
THE BIG SITT
No mine is not the CA model. So you're saying there is a tube that goes to the black fuel sensor under the tank?
Old October 10th, 2011, 09:06 AM   #4
ScorpionNinja
no, i "thought" there was... so i connected a vaccum hose from the carb, to the black fuel sensor thinking it would solve my bikes problem.
its clear that, that nothing is to be connected to the black fuel sensor except for the WIREs that plugs into it, lol.
Old October 10th, 2011, 09:14 AM   #5
THE BIG SITT
Hmmm… so any other ideas why the gage isn't working?
Old October 10th, 2011, 09:22 AM   #6
Cuongism
Cuongism's Avatar
What do you mean by not working? Doesn't read full, always says empty, etc?
Old October 10th, 2011, 09:31 AM   #7
THE BIG SITT
It reads completely empty...
Old October 10th, 2011, 10:29 AM   #8
Cuongism
Cuongism's Avatar
Your issue is probably electronic then and shouldn't have to do with those tubes (unless your tank is actually empty ). The easiest thing to check is the fuel sender connector which has a green tab is connected.
It should only connect one way and clicks into the other tab. If that's secure, you might have jarred a wire loose behind the dash.
Old October 10th, 2011, 11:07 AM   #9
THE BIG SITT
I'm not at home so I can't just look; do the gages need taken apart to see if there is a wire loose?
Old October 10th, 2011, 04:24 PM   #10
ScorpionNinja
I think, you only need to remove the windscreen, then the 4 chrome hex bolts on the dash (2 are used for the Mirror mounts) then that whole panel should come off to allow you access to the gauges wiring.
Replace Fuel Gauge with Fuel Light? Proteus 2008 - 2012 Ninja 250R Tech Talk 8 December 2nd, 2014 08:33 AM
My video on how to fix the fuel sender for your fuel gauge Klint 2008 - 2012 Ninja 250R Tech Talk 1 November 2nd, 2013 09:04 PM
Fuel tank/Fuel gauge issues coolcatjames 2008 - 2012 Ninja 250R Tech Talk 10 August 23rd, 2012 06:25 PM
Fuel gauge not working jdoucet93 2008 - 2012 Ninja 250R Tech Talk 6 September 15th, 2011 10:07 PM
fuel gauge shellneil General Motorcycling Discussion 8 November 1st, 2009 02:26 PM
