Old March 11th, 2013, 05:21 PM   #1
TqAmsNy
Motorcycle(s): 250r 09 and 04 R1
09 Ninja 250r wont stay idle without choke
so this problem started a while ago...bike was running very boggy if that's the right word...my girl could not get it to go over 20....looking online there were a couple of options....so I first tried new spark plugs and a fuel system carb cleaner...that did not work so my next step was to take the carbs and air cleaner out for cleaning...so i put them back in today....bike is just as bad.
Major problem...using the throttle makes bike putter out barely reacts unless choke is on.
Here is a quick video of the problem:
http://m.youtube.com/watch?v=DmiZc_t4n20&feature=plcp
TqAmsNy is offline   Reply With Quote
Old March 12th, 2013, 05:45 AM   #2
Welcome Tim!
Hmmm.... Sounds like an aftermarket exhaust and not getting enough gas. Was the bike ever tuned for the new exhaust? Vac leak somewhere maybe? When you cleaned the carbs did you ensure all jets and other pathways were clear?
Old March 12th, 2013, 06:45 AM   #3
DaBlue1
DaBlue1's Avatar
The bike is running bad in the video partly because you have the side cover off of the air filter and you are trying to throttle a cold engine. If you've cleaned everything, put it back together, start it with the choke and let it warm up, then set the idle to about 1350 rpms and see what happens.
Old March 12th, 2013, 11:32 PM   #4
TqAmsNy
OK...will try the suggestions to day when I wake up And get back to everyone....thanks for the responses so far :-)
O and the jets and all were pulled, wired and sprayed through for proper spray and the exhaust didn't effect it for a few months before the problem but I will put the stock on to verify.
Old March 13th, 2013, 12:20 AM   #5
tubarney
If your wearing a hoodie/jumper outside then its too cold and you need to let it warm up.
When its below 45F outside the 250 needs time to warm up. Some mornings it takes me 5+ mins before I can even move. Give it throttle and its going to stall.
Old March 13th, 2013, 01:42 AM   #6
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
sounds like you need to let it warm up before we can tell if there is an issue.
TEAM ALFALFA
www.apexassassins.com
Old March 13th, 2013, 07:12 AM   #7
There are about 4 or 6 (can't remember) other air/gas pathways in the carbs. Those need to be just as clean as the jets. I hope you get it figured out.
Old March 13th, 2013, 09:05 AM   #8
Welcome to the site, Tim !!!
Also check that the air intake is free and that all the electrical connections to both spark coils are clean and solidly connected (it sounds to me that one cylinder is not firing).
Old March 13th, 2013, 02:04 PM   #9
TqAmsNy
THANKS for all the welcomes! Well stupid me it was the idle turned too low....and it is idling pretty good now. Must've had something happen when it was stripped apart, now the back is back to my original problem which is a little less severe....I will post a video showing it later...but basically when i "crack" the throttle there is a delay and it wants to stall out. I have to kinda easy into it to keep it revving, but then it still starts to miss. Like I said, I will have to show on a video. It has been warmed and I ran seafoam through it just in cases something was missed when disassembled.
Old March 20th, 2013, 11:45 AM   #10
TqAmsNy
THought it was all under control....but there is still a "delay" when the throttle is opened and then while holding it, will not rev higher than a couple thousand. LIke it won't allow it to move.
Old March 20th, 2013, 12:53 PM   #11
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
That happened to me once when I forgot to hook up the gas tank lines correctly after I put the tank back on. Is there gas in the tank?
cookiebug79 is offline   Reply With Quote
Old March 20th, 2013, 01:38 PM   #12
TqAmsNy
Yea...about half tank, fresh gas. I'll have to check the routing again. Damn haha, o well. The new plastics won't be here for another week or so anyway so time to strip her down again :-|
Ninja wont stay in 1st when engine off archaeofreak 1986 - 2007 Ninja 250R Tech Talk 6 December 20th, 2014 04:30 PM
2010 ninja 250 wont stay on! daveduno 2008 - 2012 Ninja 250R Tech Talk 10 May 27th, 2014 07:55 PM
2008 ninja only runs on choke at idle Klondike1020 2008 - 2012 Ninja 250R Tech Talk 5 September 6th, 2012 09:00 AM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Ninja 250r Wont Rev or run without choke esde 1986 - 2007 Ninja 250R Tech Talk 21 November 9th, 2009 02:32 PM
