Old May 25th, 2019, 11:36 PM   #1
minimatt
minimatt's Avatar
Noob Question About Front Brake Lights
Hey guys,
I purchased my first bike ('08 Ninja 250) at the start of this year which I bought for dirt cheap. I'm the 5th owner and seems like it's been neglected for a long period of time. Simple tasks like chain cleaning and adjustment were never done, and the bike in general is just in pretty bad condition.
The bike is in way better shape now than when I bought it. There are just a few more jobs to perform before everything is in working order.
The problem:
I need to replace the entire brake caliper and front master cylinder assembly.
I'm quite confused on how the front brake lights are connected to the front master cylinder. Is it just a wire running from the brake switch underneath the master cylinder?
I'd like to know this information before I commit to dismantling my front brakes and encounter a blank wall as my bike is my only form of transport and would prefer to do this job in 1 day.
Your help is much appreciated!
minimatt is offline   Reply With Quote
Old May 26th, 2019, 06:18 AM   #2
It's actually two small wires, one to each terminal of the little switch on the master cylinder. It's shown in the motorcycle's wiring diagram in case you forget.
Old May 26th, 2019, 07:43 AM   #3
Originally Posted by minimatt View Post
Hey guys,
The problem:
Replace? Each able to be rebuilt to become operational, you know.
Even painted to look pretty again.
On what basis are you condemning them to the junkpile?
Old May 26th, 2019, 08:56 AM   #4
minimatt
minimatt's Avatar
Noted, thank you! I'll look out for the wires.
My front master cylinder cap screws are stripped and refuses to come off, which means I have no way to refill the bike's braking fluid once I bleed them.
The pistons on the brake caliper wont push back despite using a piston rewind tool. The caliper itself is probably rebuildable to working order as you said, but I found one online from a Ninja with only 1,000 miles on the clock. I figure it would just save me a lot of hassle with a neglected one if I just purchased an entirely new caliper.
Old May 26th, 2019, 09:18 AM   #5
your call, good luck with it
Old May 26th, 2019, 05:39 PM   #6
There's front brake lights???
Old May 26th, 2019, 05:49 PM   #7
Do you mean screw-heads on cap is buggered, or threads themselves in resevoir below?
Need to use JIS screwdriver tip instead of philips, probably too late now.
Using hammer impact driver will often remove these screws .
https://www.harborfreight.com/impact...ase-37530.html
Worse case, use 4mm bit to drill out just heads of screw. Pop off cap and remove stubs of screws with pliers. Then replace screws with new ones using anti-seize.
All above procedures are still quicker and less effort than replacing master-cylinder. Bleeding from scratch with empty cylinder and line is pain. I suggest tying caliper up so bleed-screw is higher than MC.
Front brake hard braking question Cep 2008 - 2012 Ninja 250R Tech Talk 16 July 2nd, 2018 07:29 PM
Stupid noob question from a non-noob LNasty 2008 - 2012 Ninja 250R Tech Talk 13 March 21st, 2015 10:47 PM
Noob Tire question Harrison89 2008 - 2012 Ninja 250R Tech Talk 7 July 29th, 2012 06:07 PM
ZZR-250 Front Brake Question johnjohn 1986 - 2007 Ninja 250R Tech Talk 6 August 31st, 2010 04:38 AM
Noob Jetting Question 00v_Lucky 2008 - 2012 Ninja 250R Tech Talk 6 July 11th, 2010 06:23 PM
