Old March 27th, 2019, 06:29 AM   #1
Ponr
2004 ninja 250 newbie hard to start
Hey guys newbie here. I have a bike there’s hard to start. If I choke it all the way it won’t start. If I go close to half way on choke and give it a little throttle it starts. Once it warmed up sometimes I have to give a little throttle for it to start.
It isles around 1500 when started. I’ve clean the carbs, put new plugs. But at a lost.
Thanks
Ponr is offline   Reply With Quote
Old March 27th, 2019, 06:49 AM   #2
dodgerdad
dodgerdad's Avatar
Did you properly re-install the spring, washer and gasket in he air mixture holes before installing the scew? Did you set both mixture screws to 2.5 turns out?
Old March 27th, 2019, 06:52 AM   #3
Ponr
I installed the o-ring, washer, spring in that order with oring at the top. If I turn the screws out at 2.5 the plugs are black I guess for running rich.
Old March 27th, 2019, 08:04 AM   #4
ducatiman
ducatiman's Avatar
provided your carb work was successful...other tuning factors to consider as well...spark at plugs, valve clearances, air filter....blah blah
"its all gotta work together like an orchestra".
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 27th, 2019, 10:01 AM   #5
Ponr
Before it wouldn’t run without the choke. I had a plugged jet so cleaned I didn’t want to soak the whole thing as I was afraid of the plastic fuel line. It was removal so I just clean all the passages with a Cooper wire and compressed air.
I have good spark and new plugs.
Valves were with specs.
New air filter.
Old March 27th, 2019, 10:43 AM   #6
ducatiman
ducatiman's Avatar
New air filter.
spark ok? yes?
valves ok? yes?
air filter ok? yes?
Then your carb work is suspect.
Custom Carb Service
Old March 27th, 2019, 11:11 AM   #7
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
sounds like it's rich starting and warmed idling, is the fuel level in the float bowls set to the proper level? (maybe too high)
Old March 27th, 2019, 11:22 AM   #8
That's what I was thinking. Also verify that the float valves are sealing.
Old March 27th, 2019, 02:06 PM   #9
And make sure all jets are stock sizes. Someone in past may have installed larger jets to make up for clogged fuel-circuits in carbs instead of doing proper disassembly and cleaning.
2004 250 ninja help -- won't start SON1C 1986 - 2007 Ninja 250R Tech Talk 6 March 24th, 2014 10:30 AM
2004 ex250 won't start fallsdown76 1986 - 2007 Ninja 250R Tech Talk 7 October 21st, 2013 10:50 PM
Hard to start sometimes? SwagenGTI 2008 - 2012 Ninja 250R Tech Talk 3 May 7th, 2013 08:38 PM
Hard to start Sfor6285 2008 - 2012 Ninja 250R Tech Talk 11 August 28th, 2011 09:43 AM
hard to start conchwanab 2008 - 2012 Ninja 250R Tech Talk 4 May 7th, 2009 02:30 PM
