June 21st, 2014, 06:22 AM | #1 |
Adjustable pegs: No need to modify Buell pegs anymore
I was searching for Buell pegs to combine with my rearset adjusters so that my pegs are no higher but are further back with no reduced ground clearance. That's when I came across an eBay seller with "adjustable pegs" with a similar design. The difference is that these pegs are on a bracket which can be rotated so that it either drops the peg, moves the peg back, raises the peg, or moves the peg forward. The bracket is available in 25mm or 40mm.
25mm: http://www.ebay.com/itm/360-Adjustab...item2c7bf9c62b 40mm: http://www.ebay.com/itm/40mm-Length-...item5409d878cb I think they are a bit expensive but it's not like the Buell pegs were free. Last futzed with by CZroe; June 23rd, 2014 at 11:04 AM. |
June 23rd, 2014, 09:50 AM | #2 |
Join Date: Dec 2013 Motorcycle(s): 2011 250R SE Posts: 326
These look pretty slick but $50 seems pretty steep when you can make riser plates out of some aluminum and a drill.
June 23rd, 2014, 11:11 AM | #3 | |
Buell pegs (N0520.1AD and N0521.1AD) would come in only one color for about $35, require modification (grind to fit), come in one length only, and aren't adjustable (drop only). Someone probably thinks the price difference is worth it. I agree that it's steep and hope to find cheaper ones from other eBay sellers. These look very much like my blue begs that rotate and prices were all over the map for those. Edit: It looks like other sellers do have them. The2Wheels, which we all know for their levers, had some super short adjustable pegs. http://www.ebay.com/itm/CNC-Adjustab...f838d7&vxp=mtr |
June 23rd, 2014, 11:26 AM | #4 |
Sorry, I guess I wasn't thinking about fancier pegs.
I was just saying that you can make a set of rearset adjusters that would move your stock pegs straight back with just some plate aluminum. |
June 23rd, 2014, 11:33 AM | #5 | |
June 23rd, 2014, 11:34 AM | #6 | ||
I have rearset adjusters and shorter dogbones (raised suspension). Reading that thread prompted me to wonder what combining Buell pegs with my adjusters and suspension would achieve (more room without much reduction in ground clearance). The thing is, I have new colored pegs already that I'm not going to sacrifice for these. If I consider getting these it would be for one of the other bikes. Quote:
June 23rd, 2014, 11:49 AM | #7 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
I'm looking at the brakets and pegs from these guys: http://www.cyclepirates.com/main/index_2
Seem more solid. More expensive but worth it i think.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
July 2nd, 2014, 08:24 PM | #8 |
Inline 4!!!
$50? More like $65+
July 2nd, 2014, 08:25 PM | #9 |
Passenger Pegs & Brackets, Rider Pegs 2012 250r | GlassAnkles | Motorcycle-related | 2 | March 7th, 2012 11:17 AM |
DIY- Using the Passenger Pegs as Front Pegs | kkim | 2008 - 2012 Ninja 250R Tech Talk | 33 | December 6th, 2011 12:16 AM |
Buell XB Front Pegs | g21-30 | 2008 - 2012 Ninja 250R Farkles | 31 | September 22nd, 2009 06:07 PM |
