March 2nd, 2012, 12:04 PM | #1 |
Join Date: Mar 2012 Motorcycle(s): 1986 kawasaki ninja 250 Posts: 1
86' engine swap
Hey everyone, Im pretty new to the motorcycle world and im trying to figure some stuff out about the engine on my bike. I have a 1986 ninja 250 and im losing compression. im not exactly sure what to do.
One option im leaning toward is an engine swap. the only issue is i havent seen another 86 for sale around here. now my big question is would any of the other years mount up on an 86? from what ive read the engines for most of the year excluding the newest gen are basically the same. but what about the frame? if someone could let me know if i can do this it would be greatly appreciated (i dont have the money to buy an engine that wont fit) Thanks Chris |
March 2nd, 2012, 01:13 PM | #2 |
Welcome Chris, good luck with the bike.
March 13th, 2012, 07:06 PM | #3 |
It is possible but...
...it depends on your skill.
The '87 "E2" is the only other model that matches the '86 "E1." http://faq.ninja250.org/wiki/I_have_...s_different%3F This is an excerpt from that link: "You can swap any '88-07 (F series) engine into an '86-87 (E series) chassis by swapping the alternator cover and flywheel from the older engine to the newer engine. By swapping the alternator covers you swap out the wiring and ignition pickup coils. Once you remove the alternator cover on the 250, the flywheel is one bolt and a few special tools away. But, it does require (on a 1 to 10 scale) a 7+ skill/confidence level. So, if you don't have the kind of experience needed for this, the simplest way may be to take both engines (with alternator covers removed) to any decent automotive or motorcycle mechanic and ask them to swap flywheels. It should cost less than 1/2 hour labor for this work, depending." In what kind of shape is your '86? As you found with the engine, it's getting harder to find good parts for the '86 and '87. I'm looking for an unbent pair of forks for an '87 myself. A good set of plastics is even more difficult to find. You may be able to part your '86 out for enough to pick up a newer model in some areas. Best of luck! |
March 22nd, 2012, 03:52 AM | #4 |
Join Date: Mar 2009 Motorcycle(s): 87 Ninja 250, 90 Ninja ZX750R, GPZ 900r, 02 Moto Guzzi LeMans, 95 Triumph Speed Triple Posts: 121
Don't forget to keep the cams and carbs from the 86 if you do swap the engine. The 86-87 has the bigger 32mm carb instead of 30mm 88 onward and the 86-87 cams has a more aggresive profile for top end power at the expense of mid-range.
Dont forget to swap the clutch cover also as it has a sound dampen feature the later version don't have. The 86-87 are true sporting 250's but with each generation Kawasaki keep detune the engine for more beginner friendly mid-range as new riders don't spend time in 14k rpm heaven. If you can take out the engine and bring it to a mechanic to redo your rings, you might save some labor that way. |
March 22nd, 2012, 08:07 AM | #5 | ||
http://en.wikipedia.org/wiki/Ninja_250 Quote:
March 22nd, 2012, 07:20 PM | #6 | |
Well, actually in Japan where 250 and 400cc class are super competitive, some race teams still pick the 86-87 250's as their weapons of choice after its been out of production for 25+ years for a reason |
March 22nd, 2012, 07:34 PM | #7 |
huh, learn something new every day i guess
March 25th, 2012, 04:45 PM | #8 |
Beautiful. I wish we have more aftermarket pregen parts.
March 25th, 2012, 09:19 PM | #9 |
March 25th, 2012, 09:37 PM | #10 | |
geez that's what I payed for a pair of slipons, instead of for what should basically the same thing |
March 26th, 2012, 12:24 AM | #11 |
When Area P develop the full exhaust system for the pregen's, they thought its going to sell boat loads as it was one of longest production bikes for Kawasaki from 88-07, almost 20 years. When its release to the market it didn't sell anywhere near it should give the amount of bikes on the road.
People scream for aftermarket parts and support and when its there, people don't put the money where it counts. My guess is that pregen bikes resale value have something to do with it, if your pregen is worth $1,500, you'll think twice spending 1/3 of your bike's worth on exhaust systems. When I picked up the exhaust for group sale last batch before Area P shelf the system, Kerry was pretty dissapointed by the response to the pregen systems in terms of units sold. All the 86-87 250 racers I posted above are heavily modified and custom one off's and not many if anyone is going to spend time developing parts for bikes out of production that old. The front end conversion on these racers probably cost more then the bike and resale value is not high on priority list for dedicated race bikes. I'm not saying pregen's are not great bikes, in fact ,they're better street bike then 86-87 will ever be for better power spread and you don't have to ring the neck past 12k to get power but 86-87 do have more peak power. What the 86-87 got also is lighter weight compared to all generation of 250's as kawasaki try to make the pregen's and newgen's size wise to a 600 then a 250 so when you see all 3 gens together the 86-87's are almost toy like in its proportions but at the same token its not pretending to be somthing its not. |
March 26th, 2012, 01:54 AM | #12 | |
March 26th, 2012, 08:30 AM | #13 |
yeah and when AreaP made the pregen system, they did a group buy. I had literally just spent 300 on my Two Brothers slip-ons 3 weeks before. I couldn't justify getting ANOTHER exhaust system. I'm still pretty sore about that with myself. Seriously if I hadn't gotten over eager and waited a couple weeks, I would have found something that was loads better for the same price. I think the GB price was like 325+shipping
engine swap | iflylow | General Motorcycling Discussion | 4 | October 24th, 2017 12:30 PM |
engine swap questions | Honda JEB | General Motorcycling Discussion | 6 | December 13th, 2013 07:59 AM |
engine swap | ubxssangz | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 28th, 2013 08:29 PM |
Engine Swap question | Bigballs | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 12th, 2013 12:03 PM |
engine swap | almanza2010 | 2008 - 2012 Ninja 250R Tech Talk | 12 | March 16th, 2011 11:50 AM |
