Old April 4th, 2019, 03:43 PM   #1
minimatt
minimatt's Avatar
Is this a master link for my chain? (pic)
Hi guys,
My bike is in need of a chain replacement. Just wondering if this looks like a master link to you? I've heard the chains on the '08-'12 Ninjas are welded together in factory. However, I'm not sure if this is the original chain.
minimatt is offline   Reply With Quote
Old April 4th, 2019, 04:41 PM   #2
ducatiman
ducatiman's Avatar
that is, indeed, a rivet type master link
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old April 4th, 2019, 04:47 PM   #3
minimatt
minimatt's Avatar
Thanks so much! Will I be able to remove this easily with a chain breaker?
I'm quite at the bottom of the learning curve when it comes to servicing motorcycles but it definitely saves going to a mechanic.
I'm hoping to do a full chain and sprocket replacement on this bike.
Old April 4th, 2019, 04:56 PM   #4
Ceeloo Yello
Motorcycle(s): 250
you could also just cut through it with a hacksaw or dremel.
Old April 4th, 2019, 05:08 PM   #5
ducatiman
ducatiman's Avatar
Before removing the chain, loosen any front sprocket nut(s) by putting the bike in gear while applying the rear brake....to prevent the sprocket from spinning as you are removing its hardware. Aids in front sprocket removal.
Then simply grind the peened over edges flat on the master link and employ your breaker.
OPTIONAL ... as the worn chain is headed to the recycling bin anyway, utilize a disc type cutting tool (electric or air driven) and cut through a connecting link anywhere.
Takes all of about 15 seconds.
Good luck with it.
Custom Carb Service
Old April 5th, 2019, 06:37 AM   #6
The chain appears to be dry and rusty, which means it has not been regularly lubed. Don't let that happen to your new chain.
Old April 5th, 2019, 07:26 AM   #7
minimatt
minimatt's Avatar
Good luck with it.
Thanks, I don't have a dremel or anything laying around so I'll most likely use a chain specific breaker and riveting tool. Would it be possible to do this without grinding the edges?
This bike has been extremely neglected. I'm the 5th owner, which I assume all 5 of us were most likely begginer bikers. Still no excuse to neglect a motorcycle.
Pressed Master Link Too Tight On New Chain z0sum 2008 - 2012 Ninja 250R Tech Talk 9 February 27th, 2017 02:34 PM
Can I use an RK XSO Master Link with an SO chain? daverdfw Ninjettes At Speed 10 January 10th, 2017 05:38 PM
More chain trouble: 2-month old chain, O-Ring failure at master link. :( What now? CZroe 2008 - 2012 Ninja 250R Tech Talk 56 July 7th, 2012 05:42 PM
Adding a rivet master link to the stock chain ??? Tiane 2008 - 2012 Ninja 250R Tech Talk 1 June 13th, 2012 12:58 AM
Request: Silver chain, gold master link. Mountain Dew Pictures 3 January 25th, 2012 08:24 AM
