Old May 22nd, 2012, 02:43 AM   #1
karlosdajackal
karlosdajackal's Avatar
Motorcycle(s): Ninja 250R Fuel Injected Model 2009
Rear brake "sticky"
So if i use my rear brake, when I get of the bike its hard to push it around.
Its like the brake is not releasing fully. However if I have a bit of a hill so I can reverse the bike for a bit it seems too loosen up quite a bit to the point i can move it around more comfortably.
Any Ideas?
My vlogs on Youtube are here
karlosdajackal is offline   Reply With Quote
Old May 22nd, 2012, 03:33 AM   #2
Gorilla25
Dakine...
Gorilla25's Avatar
Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon)
worn out return spring? dirty calipers? dirty piston? leaking seal? stuck pedal?..could be a lot of things. need more details. how long has it been like that? when was last brake change? last fluid change? etc..
Gorilla25 is offline   Reply With Quote
Old May 22nd, 2012, 06:00 AM   #3
I would lubricate the guides of the pads, if a full service and cleaning is not possible.
Old May 22nd, 2012, 07:44 AM   #4
And don't mix brake fluid types.
Old May 22nd, 2012, 10:27 AM   #5
Francis
ninjette.org newbie 2,000
Motorcycle(s): Ninja 250r
You can mix brands, but not type (DOT 3/4/5). Correct me if I'm wrong though, this is the information I ran into when I had to bleed my brakes.
Francis is offline   Reply With Quote
Old May 22nd, 2012, 11:17 AM   #6
Sorry, for not being clear enough. Right, don't mix DOT 3/4/5.
Old May 22nd, 2012, 11:29 AM   #7
there are exceptions, like if i remember you can put dot 5.1 in 4, but not 5 in 4 or vice versa.
if the brake is sticking, its dangerous to ride on it. at very least bleed the fluid and unstick the pistons. push them out and clean the surfaces then push them back in. make sure you flush the brake line / passages to get all the crap out
Old May 22nd, 2012, 06:18 PM   #8
leed
leed's Avatar
Motorcycle(s): Time will tell
I also think 3 and 4 can go together, but 4 and 5 cannot?
Just did a little google search: DOT 3, 4, and 5.1 are hygroscopic (big word that says it readily absorbs water from humid air, basically) and they are (polyethylene) glycol based.
DOT 5 is silicone based and as such is hydrophobic (repels water). DOT 5 has a higher boiling temperature, and in addition better maintains its viscosity at high temperatures. Lastly, it's also a plus because it is not caustic (or at least not quite as bad). It's downfall is that it absorbs air instead.
By mixing 3, 4, or 5.1 you will essentially adjust the boiling temperature.
"RACE" rear brake reservoir delete? garth285 2008 - 2012 Ninja 250R Tech Talk 38 March 20th, 2016 05:58 PM
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl Ninjette Newsbot Motorcycling News 0 August 16th, 2012 04:30 PM
Poor Top End Power and Throttle Response, High "sticky" Idle yukongt94 1986 - 2007 Ninja 250R Tech Talk 12 April 22nd, 2011 12:13 AM
Trailbraking Discussion - Spinoff from "Rear Brake" Thread muffinman Riding Skills 21 July 2nd, 2009 05:40 PM
