Old January 26th, 2014, 09:38 PM   #1
Konaunit1
Motorcycle(s): 2005 FZ1. 08 DR650, 10 ninjette 250, 03 R6 (race bike)
Fan on a race bike
Building a 2010 for the upcoming race season. Are you guys running fans in your bikes? Just wondering I don't have one on my R6. Thanks!
Konaunit1 is offline   Reply With Quote
Old January 26th, 2014, 09:52 PM   #2
ahamay
Motorcycle(s): Tree Hundred
I left my fan on the bike only because a buddy who took his off over heated his bike on the starting grid. It was a hot day and someone had a mishap on the sighting lap before the race. Before he realized how long he was gonna sit there the temps got to high and he missed his race.
Interested to see what others are doing but I think the temps get to high in socal to not have the fan.
ahamay is offline   Reply With Quote
Old January 26th, 2014, 09:55 PM   #3
Many delete the fan on dedicated track machines.
Old January 27th, 2014, 05:53 AM   #4
Konaunit1
Thanks! It's pretty rare that the temps get warm enough up here in WA to overheat to quick haha? I might take it off. Not sure that it is enough weight to really get hung up on though.
Thanks!
Old January 27th, 2014, 06:41 AM   #5
DCMoney
DCMoney's Avatar
Thanks!
The fan and bracket weight more than you think.
Mine came off both bikes.
MCRA.com
Old January 27th, 2014, 10:57 AM   #6
iZapp
former ninja 250'er
iZapp's Avatar
Motorcycle(s): Aprilia 1000R, CRF450, CBR600RR tracktoy, Ninja 250 -- GONE!!!!!
hell i dont even have a fan on my daily driver ('00 Tundra)!
it was damaged when i bought it 5 years ago and i've never replaced it. only been an issue a handful of times since, stuck in traffic/hot day.
but on a racebike, just keep an eye on the temp and if gridded longer than normal, just shut the thing off. problem solved. if you're overheating WHILE moving - you're GOING TOO SLOW!
iZapp is offline   Reply With Quote
Old January 28th, 2014, 01:44 PM   #7
sprinter
Motorcycle(s): 2018 Ninja 400 Race Bike (in progress...)
I always take the fans off on my race bikes, never had a problem.
sprinter is offline   Reply With Quote
Old January 29th, 2014, 08:13 AM   #8
Konaunit1
I will be pulling it off later. Thanks for the info.
Old January 29th, 2014, 08:15 AM   #9
Konaunit1
If i am going that slow on the race track somebody just needs to kick me off the track haha.
Old January 29th, 2014, 05:58 PM   #10
mgentz
Board Member
The issue comes in more on the cool down lap or when waiting for the flag to drop. However this should not be a big deal. Even removing it on the street would hardly be an issue depending on where you live.
Old January 29th, 2014, 06:07 PM   #11
we run regularly above 100f temps here and most remove the fan. its not needed if you aren't going to be sitting still (i should hope you're not sitting still while racing)
Old January 30th, 2014, 12:34 PM   #12
simook
Convinced me to remove my fan also. But could someone enlighten me on the benefit of removing the thermostat and housing?
simook is offline   Reply With Quote
Old January 30th, 2014, 12:59 PM   #13
if you have trouble overheating because of massive modifications leading to way too much heat being produced overloading the cooling system, removing the thermostat will allow a bit more flow of coolant through the system. it's a bad idea on a regularly functioning engine because the cooling system is adequate enough and having the cooling system always-on by removing the thermostat means that the engine may drop below ideal operating temperature... ideally you have a thermostat with a bipass to maintain coolant flow while still being able to cut out the radiators cooling effect.
not having a smooth transition of cooling effects means that the head and cylinders get heated/cooled back and forth many times which as we know can weaken metal and causes size changes and warping if its not a consistent heating and cooling... in extreme cases you can cause fractures. the thermostat is a clay pellet valve that expands and contracts slowly so you really shouldn't get this type of issue with a working thermostat, but if you have no thermostat and go from 100mph down to 15mph and back to 100mph, the cooling going into the coolant varys drastically and since you have no thermostat to control it with, its more likely to vary temp through a wider range..
basically, unless you have a turbo and are running 19-1 compression, leave the thermostat in. or upgrade to a thermobob (bipass thermostat)
even in the cases i described, the correct solution would be probably a bigger radiator, not removing the thermostat
Old January 30th, 2014, 01:04 PM   #14
simook
So for a race only bike...?
Old January 30th, 2014, 01:14 PM   #15
for no bike do you remove thermostat.
Old January 30th, 2014, 01:45 PM   #16
simook
Makes perfect sense to me, I'm just trying to figure out why it seems so many people remove the thermostat.
Old January 30th, 2014, 01:47 PM   #17
because they think they know what they are doing
Old January 30th, 2014, 05:54 PM   #18
mgentz
Board Member
Leave it in.
Old January 30th, 2014, 06:17 PM   #19
Ben M
Ben M's Avatar
Originally Posted by mgentz View Post
Leave it in.
...That's what she said
Ben M is offline   Reply With Quote
fan noise when the bike is on yogurtpooh 2008 - 2012 Ninja 250R Tech Talk 27 November 25th, 2014 10:07 PM
[kropotkin thinks...] - 2013 Istanbul World Supersport Race Results: The Race The Fan Ninjette Newsbot Motorcycling News 0 September 15th, 2013 04:00 AM
[motorcyclenews.com - news] - Goodwood Festival of Speed – Lord March is a bike fan Ninjette Newsbot Motorcycling News 0 July 9th, 2013 09:30 AM
[motorcyclenews.com - news] - Goodwood Festival of Speed – Lord March is a bike fan Ninjette Newsbot Motorcycling News 0 July 9th, 2013 03:20 AM
Putting the bike on a diet - Thermostat housing removal + radiator fan 675Raisinator Ninjettes At Speed 4 July 11th, 2012 09:53 AM
