May 14th, 2015, 09:16 PM | #1 |
Join Date: Feb 2012 Motorcycle(s): 2010 Ninja 250R SE Black and Red Posts: 18
2010 Turns over then dies
I am about to go flipping crazy. Bike has been sitting for a few months in garage during harsh NYC winter. At first, bike wouldn't turn over, just cranking.
*Every time I start it is on full choke since anything less will have it die or not turn over at all" Took apart the bike, cleaned carbs, fresh gas, changed oil, and charged battery (Took it to Autozone and they said it was fine). Now it turns over but then dies almost immediately (about 2 seconds after). Sprayed some starter fluid and it stayed sputtering and idle ish after it turned over for about 10 seconds more but then dies again. I HAVE NO IDEA WHAT TO DO. Please help me! I am running out of ideas. I feel like I am getting close but I am about to lose it. It is only about 1,000 miles old. I can try to put up a video tomorrow night. |
May 14th, 2015, 09:32 PM | #2 |
Bummer Norman... It has to be one of the big 3, gas, air or spark. Let's do the checks in the order of simplicity though;
Lastly, have some patience and keep working with it. It may take some time to fully prime up the carbs after a long stent in storage. It took my 250 30 mins to fully come alive after 4 months in storage over the winter. Nothing was wrong with it, because I tracked it the very next day.
May 14th, 2015, 10:54 PM | #3 |
cadd cadd cadd
MOTM - May '15
Was it running ok before you had it in storage during the winter? Did you put any fuel stabilizer in the tank during winter?
Is the petcock working ok? Try to set it to PRI and see if gas is dripping out. Try to start it on PRI Also, how did you clean the carbs? Did you use a thin copper wire to clean out the main and pilot jets? They may look clean (can even see light through the holes), but may not be clean. Also, the air/fuel mixture screws. Did you take those out as well and soak them in carb cleaner? Where did you spray starter fluid? If it starts for 10 seconds, try spraying it onto the boots (between airbox and carbs & between carbs and motor) to see if there's any change in idle. If there is, there's a vacuum leak somewhere.
Riding it like I financed it. |
May 15th, 2015, 07:16 AM | #4 | |
If those are dry, I would first verify that fuel is flowing down. If not, apply vacuum to the petcock while the hose is disconnected from the nipple. If still you see no flow, the mesh filter inside the tank is clogged and needs to be counter-flushed. There is also a tiny mesh filter inside the house, in the lower end, that needs cleaning.
Motofool .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí Last futzed with by Motofool; May 15th, 2015 at 04:55 PM. |
May 15th, 2015, 11:18 AM | #5 |
Your carburetors need a proper cleaning, I would recommend PM @ducatiman he's close by on Long Island.
How far can you look through the turns? | csmith12 | Riding Skills | 88 | April 28th, 2015 12:49 PM |
what turns you have problem with the most...? | RJprod | Riding Skills | 12 | June 6th, 2013 07:44 AM |
Downshifting for turns | dcx4610 | Riding Skills | 106 | October 24th, 2012 01:31 PM |
Taking turns | TnNinjaGirl | Riding Skills | 51 | August 3rd, 2012 04:32 PM |
U-turns on a Ninjette | akima | Riding Skills | 14 | October 13th, 2011 12:00 PM |
