Old September 23rd, 2023, 11:35 PM   #1
Kv19xx
Motorcycle(s): 2004 kawasaki ninja ex250
Exclamation 04 ex250 brake pad replacement
Can someone help me figure out how to replace the front and rear brake pads on my gen 1 ninjette? It's my first bike and I would like to know how to do my own work and maintenance on my bike. If you have any questions please feel free to ask.
Kv19xx is offline   Reply With Quote
Old September 24th, 2023, 05:14 AM   #2
Hi Kirby, welcome to the board!
Start here and see if you still have any questions: https://faq.ninja250.org/wiki/Brakes
Last futzed with by Triple Jim; September 24th, 2023 at 09:12 AM.
Old September 24th, 2023, 10:13 AM   #3
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome to the board!
Changing brake pads isn't all that hard. Look at the exploded drawings, and pay attention when you take things apart. It can be a little tricky getting the pads out and then the new ones in, but even that isn't all that hard once you get the feel for it.
Old September 24th, 2023, 01:00 PM   #4
ducatiman
ducatiman's Avatar
2 brake jobs completed here in the last week both performed on family owned Toyotas, a Rav 4 and my own Toyota Matrix. At 100k miles, did all 4 wheels on Rav, new front discs and pads all around, cleaned up and bled all 4 as well.
At 80k miles the Matrix just got new front pads with an intensive disc/caliper cleanup, while repainting both calipers.
Both vehicles use 2 piece (sliding) calipers requiring some extra service steps to achieve that factory like- new performance....comes with the territory. Both vehicles feel and stop like brand new.
Bike brakes relatively simple in comparo.
Custom Carb Service
Old September 24th, 2023, 01:33 PM   #5
Greetings & Salutations!!
This board has all info you to any maintenance procedures you may need!
YES! Look at diagrams on how parts fit. And take photos after removing each every nut, bolt and individual component so you can put it back together in reverse order. Some notes on top of Brake FAQ linked above:
1. cleaning brake pistons before pushing them back into caliper. No need for complicated procedures for rotating pistons to clean other side. Use shoelaces dipped in brake-fluid to wrap around piston, then floss it back & forth to clean piston all around.
2. remove reservoir cap before pushing pistons into caliper. This prevents incoming fluid from trying to compress air-space at top of reservoir. Easier to push pistons
Last futzed with by DannoXYZ; September 24th, 2023 at 07:08 PM.
Old September 28th, 2023, 12:34 AM   #6
Kv19xx
Thanks guys!
I appreciate the greetings!
Thank you all for your help I'm going to use all the advice and help you guys sent. I'm going to change them out on Friday and I'll post and let you guys know how it went!
Thank you all so much. Danno, triple Jim, Caligrrl, and ducatiman!
Rear brakes - pad replacement Bill N 2008 - 2012 Ninja 250R Tech Talk 8 January 30th, 2014 03:24 PM
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 1 May 30th, 2013 08:13 PM
Rear Brake Pad Replacement neff 2008 - 2012 Ninja 250R Tech Talk 12 April 8th, 2013 06:22 PM
New Brake Pad=New Brake rotors???? kenji_808 2008 - 2012 Ninja 250R Tech Talk 3 July 20th, 2011 06:34 AM
Timing my pad replacement headshrink 2008 - 2012 Ninja 250R Tech Talk 7 April 16th, 2009 09:24 PM
