April 9th, 2013, 08:56 PM | #1 |
Shifting Issues.
Hello, I'm trying to fix a Ninja 250r that has been parked up for awhile due to a shifting issue. I have it running but it just won't shift out of neutral. The story i got from the owner was "I was riding it and shifted into the neutral and it just wouldn't go into gear". I was wondering if any of you guys/gals could help me out with trying to diagnose the problem.
April 9th, 2013, 08:58 PM | #2 |
Are you riding the bike at the time, or is it stopped? The kawi neutral-finder feature prevents the bike from shifting up into second unless the bike is moving over a certain speed, keeping it in neutral. Will it not shift into first from neutral either?
April 9th, 2013, 09:02 PM | #3 |
Step one, put it on a stand and try to run through the gears with the engine off, turning the rear wheel by hand as needed.
Let us know!
April 9th, 2013, 09:03 PM | #4 |
OH!
Welcome Ryan!
April 9th, 2013, 09:04 PM | #5 |
The bike is stopped. I can't get it into to go into first at all. and thanks for the welcome!
April 9th, 2013, 09:19 PM | #6 |
April 9th, 2013, 09:22 PM | #7 |
The next simple thing would be the clutch lever and cable. All seem to be working right and adjusted within a workable range?
April 9th, 2013, 09:35 PM | #8 |
April 14th, 2013, 11:47 PM | #9 |
Join Date: Mar 2013 Motorcycle(s): 05 Kawasaki Ninja 250R Posts: 37
When you kick it down to go into first is it a smooth slide or does it click, Or does it not even make the full range of motion to go down? Try loosening the clamp that holds the linkage on the spline and setting it to a position or even flipping it to make first an up kick instead of down.
April 25th, 2013, 11:05 PM | #10 |
I finally got some time today to check it out. I drained the oil and took the clutch basket off and found the spring that holds tension on the clutch levers was missing after i looked around a bit i found a small spring that i put on for a temp fix and i can get into first with no issues. So hopefully in a week or so ill have it on the road again.
Any shifting issues please tell your story | ztrack157 | 2008 - 2012 Ninja 250R Tech Talk | 64 | August 28th, 2023 06:36 AM |
Shifting issues when warm | mr2peak | 1986 - 2007 Ninja 250R Tech Talk | 10 | August 31st, 2014 02:54 PM |
Shifting Issues | LinnaLane | 1986 - 2007 Ninja 250R Tech Talk | 7 | August 2nd, 2014 09:09 AM |
2005 - shifting issues | gogiburn | 1986 - 2007 Ninja 250R Tech Talk | 0 | July 4th, 2010 09:04 PM |
Shifting | haligen | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 23rd, 2009 05:31 PM |
