Old July 9th, 2014, 04:00 AM   #1
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
front brake issue
so i wheeled the 250 out of the shop this morning. i noticed yesterday that i was feeling a slight pulse with the front brake. this morning i heard a grinding noise at one spot on the rotor. pads are getting thin but not enough to think they are getting the backing plate into the rotor. alas i had to take the 650 to work instead. will have to check things out this sunday. will definantly be going with better pads up front. i see there is a bracket you can buy to offset a caliper. is that just to use a larger caliper? is there a larger rotor from another kawi that would fit the little ninja? bike has 7,300 miles so its time to put it down for a bit and check the valve lash. might as well catch up on the other things i've been wanting to do.
Last futzed with by gantt; July 9th, 2014 at 12:59 PM. Reason: poor grammar and spelling
gantt is offline   Reply With Quote
Old July 9th, 2014, 01:00 PM   #2
gantt
gantt's Avatar
wow 25 views and no advice? i know i botched up the post with bad typing and such but still, no hits???
Old July 9th, 2014, 01:04 PM   #3
7500 miles is about normal for the front pad to be toast on a new-gen.
Old July 9th, 2014, 01:55 PM   #4
My bad, I was one of those 25 views but had no time last night. Anyway...
The bracket you saw in another thread will allow for a larger rotor, a non stock size. Looks to be about a $250-$300 investment in parts that may or may not fix your specific issue.
As Alex pointed out, you could be due for a pad change anyway. Do you know how to check the spec pad thickness for replacement? I would start there, if you still get pulsing, then it's time to check out your rotor and caliper. The rotor for trueness (straightness) and the caliper for sticking and general proper operation. And as always, check the torque on your bolts.
Old July 9th, 2014, 02:02 PM   #5
cuong-nutz
cuong-nutz's Avatar
Yup to what Alex said. The offset bracket is for bigger brakes combined with a larger rotor.
The stock hardware is plenty for most street riders. Most cases all you need are better brakes. Ebc HH pads are a great pads to replace the stockers.
HalfFast Racing Team
Old July 9th, 2014, 03:51 PM   #6
gantt
gantt's Avatar
OK thanks guys. Pads are thin. Time to replace. I admit I have been slightly neglectful on this bike. I needed to go into the carbs last year when I bought it.
I will check the rotor for warpage. I don't think I torqued the rotor bolts last time I had it off. Just tightened them with a ratchet wrench. Never crossed my mind really. As for the larger rotor, I've never been satisfied with the stock front brake setup. When I came off a supersport to my ex650 the brakes felt wooden. But the 250's feel like a dog turd in place of a caliper piston. Really not looking to spend that much on a larger rotor setup now. Maybe in the future. Do you have to buy an aftermarket rotor or is it a stock rotor from a different model bike? Thanks for the replies!
Old July 9th, 2014, 04:17 PM   #7
if its not used much it could just be some simple surface rust on the rotor. if thats the case it goes away after 50 miles or so. if however the bike has been crashed or abused or something it may just be a warped rotor. i doubt that pads of any condition would give a pulsing sensation. water in the brake line can sometimes cause pulsing. but typically pulsing either means warped rotor or some surface rust.
Old July 10th, 2014, 02:40 AM   #8
gantt
gantt's Avatar
I ride two bikes but the 250 is the primary ride. I ride every day to work,50 miles a day. No rust. I am rather hard on the brakes. I run this bike pretty hard though I'm sure people that track them are harder on the brakes than I. I have felt an odd sensation in the master cylinder for several weeks. When I apply the brake lever with force it has a almost dry feel. Like its not lubricated. Makes a slught popping sound/feel and binds up. What I'm trying to say is its not smooth but has a jerky feel as you pull in the lever. Related?
Old July 10th, 2014, 04:05 AM   #9
dandj86
dandj86's Avatar
Motorcycle(s): '09 Ninja 250R
Brembo/Tokico Caliper adapter
Hey gents!
Perhaps there might be some confusion surrounding the caliper adapter that you are thinking of, and whether or not a non-standard rotor is required.
Over on this thread here, @Bigballsofpaint has machined and is supplying two different types of adapters; one to suit a 4-pot Brembo caliper with a 320mm rotor (expensive option), and the other to suit a 4-pot Tokico caliper with the stock rotor (dirt cheap option).
So all in all, you can upgrade your standard caliper to a 4-pot Tokico caliper and keep your existing standard rotor for a very decent price
dandj86 is offline   Reply With Quote
Old July 10th, 2014, 04:14 AM   #10
gantt
gantt's Avatar
Thanks. ^^^ so its aftermarket for larger rotor. No OE from another bike.
Old July 10th, 2014, 06:04 AM   #11
Bigballsofpaint
You can get an aftermarket rotor in the stock size, but i dont know of any stock rotor from another bike that fits our front wheels.
Old July 10th, 2014, 09:41 AM   #12
gantt
gantt's Avatar
Thanks big balls. I really thought about getting a bracket from you,though I can't justify it right now. I started a new job early this year and am having to invest in tools. So far I'm at $4500. And I took an initial pay cut. Things are tight and will be until the end of the year. I have the means to make one. Not near as pretty though.
Old July 10th, 2014, 09:53 AM   #13
Bigballsofpaint
Not trying to push you into buying one lol, just answering the rotor question. I understand money issues, no worries. Big trip to Cali planned in a few months and have been pulling from savings to cover it, and i have much more to go...
Old July 10th, 2014, 02:59 PM   #14
gantt
gantt's Avatar
And the rotor is warped. Pads are not past the point wear the pads are divided into two halves. I am going to look into an floating aftermarket in stock size. At least I have a little time to ride before I have to make a purchase/decision as to buying a used OEM or new upgraded aftermarket. I need to get off my ass and make a bracket. It won't be sexy exotic aluminum. Lol. Just steel.
Old July 13th, 2014, 08:39 AM   #15
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
FWIW, Amazon has a lot of stock OE parts cheap. Just came across a set of front AND rear brake pads, sintered HH, $21 and free shipping. That along with a decent used or new front rotor will get you out and about again for around $100 if you bargain shop the rotor. PartsNinja may have one in good shape, or eBay.
Old July 13th, 2014, 11:39 AM   #16
gantt
gantt's Avatar
I may try one of the fleabay knockoffs. I'm still riding on the rotor. Its not very bad. I'm sure it will wear out my pads faster. But I have a gsxr caliper on the way. Not too worried about the old pads that are on the bike at the moment. Thanks for the information.
Brake Light Issue/Front Master Rebuild? TDMX595 1986 - 2007 Ninja 250R Tech Talk 5 October 24th, 2014 05:23 PM
Front Brake Issue nitehawk 2008 - 2012 Ninja 250R Tech Talk 5 October 15th, 2013 09:40 PM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
fitment issue with front cowling Ausoi 2008 - 2012 Ninja 250R Tech Talk 7 May 1st, 2012 05:58 AM
Front brake issue. Myst420 2008 - 2012 Ninja 250R Tech Talk 1 May 17th, 2010 01:34 PM
