Old July 24th, 2013, 05:29 PM   #1
Runeknight95
Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only
Bike won't start, cleaned carbs, new gas, backfires whats next?
I was having a rough/staling idle so i cleaned the carbs, and can't get the bike to start back up.
-the carbs work flawlessly in a different bike
-Gas is brand new 87 octane-today, gas was added by using the prime option for a little bit then set to "on", I tried draining the bowls just in case i flooded them and still no luck
-The bike is backfiring every so often so i have spark(right?), but I will replace spark plugs anyway on Friday.
-The bike inches forward a bit when in gear and hitting the starter (so i think the starter motor is still good)
-The battery is fully charged before trying tests (battery tender has green light)
-I can say I checked and re checked all hoses and wires but youll say check it again :\
So what would be my next steps to get this bike to fire?
Is it an issue with timing of the spark and the fuel or lack of?
Is there a way to test the vacuum system?
Runeknight95 is offline   Reply With Quote
Old July 24th, 2013, 06:37 PM   #2
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
Do you have the air filter on it and buttoned up?
cookiebug79 is offline   Reply With Quote
Old July 24th, 2013, 06:57 PM   #3
Runeknight95
Air filter in, boots are lined up on all 4 sides and tightened down
Old July 24th, 2013, 07:38 PM   #4
Are you using choke? If so, I would turn it off after you hear any signs of life at all or after cranking for 5-10 seconds max. If it's on too long it may flood. Did you remove the idle mixture screw caps and change the settings? You may need to try different adjustments around 2 turns out.
Also try opening the throttle slightly while cranking with minimal or no choke.
Looking at the color of the plugs may give you some idea of a rich or lean condition.
You will most likely need to have the battery on a small charger if you are doing any amount of cranking.
Old July 24th, 2013, 08:04 PM   #5
Runeknight95
yes tried choke on and off
will try your suggestions and report back tomorrow
I did remove the caps of the idle screws to clean the, and returned them to stock settings
Old July 24th, 2013, 08:35 PM   #6
http://www.ninjette.org/forums/showp...&postcount=111
Old July 24th, 2013, 08:50 PM   #7
Runeknight95
Good stuff Cssmith ill let you know results tomorrow
Old July 26th, 2013, 09:53 PM   #8
Runeknight95
Hey guys i replaced the plugs and it fired right up , no idea how they went bad just by pulling carbs off?
Csmith I tried adjust idle screws to no avail, waited for the plugs before doing anything else, then it turns out I didn't need to do anything else!
Cleaned Carbs, Replaced Gas, Still having engine problems. azwillnj 1986 - 2007 Ninja 250R Tech Talk 161 June 19th, 2017 08:03 PM
Won't start after pulling carbs Insan3guy 1986 - 2007 Ninja 250R Tech Talk 10 July 17th, 2013 07:12 AM
What acceleration? carbs cleaned MrSavvy 2008 - 2012 Ninja 250R Tech Talk 25 April 12th, 2013 01:47 AM
HELP! Cleaned carbs, fixed ninja, now broken again!! synapsekiller17 2008 - 2012 Ninja 250R Tech Talk 19 November 18th, 2010 11:22 AM
