September 17th, 2013, 10:14 AM | #1 |
time is running out....
Join Date: Sep 2012 Motorcycle(s): pregen ninjari Posts: 412
bike won't start. tried everything
so the bike doesnt start. nothing. battery is good..
touch both starter relay terminals together and it cranks... a working running same year ninja pulls into garage. i use his fusebox, voltage regulator. ignition switch, start/kill button, cdi box and starter relay....same....thing. put all this back on his back. his starts and he drives home.... so today i bought a new wiring harness. odd. i dont get it. my harness doesnt look damaged anywhere in other news..
The King |
September 17th, 2013, 10:38 AM | #2 |
You will need a voltmeter-ohmmeter and a lot of patience.
You may need to check if your generator is supplying enough juice. Check this thread for a similar case: http://www.ninjette.org/forums/showt...reaking&page=4
September 17th, 2013, 10:40 AM | #3 |
Did you swap coils?
September 17th, 2013, 11:01 AM | #4 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
safety switches?
-clutch -neutral -kickstand
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
September 17th, 2013, 11:08 AM | #5 |
September 17th, 2013, 11:16 AM | #6 |
those were deleted last year. drove it a year like that.
stator or not. bike should crank though.
The King |
September 17th, 2013, 02:46 PM | #7 |
Check for corrosion on the start button itself. I had a mystery issue like that with my horn and turned out it was just corrosion on the metal pieces of the button.
September 17th, 2013, 03:00 PM | #8 |
Join Date: May 2013 Motorcycle(s): '89 klr 650, '00 250r Posts: 177
did it start after you cranked it? if not then check if plugs are sparking. pull the spark plug wires and use a spare spark plug, ground the threads against the engine and check for spark.
September 17th, 2013, 03:17 PM | #9 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
what makes you think it's electrical in the first place? the complexity?
you need fuel, spark, and air. what do you have? what's coming out the exhaust? keep it simple
Trust me, I'm a banana! |
September 17th, 2013, 03:23 PM | #10 |
So it doesn't crank unless you jump the starter terminals - right?
If so, you need to look at a wiring diagram and locate the wires and path they take. Check for power at numerous points in the system and isolate where it stops. It's possible it could be corroded contacts at the button as MasterCylinder noted. |
September 18th, 2013, 02:53 PM | #11 |
even if it doesn't crank when pushing the starter, bypassing the solenoid and cranking it that way should start it. you are just bypassing one of the starting system mechanisms. if it doesn't start but cranks when bypassing the solenoid then there is an issue somewhere else.
September 19th, 2013, 07:19 AM | #12 |
Most of the time when a ninja doesn't start, its the carburetors. If you have to short the solenoid terminals to crank it, then that's an additional problem.
September 21st, 2013, 03:02 PM | #13 |
i guess no1 read the first post...
new harness didnt fix it either
The King |
September 21st, 2013, 03:23 PM | #14 | |
Hope you find the problem on your own !!!
September 21st, 2013, 04:32 PM | #15 |
Your first post says that your bike will crank, but not start. Why are you changing the electrical harness before you know what is wrong? Have you at least checked to make sure you have spark? If you have spark, then the most common cause of a no-start condition is the carbs.
September 21st, 2013, 07:11 PM | #16 |
turn the key to on. hit start button..nothing happens. nothing..like a dead battery. but battery is good and checked.
everthying minus the motor itself n stator hav been replaced and it still does nothing. but touch starter relay terminals n it cranks. has nothing to do with carbs or spark... ..its magic. or must be low on starter fluid?
The King |
September 21st, 2013, 08:02 PM | #17 |
Starter button (post #7) or starter relay.
If not, trace the power - as I mentioned in post #10. Last futzed with by jkv45; September 21st, 2013 at 09:19 PM. |
September 22nd, 2013, 04:46 AM | #18 |
Its starting to sound like you are saying that the bike runs ok, but it wont crank. That's a totally different diagnostic.
So do the dash lights come on with the ignition switch? Does the neutral light come on? Kill switch flipped down? Fuses OK? You said you shorted the terminals on the starter relay, but those terminals are not accessible. You probably mean the starter solenoid which has big nuts that are accessible. That said, you have to get an ohm meter and track it back to the fault.
Help!!!!!!!! - bike won't start | auntymunga | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 18th, 2014 06:54 AM |
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
Bike won't start | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 127 | November 17th, 2013 03:18 PM |
bike won't start... | nebraskan | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 11th, 2011 01:48 AM |
