Old July 10th, 2012, 05:14 PM   #1
Redgeneral
Redgeneral's Avatar
Motorcycle(s): '09 Ninja 250r (SOLD) - Black. 2011 ZX-6R Green/Black - 2001 Garbage Bag Green KLR650
Driven Clip-ons Installed
Like the title says I installed my Driven Clip-ons that I purchased from bohemian racing.
Install went very smoothyl because of Forceofwill's DIY. Here: http://www.ninjette.org/forums/showthread.php?t=97552
The only thing I had to do additionally was to turn the brake line coming off the front reservoir so that it was horizontal instead of vertical, which allowed me to clear all the body work and gauges.
Redgeneral is offline   Reply With Quote
Old July 10th, 2012, 05:23 PM   #2
Redgeneral
Redgeneral's Avatar
After the install (and letting the lock-tite set) I took it out for a 75km ride to test them out. And WOW what a difference, I'm 6' 165lbs with long arms and this made all the difference in comfort. It's definitely a lot harder on your back and core, but the stretched out feel these give you is awesome.
Glad I picked them up, and would recommend them to anyone that's a bit taller if you're feeling a cramped up on the stock bike.
Old July 14th, 2012, 05:26 PM   #3
Malicious Logic
hates stupid people
Malicious Logic's Avatar
Motorcycle(s): 2005 ZX6R
I must know how you got these to clear! lol, I can't get my risers to not rub on the black cowling.
My vlogging channel: Ma1iciousLogic
Malicious Logic is offline   Reply With Quote
Old July 14th, 2012, 06:27 PM   #4
Redgeneral
Redgeneral's Avatar
Which part is rubbing, can you take a picture?
Just so you know, I don't have the risers tilted at all, just angled.
Old July 15th, 2012, 08:14 PM   #5
Malicious Logic
hates stupid people
For me, it's the riser that's rubbing on the black cowling. Here are some pics I snapped earlier with my drift. It's not much but enough that I can't claim them to be clear lock-to-lock.
This me the part that rubs on the black cowling. This is the right side
Here it is making contact on the left side
Proof that it's actually rubbing
Old July 16th, 2012, 05:52 AM   #6
Redgeneral
Redgeneral's Avatar
Let me check when I get home from work tonight and I'll compare your pictures to my bike. I'll see if I can help.
Old July 31st, 2012, 04:05 AM   #7
NiJen
NiJen's Avatar
Motorcycle(s): 2010 Ninja 250R Limited Edition
G'day, gents!
I don't mean to butt in, but I'm kinda interested to know if you've managed to get the clip-ons to not rub against the cowling. I'm thinking of getting a set of Drivens myself.
Cheers!
NiJen is offline   Reply With Quote
Old July 31st, 2012, 05:20 AM   #8
Redgeneral
Redgeneral's Avatar
Mine don't rub, but I haven't had a chance to take those pictures yet.
Let me know which pictures to take and where would help most.
Old August 8th, 2012, 02:02 PM   #9
NiJen
NiJen's Avatar
Hey Nick,
Can you please take a pic of the clearance between the clip-on and the cowling at full lock? I'd also be interested to see the horizontal angle of the bars (top view) and the distance of the clip-on clamp to the underside of the triple clamp if it's not too much to ask.
Cheers!
Old August 8th, 2012, 02:53 PM   #10
Redgeneral
Redgeneral's Avatar
Originally Posted by NiJen View Post
Hey Nick,
Cheers!
Ask and you shall receive!
Some of those pics are hard to see, it's really hard to get a good pic at full lock with all the cables. I'll put up all the pics I took and maybe you'll see something you need in those cluttered ones.
They were all taken with a blackberry, since I don't actually own a camera.
Old August 9th, 2012, 05:03 AM   #11
NiJen
NiJen's Avatar
Thanks, mate!
Looks like you just managed to not touch the cowling, well done.
Old August 9th, 2012, 05:31 AM   #12
Redgeneral
Redgeneral's Avatar
Thanks, mate!
Actually I took a good look at it while I Was taking the pictures, and it does in fact make contact with the cowling on the left. Just barely but it still touches. I think if you moved your bars out to more of a flat position - - instead of pulled towards you / \ it would avoid the cowling. Though you'd have to find the right spot for comfort.
Hope this helps!
Old November 28th, 2012, 09:35 PM   #13
Mowgli
Motorcycle(s): None yet
Op how are you clearing anything at all! Aren't the clip ons supposed to go right under the top plate of the tipple crown? I see everyone else has them like that exempt you. If I moved mine down at all they would hit just about everything
Mowgli is offline   Reply With Quote
Old November 28th, 2012, 10:20 PM   #14
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
Motorcycle(s): 2007 Sportster XL1200C
Not to hijack, but these seem like the clip-ons have risers. Woodcraft has a set of clip-ons as well; they also come with 2.5" risers for the clip-on to clear the fairings.
ricomtzjr is offline   Reply With Quote
Old November 29th, 2012, 07:34 AM   #15
Redgeneral
Redgeneral's Avatar
In my last post I said that I am making very light contact with the fairing on the left, enough to leave a smudge but not damage the fairing.
And yes, Driven clip-ons made for the 2008-2012 ninjette have 2.5" risers (IIRC).
Old April 30th, 2015, 09:38 PM   #16
OdysseyOfJ
Motorcycle(s): 2006 & 2008 EX250s
Are you able to have these clip-ons at it's highest mounting (up against the top triple) without interference problems?
OdysseyOfJ is offline   Reply With Quote
Old May 1st, 2015, 05:47 AM   #17
Redgeneral
Redgeneral's Avatar
I think you probably could put them up at the highest mounting point, but with the 2.5" riser on the Driven Clip-ons you would be so close to the stock height that it kinda defeats the purpose.
I had them lower because I'm fairly tall with a long arm span. So the idea was that the lower the clips ons were the more stretched out I would be, instead of being cramped.
Hope this helps!
Ebay clip ons installed Lucagst 2008 - 2012 Ninja 250R Tech Talk 11 March 31st, 2014 07:01 PM
WTB: WoodCraft or Driven Clip Ons key3thermal Items Wanted 0 April 23rd, 2013 10:18 PM
woodcraft clip ons installed NHrider19 2008 - 2012 Ninja 250R Tech Talk 1 August 5th, 2012 02:10 PM
Best prices for Driven Clip ons? jp129 2008 - 2012 Ninja 250R Farkles 6 February 15th, 2012 09:08 AM
Driven Clip-Ons cuong-nutz 2008 - 2012 Ninja 250R Farkles 10 December 28th, 2011 09:46 PM
