Old May 1st, 2023, 02:28 PM   #1
Muyguapo123
Motorcycle(s): ninja 250
Carb issue or not enough fuel
2012 ninja will start and idle, but only with choke on. If I take the choke off or give it any gas it will die. We used some seafoam, in the tank and also spraying into the carbs. No better. For some reason we started shaking the bike back and forth and it started to rev higher. Could this be a symptom for something related to my problem? Thanks.
Muyguapo123 is offline   Reply With Quote
Old May 1st, 2023, 03:25 PM   #2
ducatiman
ducatiman's Avatar
possibly sticking floats? dirty seats? pilot jets/circuits clogged? I'd suggest a carb pull/full inspection will determine the root cause.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old May 2nd, 2023, 12:13 PM   #3
Seafoam is largely ethanol, very last thing you want to be putting into your fuel-system. Ethanol is crap in modern gas that absorbs water, causes separation and tonne of corrosion and clogging issues. Seafoam is snake-oil, much like STP Oil Treatment from '80s. I've actually sat next to Andy Granatelli @ Rotary luncheon in Santa Barbara were he lamented about how much money he lost due to class-action lawsuits from STP. Seafoam's day will come...
Instead, use PEA-based fuel-system cleaner. Works much, much better:
  • Red Line SI-1
  • Techron Concentrate Plus
  • 3M Max Strength Fuel System Cleaner #08814
  • Royal Purple Max Atomizer 18000
  • Gumout All-in-One (might be off list soon due to lowering amounts of PEA)
Old May 2nd, 2023, 02:23 PM   #4
I agree with all in your post, Danno, but for the record, seafoam has equally unwanted isopropyl alcohol in it, not ethanol.
Old May 3rd, 2023, 06:40 AM   #5
ducatiman
ducatiman's Avatar
i'd suggest to add Stabil 360 to the list as well
https://www.goldeagle.com/product/sta-bil-360-marine/
Custom Carb Service
Old May 6th, 2023, 07:53 AM   #6
Guaire
Startron has ethanol. Startron says Starbrite attracts water and it gets run through engine. Usually, the water was in there in the first place due to ethanol.
Seafoam isn't alcohol. They've been in business since 1942. When I bought a EX250 a few years ago, the pilot jets were clogged. It was hard starting and it would not idle. It could only run at mid-range throttle and higher. I used sea foam treated fresh fuel and helped it start with Gum Cutter. In 15 minutes the pilots were cleaned, so the carbs didn't need a rebuild. After that the bike was running very well.
There are plenty of amateur videos on YouTube of documenting their use of Seafoam. Andy Granatelli is not connected to Seafoam.
Old May 6th, 2023, 09:09 AM   #7
I didn't say it's all alcohol, but it certainly has a fair amount of isopropyl alcohol in it, which I would never intentionally put in my gasoline. PEA is much more effective anyway.
Page 3: https://seafoamworks.com/wp-content/...161205-ENG.pdf
Old May 10th, 2023, 02:16 AM   #8
Amateur being keyword there. Any pro who makes a living servicing engines would not use Seafoam. PEA works so much better.
Granatelli/STP was used to illustrate how marketing works so much better than technical merits when it comes to selling products (i.e. selling refrigerators to eskimos). Same thing with Seafoam, its popularity is purely based on marketing. Sure it kinda works, but there's other products that works better at lower costs. But only a pro would know that.
Old May 11th, 2023, 07:26 AM   #9
Guaire
I found an explanation what is PEA here:
https://tipsforefficiency.com/pea-fuel-additive/
Thanks for the suggestion on better fuel additives. I'll be checking out the recommendations.
By amateur I meant amateur motion picture video production. From what I've seen there weren't many actual IATSE members making the videos!
Carb issue? Idealhobbies 1986 - 2007 Ninja 250R Tech Talk 1 July 13th, 2021 02:26 AM
Carb issue Detrailers 1986 - 2007 Ninja 250R Tech Talk 11 December 3rd, 2019 12:39 PM
Yet another Carb issue Foxrider64 2008 - 2012 Ninja 250R Tech Talk 7 October 2nd, 2013 09:38 AM
Carb issue zach 2008 - 2012 Ninja 250R Tech Talk 4 May 24th, 2013 10:54 AM
carb issue. justin_ninja 1986 - 2007 Ninja 250R Tech Talk 8 January 19th, 2013 07:16 PM
