Old August 17th, 2019, 07:33 PM   #1
Dan the man
Motorcycle(s): 2012 Kawasaki ninja 250R
Hazard style flashing....still flashing.
I bought a 2012 Ninja from a guy and the stock turn signals in the rear didn't work but the front had been updated to LEDs but flashed at the same time. I bought two new LEDs and installed them in the rear and got a four-way flash syndrome. I looked under the seat and he had already replace the LED resistor. so I purchased a diode online and installed it today. But I'm still getting the four way flashers, any idea where I went wrong?
Dan the man is offline   Reply With Quote
Old August 17th, 2019, 07:40 PM   #2
Welcome Dan,
I am sure someone will know the answer to this and post up soon.
Good luck!
csmith12 is online now   Reply With Quote
Old August 17th, 2019, 09:12 PM   #3
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old August 17th, 2019, 11:57 PM   #4
Hi and welcome to Ninjette.
The issue is that a little power goes through indicator-bulb in dash and lights up other side. Diodes are supposed to block flashing power from crossing across dash bulb (two required). However, there's multiple ways to connect this and you'll also have to run new ground wire for bulb.
Show us the diode kit you got (link to product?).
Also show us how you wired it up. Such as photos of actual wires you connected diodes to.
Last futzed with by DannoXYZ; August 18th, 2019 at 09:55 AM.
Flashing ECU Abu_Mishary General Motorcycling Discussion 1 June 17th, 2016 09:38 AM
ECU Flashing garth285 2013 - 2017 Ninja 300 Tech Talk 30 July 13th, 2015 11:47 AM
Dashboard flashing? arnoldc6 2008 - 2012 Ninja 250R Tech Talk 4 March 27th, 2013 05:55 AM
HELP PLEASE!!! Proton's now flashing on both sides b4idie 2008 - 2012 Ninja 250R Tech Talk 2 April 11th, 2012 02:30 AM
Faster flashing signal randomwalk101 2008 - 2012 Ninja 250R Tech Talk 9 January 23rd, 2010 11:56 PM
