Old May 28th, 2018, 08:02 AM   #1
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
el cheapo steering dampener
picked this up from ali express for $61 and some change. you have to buy the mount kit separate.
"trying not to get old"
Old May 28th, 2018, 08:28 AM   #2
Snake
Snake's Avatar
How do you like it so far?
Old May 28th, 2018, 08:29 AM   #3
maverick9611
MOTM - Feb '18
alignment off
can't bolt tank down! front of tank hits edge of bracket. will update
Old May 28th, 2018, 08:30 AM   #4
Snake
Snake's Avatar
Very interested, keep us informed!
Old May 28th, 2018, 08:52 AM   #5
maverick9611
MOTM - Feb '18
I have 2 options
#1 drill and tap new holes for tank mount.
#2 get my dremel out and start grinding on bracket.
option 2 is winning
#brainstorm#
option #3 drill out/hog out tank hold down bracket holes.
Old May 28th, 2018, 09:34 AM   #6
So have you had headshake issues under braking in the past?
Old May 28th, 2018, 09:50 AM   #7
maverick9611
MOTM - Feb '18
no, I always wanted one though
Old May 29th, 2018, 01:42 PM   #8
ck.mecha
Motorcycle(s): 1969 Benelli Cobra 125, 1970 Honda CB160, 2009 Kawasaki 250R
My racing org, WERA, requires a damper on all bikes even the little 250. I bought one exactly like this and have been using it with no problems over 2 years now I believe.
It does bolt right on with no modifications. Ill see if I can get pictures tonight. I can tell you that you will need to slide the clamp about an inch further down the body of the damper to get full lock/lock travel.
I always leave mine on the lowest damper level possible. Its only there for me to pass tech.
ck.mecha is offline   Reply With Quote
Old May 29th, 2018, 01:54 PM   #9
Old stock gsxr dampers work too. We use them to pass race tech as well, they are mostly non functional and just weight you down more, but required non the less. :\
Old May 29th, 2018, 01:58 PM   #10
I have one of those on my DT100. Watch out, the bushing in the mounting clamp can push out, disconnecting the whole thing when you least expect it. I put an oversize washer under the bolt head so the clamp can't come off over the bolt even if the bushing tries to come out.
Old May 29th, 2018, 09:42 PM   #11
maverick9611
MOTM - Feb '18
gotta pic of your mod?
Old May 30th, 2018, 06:35 AM   #12
It's just a washer under the bolt head of the bolt that mounts the movable clamp to the frame. The washer is slightly larger than the hole the bushing presses into, so even if the bushing tries to come out, the clamp can't come past the washer.
Last futzed with by Triple Jim; May 30th, 2018 at 08:15 AM.
Old May 30th, 2018, 08:52 AM   #13
maverick9611
MOTM - Feb '18
thanx
dampener alex.s General Motorcycling Discussion 16 June 10th, 2015 10:53 AM
Bought new 2013 ZX-6R...steering dampener? tsdexter General Motorcycling Discussion 27 March 12th, 2014 10:18 AM
Cheapo turn signal capriccio 2008 - 2012 Ninja 250R Farkles 6 May 10th, 2012 04:16 PM
Increased rake modification + steering dampener, a possibility? Any reason? Erin_S 1986 - 2007 Ninja 250R Tech Talk 22 April 28th, 2009 11:10 PM
