Old September 6th, 2017, 08:31 PM   #1
Baker Jr
Motorcycle(s): 2017 Ninja 300
2017 ninja 300 engine noise
Have a new ninja 300 1300 mile on it.Hearing a ticking noise on top of engine.
Baker Jr is offline   Reply With Quote
Old September 6th, 2017, 08:50 PM   #2
Hmmm, could be needing inspection and R&R of the following:
- cam-chain tensioner
- valve-clearances
- loose spark-plug?
Easy compression-test will tell you status of valve-clearance without having to open anything up. Then proceed from there.
Old September 7th, 2017, 06:12 AM   #3
Does it change when it warms up?
Have you changed the oil? Is the oil up to the proper level?
Old September 7th, 2017, 06:15 AM   #4
Perhaps loose header bolt? Exhaust can "tick" if not sealed properly.
Old September 7th, 2017, 12:50 PM   #5
Baker Jr
Changed oil 3 times. I do ride it fast.If it was a car I would say it sounds like valve or lifter noise. Switching to Mobile 1 10w 40 synthetic today. In a couple hours. I guess I'm going to take it to Kawasaki next week. Bought it on June 14.
Old September 7th, 2017, 01:16 PM   #6
Most likely that's what it is.
Valve adjustment is not scheduled to be done until 7500 mi. Most of the time the valves will wear tighter than spec, and need to have additional clearance added, so "ticking" (loose valves) shouldn't be very common - especially when new.
Does it quiet down when warm?
I'm assuming you are using Mobil1 4T - correct? Don't use the standard auto Mobil 1 10W-40.
Old September 7th, 2017, 05:08 PM   #7
Baker Jr
No doesn't quiet down warmed up. I ride it to work and back. 20 miles one way. And I do open it up a lot. I was thinking maybe values. I changed oil again today. Switched to synthetic Mobile 1 K&N oil filter. That's the best I could find around here.
Thanks everyone for advice.
Mike Baker Jr.
Old September 7th, 2017, 05:11 PM   #8
Baker Jr
This is my first bike.Can anyone recommend a good spark plug?
Thanks again.
Mike
Old September 7th, 2017, 07:57 PM   #9
bob706
bob706's Avatar
sounds like the cam chain tensioner. I had a similar noise in my 08. bought a new cct and it went away.....for about a week. I've heard a manual cct isn't as noisey
http://sandollarmotorcycleclub.com/
Old September 7th, 2017, 08:14 PM   #10
Baker Jr
Yes I'm using mobile 1 4t motorcycle oil synthetic 10w40. Hanged it tonight before I came to work. Sounded good for a while then got bad again. Can I put a manual tensioner on my bike. And should I do that or just take it back to Kawasaki?
Old September 7th, 2017, 08:20 PM   #11
Baker Jr
And again thanks for info. It's great to be able to talk to someone else about this.
Thank U
Mike
Old September 7th, 2017, 08:41 PM   #12
If it's under warranty, I'd certainly make the Kaw hierarchy fix it before doing any work that could allow them to claim that you voided the warranty.
And welcome to the board, Michael!
Old September 7th, 2017, 08:55 PM   #13
Baker Jr
Thank U, Triple Jim I will do that tomorrow morning.
Old September 7th, 2017, 09:40 PM   #14
As TJ said - take it back to the dealer. They should make any repairs under warranty if needed or at least note it down in case problems present themselves later.
Old September 8th, 2017, 08:25 PM   #15
Baker Jr
Took bike in today. The owner listened to it told me he thought it was the chain tensioner. Said they have never had any problems out of that motor. Told me it would stop doing it eventually.
Thanks all
Mike.
Old September 8th, 2017, 09:00 PM   #16
Make sure it's documented that you presented the problem to the dealer on that date and don't hesitate to go back in a few thousand miles when it's still doing it.
Old September 9th, 2017, 12:21 PM   #17
/moved to tech area
Old September 10th, 2017, 07:05 AM   #18
Thanks all
Mike.
That's a start.
A new tensioner isn't going to be expensive or hard to install, so I would think they would want to replace it under warranty as to avoid any damage that an incorrectly adjusted cam chain may cause.
Simple, quick, inexpensive fix at this point.
Not so much later.
I might push for it.
Old October 14th, 2017, 10:28 AM   #19
john pierson
john pierson's Avatar
Motorcycle(s): '00 SV650,'02 EX250,'15 EX300
DEALER B.S.!
Go back and get that in writing. The early 250s had a crappy C.T. design and supposedly the later design is better-I put a manual in my '02. That said anything can happen to mass produced items. Pieces can be flawed, broken spring, machining chip etc. If the dealer was reputable he'd take the time (2 bolts) to try a new one or at least take it out for inspection. If it heals itself then you have a miracle bike.
GUZZI JOHN
john pierson is offline   Reply With Quote
Ninja making ticking noise from engine area zaknifein 1986 - 2007 Ninja 250R Tech Talk 42 May 4th, 2017 08:28 PM
2009 ninja 250r engine ticking & knocking noise ubxssangz 2008 - 2012 Ninja 250R Tech Talk 47 January 26th, 2017 12:15 PM
