Old July 9th, 2012, 09:36 AM   #161
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
http://www.ninjette.org/forums/showthread.php?t=15025
Mine did once with the stock exhaust. I think it's twice now with my danmoto.
broilmebk is offline   Reply With Quote
Old July 9th, 2012, 09:43 AM   #162
PsHYk
PsHYk's Avatar
Motorcycle(s): 2012-250R
was just gonna send him to that... XD
theres a video in here somewhere too i just cant find it... =/
seems to be normal though...
PsHYk is offline   Reply With Quote
Old July 9th, 2012, 09:45 AM   #163
/merged
Old July 9th, 2012, 10:31 AM   #164
when you first start cranking it puts gas through the system and it flows out the exhaust until the first fire when it sends hot gas out which ignites the remaining gas vapor that was in the exhaust from before it fired. maybe more backfire on startup means your exhaust pipe has more volume to hold more gas vapors? maybe it means your jetting is rich when its cold. who knows, not me.
Old September 10th, 2012, 08:12 AM   #165
lindasninja
Motorcycle(s): Ninja 250J
Was wondering if anyone can tell me if they were totally sure you haven’t touched the throttle grip? First time it happened my son was ‘helping me’ check the oil and said wow this grip doesn’t go round that far! Yep he’s sacked! Left it to sit for a few hours in the ‘hope’ the fuel would drain, but no, sure enough bang! Took me an hour to go check, was so expecting to see aluminum shrapnel, started like a charm!
Has happened perhaps 5 times in 2700ks and only at start up! But I always have to move mine before I start her, anyone 100% sure they haven’t touched a throttle? As I was thinking this was the reason, for the backfire not just a random thing? Like after stoping the bike you give it a small twist while getting off or moving it? As I was almost sure it was extra fuel ??? Poor hubby was right behind the last time, and got the full ‘detonation’ wasn’t at all impressed, and didn’t have his helmet on either!! Woops! Totally 100% sure it’s out the pipe!
lindasninja is offline   Reply With Quote
Old September 10th, 2012, 08:25 AM   #166
dubojr1
dubojr1's Avatar
I am 100% sure.
Old September 10th, 2012, 08:29 AM   #167
lindasninja
Thanks, now I know it’s totally random and going to do it somewhere really choice!
Old September 10th, 2012, 08:45 AM   #168
bdavison
Wartown, USA
bdavison's Avatar
Look guys, I know why this happens.
When you came home the previous night on the bike, you pulled into the driveway, and hit the kill switch.
That is why.
If you pull into the driveway with even with a little bit of throttle and then hit the kill switch, it will load up a bit of unburnt fuel/vapor into the exhaust header.
The next morning when you hit the starter button, and that first burst of hot exhaust gas hits the vapor in the exhaust...it goes BOOM.
You can repeat this scenario....
Hop on your bike, Rev it up a bit, and hit the kill switch, then flip it back and hit the starter....PLUG YOUR EARS...cause its gonna go BOOM big time.
If you dont want it to pop every morning, then dont use the kill switch to stop the engine when you any bit of throttle in it.
Old September 10th, 2012, 09:35 AM   #169
Sound Wave
Ramen Rider
Sound Wave's Avatar
i never used to use the kill switch and it would still backfire every now and then. i'd let it idle a bit after the ride before shutting off the engine... didn't matter. totally random and when i least expected it.
Old September 10th, 2012, 10:29 AM   #170
lindasninja
I always thought you hit the kill switch when you were about to hit something! And the Kill switch is a bit nasty on the bike, maybe used it like 10 times to see if it worked, not crashed!? Also put in neutral when I get home, and idle it have to reverse in between cars, backwards then through a gate, usually get the angle right then, get off and turn of the bike, take helmet off and roll it to its home! I knew nothing at all, when I got my L’s so I did lots of reading, and apparently better for the engine to do the cool down thing? Go nice and gentle just a bit before you get home, and turn it off, after a few seconds of not moving like a cool down lap, but not idling too much as it heats the engine too much? Sorry think that might not help the idle theory!? Totally random again!
Old September 11th, 2012, 04:06 AM   #171
g21-30
g21-30's Avatar
Not!
I always use the ignition key to turn off the engine. You WILL get a backfire....sooner or later!
Old September 11th, 2012, 04:55 AM   #172
dubojr1
dubojr1's Avatar
Originally Posted by g21-30 View Post
Not!
He speaketh the truth. There is NO known cause.
Old November 14th, 2012, 03:03 PM   #173
250rr
250rr's Avatar
Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty
Happened to me for the first time this morning. High 40's degrees. No throttle, full choke. As one of the previous replies pointed out, it sounds like a gun shot! Thank goodness for my ear plugs.
Last futzed with by 250rr; November 14th, 2012 at 03:03 PM. Reason: Forgot something.
250rr is offline   Reply With Quote
Old November 18th, 2012, 08:16 PM   #174
thomason2wheels
thomason2wheels's Avatar
Motorcycle(s): dl650
Two weeks to the day! My bike had a healthy backfire at startup this afternoon. Lady a few houses down was working in her flower garden. It gave her a pretty good startle, So much for the thought that the CDI retrofit fixed it! I knew I shouldn't have mentioned it.
I know this is off topic, but did you notice a fuel economy improvement after backdating your cdi? Respond by pm if u like...thx.
Tom
I was with Alex.S and Jiggles last night and they had sex....the video is on utube. :-)
thomason2wheels is offline   Reply With Quote
Old November 18th, 2012, 08:25 PM   #175
thomason2wheels
When you stop the engine the odds are good at some point you will do so in a way that leaves one cylinder with fuel vapor in it and unignited. Then when you hit the starterif the exhaust valvehappens to beopen when the plug fires, boom, you get a bigbang. Makes sense to me anyway. a
Old January 17th, 2013, 12:16 PM   #176
Corona
Corona's Avatar
Motorcycle(s): 09 Ninja 250R (Crashed/Unexistent) / 11 Ninja ZX6R
I bought my bike used, the first backfire happened months after and it happened about 6 times within a month, after that I haven't had another, it's been about 3 months without it happening
Corona is offline   Reply With Quote
exhaust backfire question Mizono 2008 - 2012 Ninja 250R Tech Talk 6 May 30th, 2011 09:00 AM
Backfire after exhaust install? chef 2008 - 2012 Ninja 250R Tech Talk 6 April 2nd, 2011 09:55 AM
Backfire on downshifting and decelerating menno 2008 - 2012 Ninja 250R Tech Talk 4 August 30th, 2010 07:00 AM
Backfire when letting go of throttle Derbs420 2008 - 2012 Ninja 250R Tech Talk 38 July 20th, 2009 01:20 PM
Backfire athimmel General Motorcycling Discussion 25 March 5th, 2009 06:42 AM
