Old February 26th, 2009, 09:16 AM   #1
athimmel
athimmel's Avatar
Motorcycle(s): 2009 Ninja 250 - blue
Question Backfire
My Ninja now has about 60 miles on it. When I went to start it this morning, it backfired like someone fired a 44 magnum at me! Anyone else have this happen on a stock Ninja with few miles? I told my wife that "it happens" , but she wanted me to ask others to be sure.
athimmel is offline   Reply With Quote
Old February 26th, 2009, 09:28 AM   #2
aloh
lolwut
aloh's Avatar
Happened to me a couple times before, but I havnet heard it again for awhile.
08 Blue Ninja 250R
aloh is offline   Reply With Quote
Old February 26th, 2009, 09:42 AM   #3
Cali619
Giggity Giggity
Cali619's Avatar
Motorcycle(s): 08 ninja 250R aka Hiryu
this happened to me once before, and I am thinking its just some fuel that was not burned from before it shut down causing that. You are using the minimum octane Im assuming, cause if its a higher level maybe thats why it didnt combust right. Just a guess though...
Cali619 is offline   Reply With Quote
Old February 26th, 2009, 09:50 AM   #4
athimmel
athimmel's Avatar
Actually, for the first tank I used the mid-grade of octane. I guess that I'll use the lower octane next time.
Old February 26th, 2009, 10:10 AM   #5
ChuckFever
ChuckFever's Avatar
It happens, no worries.
My '08 does it on the first start attempt every once in awhile when it is cold and hasn't been started yet that day.
Oh, and higher octane is not good for these things, that is a misconception. Use 87.
ChuckFever is offline   Reply With Quote
Old February 26th, 2009, 10:22 AM   #6
athimmel
athimmel's Avatar
Thanks Chuck, Cali, and aloh. I knew you guys would have the answer.
It's tough being a newbie sometimes, but I appreciate the complete lack of mockery to honest questions.
Old March 2nd, 2009, 10:54 AM   #7
athimmel
athimmel's Avatar
Another shot went off yesterday. I'm worried that neighborhood watch is going to think someone's being assaulted!
Old March 2nd, 2009, 11:07 AM   #8
do you play with the throttle right before you turn off the bike or right before you start it? if so, don't do that.
Old March 2nd, 2009, 11:15 AM   #9
athimmel
athimmel's Avatar
No, I don't fiddle with the throttle in either situation.
Old March 2nd, 2009, 11:18 AM   #10
okay.
when the bike is cold, do you put the choke on before hitting the start button?
Old March 2nd, 2009, 11:30 AM   #11
athimmel
athimmel's Avatar
If it's cold, yes.
Old March 2nd, 2009, 11:35 AM   #12
last question... do you notice if the backfiring is happening more or less when you're using the choke or not?
Old March 2nd, 2009, 11:36 AM   #13
athimmel
athimmel's Avatar
It's only done it twice, so it's tough to say. I think it has happened once with and once without.
Old March 2nd, 2009, 11:51 AM   #14
I don't have definite answers for you, only what has been discussed in the past on this subject.
It happens a lot with some owners, with others, not too much. Some say it's related to playing with the throttle before shutdown or start up, I have not found any correlation to that.
My bike did backfire on me a couple of times when it was stock. I didn't notice at the time if I had played w/ the throttle or not prior to hitting the start button.
After I added a full exhaust, rejetted, added separate air filters, removed the Kleen system, etc, etc, etc. the backfiring stopped. However, one day recently when I was starting the bike, it did it again.
I don't know what to make of this, other than it seems if your bike is lean, it might make the backfiring situation worse than for others. I don't even know if it's a lean or rich situation causing the backfire, which was a topic of discussion before with no resolution.
I do know, every time my bike is cold, to start it, I turn the choke full on and then hit the start button. The bike will stumble to life and from there I adjust the choke lever so it will idle at about 2000-2500rpm. As the bike warms, you will need to readjust the choke as the revs go higher than that. After awhile, you can turn the choke off completely and it should idle between 1300-1500.
Since I've adopted that starting procedure, the backfiring has all but disappeared, but not completely.
Last futzed with by kkim; March 29th, 2009 at 04:41 PM.
Old March 2nd, 2009, 11:57 AM   #15
athimmel
athimmel's Avatar
Thanks, kkim.
You're awesome!
Old March 2nd, 2009, 12:07 PM   #16
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
Mine done it occasionally when stock and has also done it with my AreaP full system and louder! gave me a fright the first time, as both of you, I have no idea what I had done before hand. Mine doesn't do it enough for me to be concerned.
Viper-Byte is offline   Reply With Quote
Old March 2nd, 2009, 12:19 PM   #17
islanderman7
The Sexy Filipino
islanderman7's Avatar
Motorcycle(s): Ninja 250R 2008 (da black one)
Don't know if its a direct correlation but I noticed that my start up backfire happens consecutively when I haven't changed my oil for about 1000+ miles or so. As soon as I changed my oil the start up backfire goes away till it gets dirty again. Again, don't know if this is correlated but it is pattern I noticed.
islanderman7 is offline   Reply With Quote
Old March 4th, 2009, 01:00 PM   #18
Ramen
Frak It
Ramen's Avatar
Happened to me just a couple of days ago. Weather was around 45, and I started the stock bike without choke. It died because it needed choke, but I fired it up again with choke at full and it started fine. It's happened a couple of times now. Bike performs fine.
I'm not worried about it.
Ramen is offline   Reply With Quote
Old March 4th, 2009, 01:07 PM   #19
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
09' with 2 Brothers exhaust, 2 shims, snorkel and kleen air removed. Backfired the other day. I use the choke when it's cold but otherwise it starts fine without it. Who knows... It persoanlly doesn't bother me. I don't reckon it'll hurt anything. Oh ya, I run premium in every tank. Which is like 93 or something like that around here.
Old March 4th, 2009, 01:09 PM   #20
CB-
You can run premium in the bike w/o problems, but you do realize it's not helping anything with regards to power, correct? Recommended fuel is 87.
Old March 4th, 2009, 01:26 PM   #21
TnNinjaGirl
Ms. Personality
Fully aware thanks. I prefer to run it to keep things a little cleaner on the insides. I've taken apart many engines and can tell a noticeable difference in the types of oil, gas and maintenance used. Personal preference really. The cost is negliable in my eyes. Maybe I just like being different. lol
Old March 4th, 2009, 04:28 PM   #22
devinjc
Motorcycle(s): 2008 Kawasaki Ninja 205 Black
How does higher octane keep things cleaner?
devinjc is offline   Reply With Quote
Old March 4th, 2009, 04:29 PM   #23
athimmel
athimmel's Avatar
Yeah. Isn't it the detergents in the fuel that determine how clean it burns?
Old March 4th, 2009, 04:47 PM   #24
islanderman7
The Sexy Filipino
Thats what I want to know. I do know that if you buy 87 octane from top tier gas companies (i.e. Chevron, Texaco, Shell) they have detergents in their fuels to help burn cleaner.
The only thing that I know that higher octane does is to prevent engine "knocking" because of its resistivity to burn.
Old March 4th, 2009, 09:36 PM   #25
Angel-be-Good
Angel-be-Good's Avatar
Motorcycle(s): '08 Ninja 250, '11 Street Triple R
Happens to me on occasion, often enough (once ever other week roughly) that I started putting in my earplugs before starting the bike. A couple of things I make 100% sure of to try and prevent it, but nothing's changed:
  • Never play with the throttle when the bike is off.
  • I don't use the choke until after the bike has started.
I only had it happen after installing my Two Bros. muffler (not a full system), though I did that after just a couple thousand miles and the backfires didn't start immediately afterward, so it's hard to say if it's related. I do have a slight exhaust leak that I am aware of.
The Sunday Best | Current mileage: 50,000
Angel-be-Good is offline   Reply With Quote
Old March 5th, 2009, 06:42 AM   #26
TnNinjaGirl
Ms. Personality
Hmm good point. It could be the engines I've taken apart that require the higher octane are high performance and are being used as such. Blowing all of the carbon and other dirt out of the intake, exhaust and other cavities. DIdn't really think of that. Revelation, I think so. Good job ya'll.
Backfire at Startup!!!!!! g21-30 2008 - 2012 Ninja 250R Tech Talk 175 January 17th, 2013 12:16 PM
exhaust backfire question Mizono 2008 - 2012 Ninja 250R Tech Talk 6 May 30th, 2011 09:00 AM
Backfire after exhaust install? chef 2008 - 2012 Ninja 250R Tech Talk 6 April 2nd, 2011 09:55 AM
Backfire on downshifting and decelerating menno 2008 - 2012 Ninja 250R Tech Talk 4 August 30th, 2010 07:00 AM
Backfire when letting go of throttle Derbs420 2008 - 2012 Ninja 250R Tech Talk 38 July 20th, 2009 01:20 PM
