Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old May 28th, 2015, 07:29 AM   #81
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
^ 1/2 can be made to work but it is more work. Personally I feel like if you are drilling it to 1/2 you need to use a 1/2 bolt as there is too much play for my liking with the 12mm bolt. And if you use a 1/2 bolt then you need to drill out the shock mount in the frame as well and then you run into problems on the lower connecting point as well.
I would advise anyone and everyone to either buy a 12mm bit or a 31/64 bit. Don't use a 1/2" it creates more problems than it is worth... ask me how I know
Old May 28th, 2015, 07:52 AM   #82
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Originally Posted by Qomomoko View Post
can you elaborate a little? I'll do a search. I saw that I need to bore out some 5/8 inch holes ....
Very similar issue to what happens with and SV. Compression holes when done as the instructions say end up compromising fluid movement at the bottom of the stroke giving you issues with the last bit of travel. You will struggle to get your end of the stroke rebound dampening right when modified as the instructions dictate.
Old May 28th, 2015, 08:51 AM   #83
Lemonfresh
Motorcycle(s): '10 Kawasaki Ninja 250ARRRR (Sold), '13 Kawasaki Ninja 300 (Crashed), '07 Triumph Daytona 675
I know others have used a 1/2 bit as well with success.
1/2 inch is 12.7 mm. You will end up with extra clearance if you use it, probably not that big of a deal.
Lemonfresh is offline   Reply With Quote
Old May 28th, 2015, 08:53 AM   #84
ROADandTRACK
R&T Suspension
ROADandTRACK's Avatar
The proper thing to do is drill the frame and add some custom spacers.
Also, I keep saying this but the OEM shock is too short for the track. So the GSXR shock makes the bike worse than OEM.
ROADandTRACK is offline   Reply With Quote
Old May 28th, 2015, 08:59 AM   #85
Full transparency... My 250 (#511) gsxr shock top mount hole was drilled out with a 1/2 bit 1.5 seasons ago. 3 or 4 different ninjette members have ridden it on track. ALL have good reviews of how the bike felt and handled but... I aint saying it's right or wrong, but it worked out ok for me showing the bike no mercy. YMMV
Don't forget the blue locktight on the bolt no matter what you do.
Old May 28th, 2015, 09:15 AM   #86
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
^ as long as it is all tight like a tiger I would assume it is all good to go but don't have any experience, however I do remember a member here posting that they went with 1/2" hole with the 12mm bolt and after a few races they noticed damage/deforming of the top shock eye because of the extra space allowed movement and acted like a hammer so to speak. Alas they had no pictures but that is what they said.
still think the best way to go is with the proper bit size, no reason not to IMO
Old May 28th, 2015, 09:24 AM   #87
But of course!
Old May 28th, 2015, 09:34 AM   #88
Lemonfresh
Attachment 36680
Sorry we all don't have $600 laying around to spend on the correct length shock. The gsxr shock may be a little shorter in height but it is miles better than the stocker in damping.
Old May 28th, 2015, 09:43 AM   #89
ikr.... I have been beaten by riders on stock bits (front and rear) at damn near lap record pace. So not sure why some riders think the stock stuff is 100% garbage for track, because it aint. It's just the rider doesn't like it, which is fair enough.
The pic below tells the story. Take some of the preload out and the bolt holes will line up, then drill it out. Install the proper rate spring and then get custom bones to put the height where you want it, then enjoy the ride.
Old May 28th, 2015, 10:21 AM   #90
sharky nrk
sharky nrk's Avatar
Attachment 36680
Where did you get those spacers? Link? Are they 12mm od 10mm id flanged?
Old May 28th, 2015, 01:28 PM   #91
ROADandTRACK
R&T Suspension
Not for the track
Old May 28th, 2015, 01:30 PM   #92
ROADandTRACK
R&T Suspension
They come with the Frankenshock we sell for $450 or you can buy them alone for $20/pair shipped.
Old May 28th, 2015, 02:37 PM   #93
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
For whatever it's worth, I used a 12mm reamer bit on my SV650 shock. It was a tighter fit than the "12mm" hole in my stock EX500 shock with only a few thousand miles on it. Using a 31/64" (12.3mm) is probably just as good as stock. As stated, the 1/2" (12.7mm) bit is adding a bit more slop, but we're still talking about fractions of a millimeter.
Old May 28th, 2015, 02:38 PM   #94
InvisiBill
InvisiBill's Avatar
Originally Posted by Manimal View Post
What is the weight rating of the OEM springs, btw? Just curious is all.
Don't take it as gospel (especially since the numbers on their site have been changed), but RT's calculator says the stock .65kg/mm springs are good for 96lb on the street or 76lb for racing. The 9.3kg/mm rear is good for 210-220lb. The '06-'09 GSXR 600 spring is just a tad stiffer at 9.4kg/mm.
Originally Posted by Somchai View Post
Manimal, where did your suspension guy get the calculation from about the front spring is to soft for you?
My weight is 175 lbs and when I go to the racetech website to calculate my spring rate it gives a 0.70 kg/mm spring for me.
The NewGen and 300 calculators both give me .746kg/mm street and .783kg/mm race when I put in 160lb. For 175lb, I get .768 and .807.
Old May 28th, 2015, 09:30 PM   #95
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Your right, I guess this depends on their upgrades since the calculation I'd make was when I changed my setup more than two years ago
But at least I don't see any reason to change my setup (made from a twenty year experienced Irish Kawasaki race mechanic) since suspension setup does not only depend on the spring rate, like told here every time.
Old May 28th, 2015, 09:32 PM   #96
sharky nrk
sharky nrk's Avatar
how much of that is shipping? I am in San Antonio area from time to time. You can PM me if you would like. I think I asked about the Frankenshock before but can't really remember the conversation. Does the 450 include a service/freshening, and is it resprung/revalved for each customer's needs or is the 450 a "one size fits all based off the shelf jobber"?
Old May 29th, 2015, 09:13 AM   #97
ROADandTRACK
R&T Suspension
None of it is shipping and it is set up for you with the proper spring and valving.
Old July 27th, 2015, 09:33 PM   #98
supersport
Motorcycle(s): Ninja 300
Is the GSXR shock mod really that bad?
supersport is offline   Reply With Quote
Old July 28th, 2015, 10:02 AM   #99
GregS
Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100
Can't speak for the stock GSXR shock, but I have the GSXR Frankenshock that Keith Hertell at Road and Track sells and it made a big difference. Money well spent!
GregS is offline   Reply With Quote
Old July 28th, 2015, 11:06 AM   #100
sharky nrk
sharky nrk's Avatar
I want to get one, its likely to be my next track bike purchase but money is so tight
Old July 28th, 2015, 11:29 AM   #101
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
No it's not bad at all I use it. It is rebuildable and lot less than an Olins and is head and shoulders above stock for less than $100.
accumack is offline   Reply With Quote
Old July 28th, 2015, 07:08 PM   #102
Lemonfresh
Some seem to be saying it is terrible on the track. I wouldn't know I have only used it on the street. I can say this, it is much better than the stock shock for that purpose.
It is less than 5mm shorter than the stock shock. It will affect the trail and anti-squat of the bike. Trail can be compensated for by adjusting the fork height in the triples.
Will you feel the change in anti-squat on the street? Probably not.
For an upgrade less than $100 including hardware, it's a no brainier.
Old July 28th, 2015, 07:11 PM   #103
howlinhoss
I did tires first then suspension. However, if I were to do it again I would have done suspension first.
howlinhoss is offline   Reply With Quote
Old August 3rd, 2015, 07:07 AM   #104
sharky nrk
sharky nrk's Avatar
I think the answer is almost always "it depends" lol. I mean your weight, riding style, other mods, etc all will dictate whether its an "improvement" or not for your particular application.
On the track, that 5mm difference is a BIG DEAL. I have the shorter dogbones and if your considering the GSXR shock for track work, getting that rear geometry change back is a must.
On the street for commuting/regular riding purposes....I suppose if the spring was in the right range and you had the shock adjusted properly it could be better, and certainly the adjustment flexibility is nice. But a "better" / "more adjustable" shock that is well out of range for the rider/riding style is not a "better" shock at all
Old August 3rd, 2015, 09:06 AM   #105
InvisiBill
InvisiBill's Avatar
I think this is precisely it. The '06-'09 GSXR600's spring rate is nearly identical to the NewGen/300 stocker (I'm not sure if that's a carefully researched feature or pure coincidence). However, most signs indicate that this rate matches a ~215lb rider. Also, other GSXR shocks have a variety of spring rates. Depending on exactly which GSXR shock you buy, you may or may not be matching the stock spring rate, which may or may not work well for your weight.
I've seen very little mention of the NewGen/300's relatively stiff rear spring (I brought it up in another thread). If the rear can't properly absorb bumps, especially with too-soft fork springs, it'll bounce around like a rocking horse. If you're replacing the crappy, way-off stock parts with better, way-off donor parts, I wouldn't expect much improvement. The fact that they're better parts might even exacerbate the fact that they're mismatched.
Shock Swap Myth points out some issues with swapping in a shock from some random bike. There are many ways to skin a cat, and Suzuki's way might vary greatly from Kawasaki's. The GSXR shock is made for the GSXR suspension, not the Ninja suspension. On the other hand, they seem to be close enough that many people are very happy with the GSXR shock swap. If you're starting with bottom-of-the-barrel non-adjustable parts, it's not hard to find something that does work better, even if it's not perfect. If you can spend $35 and get a drop-in shock with better features and a good spring rate, that sounds like a great value upgrade (even if you spend another $35 on a second shock to get a donor spring with a better rate). I've personally used multiple shocks from other bikes on my 500, and been very happy with the results given the cost. If you spend nearly $500 trying to make that wrong shock into the right shock, you're now into the price range of good aftermarket shocks, and most likely will still be ending up with something not all that great.
I think it's around 3:1 for height changes at the shock compared to the axle. So the shock being 5mm shorter equates to the rear end being over 1/2" lower. While I'm sure it's a much bigger deal on the track, it will still affect the steering on the street too. It'll just be slower to turn and feel less flickable overall. While I'm sure a pro racer wouldn't just toss in a different shock like this, the 5mm difference shouldn't alter the angles in the suspension geometry much, and the rear height can be corrected via dogbones (R&T said above that even stock is too low anyway).
Overall, I think this can be a budget way to get a decent upgrade. Depending on the specifics of your mod, it's possible to do things in a way that will actually make things worse though. If you do some research and/or testing, I think you can end up with something quite cheap that will perform quite well.
200lb rider on an 11 yro pre-gen; suspension upgrades? aelath 1986 - 2007 Ninja 250R Tech Talk 42 February 1st, 2015 07:40 PM
Budget suspension upgrades? Worldtraveller Ninjettes At Speed 40 October 11th, 2014 02:59 AM
Suspension Upgrades - For a skinny mof**ka NinjaNinja2012 2008 - 2012 Ninja 250R Tech Talk 18 July 6th, 2014 04:34 AM
Suspension upgrades: which first? cuong-nutz Ninjettes At Speed 11 November 29th, 2011 06:44 AM
[roadracingworld.com] - STM Suspension Holding Suspension Seminar June 25 In Colorado Ninjette Newsbot Motorcycling News 0 June 21st, 2011 10:10 AM
