Old June 7th, 2015, 07:14 PM   #1
uberwoot
Motorcycle(s): 250R
what gearing for my weight for highway riding.
Ok so I read up on what gearing people are running but I would like some feedback since I did not find info on rider weight.
What gearing are the 200-230lb riders doing for 70mph rides? I'm a little high on the rpms so I would like some feedback from the bigger guys.
uberwoot is offline   Reply With Quote
Old June 7th, 2015, 07:21 PM   #2
snot
sammich maker
snot's Avatar
MOTM - Apr '15
lol.... gearing not gear.
Last futzed with by snot; June 8th, 2015 at 02:56 AM.
Old June 7th, 2015, 07:29 PM   #3
verboten1
verboten1's Avatar
MOTM - June '15
I assume you mean sprockets? I ran a15 tooth front sprocket plenty of power for that still. ~300 pounds
Ride more, worry less.
Last futzed with by verboten1; June 8th, 2015 at 04:50 AM.
Old June 7th, 2015, 08:15 PM   #4
Ghostt
Ghostt's Avatar
I'm about 230lbs with full gear, I run +1/-2 set up, at 70mph roughly about 7.5k RPMs, at 75mph it's about 8k which is perfect for me and the power band of the bike
I used set up when I went to the north Carolina coast last year, about 700 miles in one day, no problems whatsoever.
Here's a fun link to play around with, http://www.gearingcommander.com/
violente et ignorantia
ZX-2R BLOG
Old June 7th, 2015, 08:27 PM   #5
Originally Posted by snot View Post
my hubby prefers leathers, but started with textile because it is easier to find.
I know many others who are leather only.
File Type: jpg Swing+and+a+miss+_fc7b4af5ee90f7b7343906b478ac79e2.jpg (5.7 KB, 98 views)
Old June 8th, 2015, 01:10 AM   #6
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
These motors are made to rev, changing the gearing is a compromise you may gain a little here but loose a bit somewhere else. Manufactures spend a lot of time and money designing a bike that will perform well in all road conditions, unless you have just one need I would stay with the stock gearing and let it rev
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old June 8th, 2015, 06:43 AM   #7
uberwoot
Motorcycle(s): 250R
Right now I'm at about 8k at 70. I would like to be around 8.5k at 75
Old June 8th, 2015, 01:42 PM   #8
Ghostt
Ghostt's Avatar
Try changing the front sprocket to 15t, it's easy enough to do, and inexpensive too.
ZX-2R BLOG
Old June 8th, 2015, 02:40 PM   #9
uberwoot
Motorcycle(s): 250R
Ok I'm going to try that this weekend. Thanks.
Old June 8th, 2015, 02:47 PM   #10
Ghostt
Ghostt's Avatar
As I said it's easy enough to do, any questions feel free to ask.
ZX-2R BLOG
Old June 14th, 2015, 07:17 AM   #11
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
15T sprocket should be stick. Makes the bike much more usable in my opinion. I seen someone mention a 43T rear sprocket? Where from?
Old June 14th, 2015, 09:18 AM   #12
johncrist1988
johncrist1988's Avatar
Motorcycle(s): 2006 EX250-F "Sheldon" (Sold), 2010 Ninja 250R "Zeke"
The 15 is great, provided you do a lot of highway. I hit the highway about once a week so I stick with the stock. A buddy of mine hits the highway twice a day and 15 was a great move for him.
johncrist1988 is offline   Reply With Quote
Old June 14th, 2015, 11:39 AM   #13
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Based on OP original question, 15T should work great for him.
In terms of my comment of 15T being stock, I make that based in several things. 250s are generally, or were, purchased by new riders, with limited or no skill. The stock 14T with standard gear ratios, I along with others here found the 1st gear mostly unusable. By moving to 15T, the bike seem slightly more stable as it isn't jerky from how quickly the RPMs rise in first gear. Also, the rider isn't as worried about quickly shifting as it changes the ideal shift points slightly. And as you mentioned, makes the bike better equipped for highway riding. I do 60% highway, so I'm well aware of the benefit, even interested a 43T rear.
I can see where a veteran rider would like the 14T as it makes the bike more peppy, just feel 15T is more universal.
Old June 14th, 2015, 11:52 AM   #14
Ghostt
Ghostt's Avatar
That would be me, I'm running +1/-2 setup, it works nicely for me.
ZX-2R BLOG
Old June 14th, 2015, 12:10 PM   #15
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
43T rear? Still feel the bike has plenty of power and get away?
Old June 14th, 2015, 12:18 PM   #16
I75mph it's about 8k which is perfect for me and the power band of the bike
and here i thought the power band was 11k-12k
Old June 14th, 2015, 01:29 PM   #17
Ghostt
Ghostt's Avatar
http://faq.ninja250.org/wiki/Acceler...changing_gears
ZX-2R BLOG
Old June 14th, 2015, 01:30 PM   #18
Ghostt
Ghostt's Avatar
I think so,
ZX-2R BLOG
Old June 14th, 2015, 01:42 PM   #19
Old June 15th, 2015, 02:52 PM   #20
wardie
Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT
gearing
I put 8700 miles on my bike in its first year. I changed to 15/41. She won't pull past 93 or 95 mph but cruises all day at 70 at 7200 rpms. Took a 2700 mile trip on her great gas mileage. If I had it to do over I think 15/43 might be the best all arounder. Wardie
wardie
wardie is offline   Reply With Quote
Old June 15th, 2015, 08:54 PM   #21
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
FYI your weight has nothing to do with the revs.
TEAM ALFALFA
www.apexassassins.com
Old June 18th, 2015, 07:50 PM   #22
wardie
Weight comes into play on acceleration, deceleration and fatigue and maybe you have to add some air in your tires
wardie
Old June 19th, 2015, 04:31 AM   #23
DaBlue1
DaBlue1's Avatar
I weigh around what you weigh. As a frequent Hwy rider I use 15/41 and still outpace most traffic easy. Also keep in mind that with sprocket changes it doesn't hurt to do a few small intake/performance mods. for a little extra oomph.
https://www.ninjette.org/forums/show...1&postcount=20
Highway Riding Questions Proteus Riding Skills 12 August 18th, 2014 05:03 AM
Highway riding? lstat 2008 - 2012 Ninja 250R Tech Talk 12 May 20th, 2012 05:10 AM
Highway riding Noob erittz Riding Skills 9 April 9th, 2012 07:21 PM
[motorcyclistonline] - California's Historic Highway 49 is Worth Its Weight in Gold Ninjette Newsbot Motorcycling News 0 February 10th, 2011 11:30 PM
Highway Riding Snake Riding Skills 48 November 30th, 2010 11:15 PM
